I'm trying to use the HTTP Listener plugin (provided as part of the Domoticz plugin/example) with the HTTPS protocol.
While if you use HTTP (line 166 of the plugin here attached), it works well ( in response to a GET from a browser you get "Successful GET!!!" ), it doesn't work with HTTPS and it even crash Domoticz !
Attach is the plugin.py listening on HTTPS (by default on port 8008)
CC: @Dnpwwo
Plugin listening on HTTPS crash Domoticz
- plugin.py.zip
- (2.45 KiB) Downloaded 33 times
Re: Plugin listening on HTTPS crash Domoticz
Should I create an Issue in GitHub ?
any hint/idea ?
