Color slider not visible/available in Dashticz?
Posted: Saturday 04 January 2020 15:11
by Sjonnie2017
I am trying to figure out how to get the color slider to show up in Dashticz. I have been reading through some threads over here after a search for "color slider" but all I found were ancient threads/posts that entailed hacking around in main.js or custom.css. I was under the impression the color slider was added to a version of Dashticz (V2) some time ago but I can't get it to work out of the box.
So probably I am missing something very obvious here...
Some details:
Screenshot of the switch in Domoticz:
Screenshot of details of the switch (122):
The same switch in Dashticz:
Settings in var config:
config['no_rgb'] = 0;
config['hide_off_button'] = 0;
Changing 'no_rgb' to 1 and/or changing 'hide_button_off' to 1 made no difference
Settings for the block:
// Dimmers - Eettafel
blocks[eettafel] = {}
blocks[eettafel]['title'] = 'Eettafel';
blocks[eettafel]['width'] = 12;
//blocks[eettafel]['hide_data'] = false;
What am I missing in Dashticz or what do I have to configure?
TIA
Greetz,
Sjonnie
Re: Color slider not visible/available in Dashticz?
Posted: Monday 06 January 2020 0:55
by clinkadink
You could try checking the device's data in Dashticz by ....
The code seems to be looking for a device subtype of RGB, RGBW or RGBWW. If that isn't there, the slide won't show.
function isRGBDeviceAndEnabled(device) {
return (typeof (settings['no_rgb']) === 'undefined'
|| (typeof (settings['no_rgb']) !== 'undefined'
&& parseFloat(settings['no_rgb']) === 0))
&& (device['SubType'] === 'RGBW' || device['SubType'] === 'RGBWW' || device['SubType'] === 'RGB');
Posted: Monday 06 January 2020 5:53
by Sjonnie2017
Tx! Will check this evening and post back results.
Greetz,
Sjonnie
Posted: Monday 06 January 2020 18:31
by Sjonnie2017
OK, tried to figure out how to use your first code fragment. I pasted it in custom.js like so:
function getStatus_122(idx, value, device) {
console.log(device.Level)
Saved the code and refreshed Dashticz web interface (although I did not believe that would do the trick). Read the docs but couldn't find an indication what to do. Sorry, I am at a loss here.
I know it is silly but can you explain in detail what I should do?
Thank you!
Greetz,
Sjonnie
Posted: Friday 10 January 2020 14:23
by Sjonnie2017
Tried the second part of the code but no joy. I am stuck.
One thing I noticed though is that the device is identified in Domoticz as "RGBWWZ". Don't know if the code should be adapted to that
Any tips are highly appreciated!
Greetz,
Sjonnie
Posted: Friday 10 January 2020 16:24
by Lokonli
Sjonnie2017 wrote: Friday 10 January 2020 14:23
Greetz,
Sjonnie
Yes, probably the code needs to be adapted for that. Can you post the output of:
http://<domoticz-ip>/json.htm?type=devices&rid=122
Posted: Friday 10 January 2020 16:37
by Sjonnie2017
Of course
ActTime 1578670530
AstrTwilightEnd "18:53"
AstrTwilightStart "06:42"
CivTwilightEnd "17:29"
CivTwilightStart "08:06"
DayLength "08:03"
NautTwilightEnd "18:12"
NautTwilightStart "07:23"
ServerTime "2020-01-10 16:35:30"
SunAtSouth "12:48"
Sunrise "08:46"
Sunset "16:49"
app_version "4.10717"
result
0
AddjMulti 1
AddjMulti2 1
AddjValue 0
AddjValue2 0
BatteryLevel 255
Color ""
CustomImage 0
Data "Off"
Description ""
DimmerType "abs"
Favorite 1
HardwareID 11
HardwareName "ConBee2"
HardwareType "deCONZ plugin"
HardwareTypeVal 94
HaveDimmer true
HaveGroupCmd false
HaveTimeout false
ID "GROUP_Verlichting_Tafel"
Image "Light"
IsSubDevice false
LastUpdate "2020-01-10 14:15:36"
Level 0
LevelInt 0
MaxDimLevel 100
Name "Eettafel"
Notifications "false"
PlanID "0"
PlanIDs
0 0
Protected false
ShowNotifications true
SignalLevel "-"
Status "Off"
StrParam1 ""
StrParam2 ""
SubType "RGBWWZ"
SwitchType "Dimmer"
SwitchTypeVal 7
Timers "false"
Type "Color Switch"
TypeImg "dimmer"
Unit 7
Used 1
UsedByCamera false
XOffset "0"
YOffset "0"
idx "122"
status "OK"
title "Devices"
Thank you for your support!!
Greetz,
Sjonnie
Posted: Friday 10 January 2020 17:11
by Lokonli
Could you test latest beta?
(I don't have a RGBWWZ device, so I was not able to test)
Posted: Friday 10 January 2020 17:13
by Sjonnie2017
I would be happy to. I am currently on 3.3.0. Is there an even newer version?
Greetz,
Sjonnie
EDIT: Would it be helpful to post a bug report on github?
Posted: Friday 10 January 2020 17:55
by Lokonli
Sjonnie2017 wrote: Friday 10 January 2020 17:13
Greetz,
Sjonnie
I did not change the version number yet. It's the version of one hour ago.
Posted: Friday 10 January 2020 18:32
by Sjonnie2017
At least there is no discussion if I use the latest version
