ZMNHCDx with Domoticz partially working
Posted: Sunday 05 January 2020 0:29
by helppp
Hi All!
I have 2x ZMNHCDx modules here and want to use them to control my shutters on the outside of the house. When adding new hardware I only get one 'level' switch added, this controls the "Q2" connector, but I cannot control the Q1 feed. It simply is not added.
What I have tried;
- exclude module -> add it again; same devices added
- reinstall Domoticz -> even with clean install, same devices added (only Q2 control possible)
- Google for hours and hours, all suggestions (different config file, same result; no secondary 'level'
- Tried all devices as 'level' and see if maybe one was mapped wrongly -> not the case
This issue is with both modules, brand new, so I don't think this is an RMA module, but rather Domoticz! I can see many people using Domoticz with this module, so I must be doing something wrong ... but whát?
Thanks for any advice!
Re: ZMNHCDx with Domoticz partially working
Posted: Monday 06 January 2020 13:08
by lost
helppp wrote: Sunday 05 January 2020 0:29
https://github.com/OpenZWave/open-zwave ... MNHCDx.xml
1st check if your config file is up to date (didi not changed since 7 month, but inclusion in Domoticz embedded OZW may extend this delay), maybe this was already done after googling, indeed... But you may have missed that when a device is added with one conf file version, it gets added on OZW conf cache file for added nodes and never checked again for base conf file change!
=> Stop Domoticz service, edit the OZW cache conf file (don't remember the name & not at home, but should be easy to find, something like ozwcfg_???.xml ) to remove all nodes xml data (bock between <node and /node> if I remember correctly), then restart Domoticz service. OZW cache config wil be rebuilt for removed nodes.
Take care to respect whole file syntax (keep a copy in case of error). You may remove whole file, but restart will be longer (+ if conf file changes since some devices inclusion cause issues, you'll run into them).
Posted: Friday 10 January 2020 15:51
by helppp
Hi Lost, thank you very much for your reply! I indeed tried this; remove (exclude the module), replaced the configuration file for ZMNHCDx.xml + remove the cache config file, reboot and thén re-included the module. Still I just have one 'level' switch when the hardware is added under 'devices' page in domoticz. Anybody has a clue how I can debug this?
Posted: Monday 13 January 2020 19:19
by helppp
After some more trying;
2020-01-13 18:13:43.960 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2020-01-13 18:13:43.963 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1, Index: 6
2020-01-13 18:13:43.964 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1, Index: 7
2020-01-13 18:13:43.964 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1, Index: 8
2020-01-13 18:13:43.964 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1, Index: 0
2020-01-13 18:13:43.964 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1, Index: 1
2020-01-13 18:13:43.965 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1, Index: 2
2020-01-13 18:13:43.965 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2020-01-13 18:13:43.965 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2020-01-13 18:13:43.965 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2020-01-13 18:13:43.966 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2020-01-13 18:13:43.966 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2020-01-13 18:13:43.697 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
2020-01-13 18:13:43.697 Status: OpenZWave: Received unhandled notification type (30) from HomeID: 0, NodeID: 0 (0x00)
2020-01-13 18:13:43.697 Status: OpenZWave: ManufacturerSpecificDB Ready
2020-01-13 18:13:43.900 Status: OpenZWave: Driver Ready
2020-01-13 18:13:43.964 Status: SendSwitchIfNotExists: Device '2.instance.1.index.0.commandClasses.38' (Level) with DeviceID '00000201' matches '2.instance.1.index.0.commandClasses.37' (Switch). Domoticz will use the Dimmer (and hide the Switch).
2020-01-13 18:13:49.763 (USB) General/kWh (kWh Meter)
2020-01-13 18:13:49.847 (USB) Usage (Unknown)
2020-01-13 18:13:49.848 (USB) General/kWh (kWh Meter)
2020-01-13 18:13:49.921 (USB) General/Alarm (Alarm Type: Power Management 8 (0x08))
2020-01-13 18:13:49.927 (USB) Light/Switch (Power Management)
Seems there is something wrong. This is with a clean configuration file (I did a complete reset for the AEON Z-Stick gen 5), excluded the module and reinstalled domoticz. Still a no-go! Anybody? I tried now with a clean Domoticz stable ánd beta version, both only a single switch is added, not for the other port. Same for both modules, so pretty sure it is not an RMA.
