Zigbee Control Station Z1 not compatible?
royklo
Post by royklo »
Hi guys,
I''ve just installed domoticz on my Synology DS218 and checked some youtube videos about how to configure everything (doesn't look that hard to install btw..)
But at the first step you have to add your hardware component, in this case it is the Zigbee Control Station Z1. But i can't find the right hardware type, or am I missing something?
https://www.trust.com/en/product/71168- ... station-z1
This bridge is working with Zigbee and there is a shitload of unknown hardware types and Trust is a pretty known brand, so it should be possible I guess?
Does anyone know what it could be or which one i have to add?
Thanks is advance!
Thorgal789
Re: Zigbee Control Station Z1 not compatible?
Post by Thorgal789 »
Sorry, but on m y side I don't see anything to control this hardware with another application, no API, no plugin, ...
royklo
Post by royklo »
That’s strange right? Because the older version with the 433 MHz is possible to function fully operational?
That’s why I was asking if I overlooked something...
royklo
Post by royklo »
Thorgal789 wrote:Hello,
So when I buy the Philips hue bridge and I connect all my lamps with the hue bridge it should work right?
mosjonathan
Post by mosjonathan »
Yes it should.
You can also build your own zigbee bridge and use zigbee2mqtt or buy a conbee2 and use the deconz python plugin.
Thorgal789
Or there is too the zigate plugin.
There is lot of way to use zigbee devices, but I have never see the "zigbee control station Z1" on domoticz or in other application.
