Page 1 of 3
custom icons
Posted: Thursday 02 January 2020 19:34
by JuanUil
Hi there,
I have found some icons I want to use for my curtains.
I have a open.png and a close.png, when i combine them in an zip file (curtains.zip) and want to upload them I get an error "No icon definition file not found.
What am I doing wrong?
Or when anybody has curtain icons in a zip file please share them with me
Re: custom icons
Posted: Thursday 02 January 2020 21:44
by FireWizard
See:
https://www.domoticz.com/wiki/Custom_ic ... binterface.
Upload your icons to the link below and it will create your complete Zip file.
https://domoticz-icon.aurelien-loyer.fr/
Re: custom icons
Posted: Friday 03 January 2020 11:16
by JuanUil
Thank you verry much!
Works like charm!
Re: custom icons
Posted: Friday 03 January 2020 11:50
by EdwinK
Keep getting an 'undefined' error.
Re: custom icons
Posted: Friday 03 January 2020 21:39
by FireWizard
Hello EdwinK,
Can you give a little bit more info.
Where do you get that? When do you get it? What are the contents of your zip file?
Re: custom icons
Posted: Friday 03 January 2020 22:01
by EdwinK
FireWizard wrote: Friday 03 January 2020 21:39
Hello EdwinK,
Where do you get that? When do you get it? What arethe contents of your zip file?
Uploading through custom icons
At first nothing seems to hppen, but then the 'error uploading iconset: undefined'
Created zip file with the earlier mentioned site (
https://domoticz-icon.aurelien-loyer.fr/) containing on and off images.
Re: custom icons
Posted: Friday 17 January 2020 17:32
by macieiks
I've got the same error message: "Error uploading Iconset: undefined"
Using latest beta:
V4.11605
Build Hash: 7de1f368f
Build Date: 2020-01-08 23:12:15
Any idea if there is any fix? Perhaps workaround like manual copy?
Re: custom icons
Posted: Wednesday 05 February 2020 12:21
by fireport
I have domoticz 4.11553 on Fedora 31 and when I tried to upload some icons taken from the google link provided by documentation, nothing happens.
Any idea ?
Re: custom icons
Posted: Wednesday 04 March 2020 11:35
by Gangelie
I got the same issue, generated icon set with
https://domoticz-icon.aurelien-loyer.fr/, go to Custom Icon, insert the zip file via Choose Button and klick upload, it takes about 5 seconds and then "Error uploading Iconset: undefined"
Version: 4.11775
Build Hash: 09054c6c9
Compile Date: 2020-03-04 08:38:33
dzVents Version: 3.0.1
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
Re: custom icons
Posted: Friday 27 March 2020 12:05
by desertdog
I have the same problem with the latest stable version. The custom icon's top half of the page stays white. And when I select a zip file containing the icons (downloaded from Custom Icons Google Drive) the buttons don't seem to respond. This happens on mac (os x 10.5.3) both in safari and chrome
Sometimes, but not all the time it seems, I get the error: Error uploading Iconset: undefined
Version: 2020.1
Build Hash: 63fa969e4
Compile Date: 2020-03-22 15:16:16
Raspebby pi with lastest Debian Buster
Re: custom icons
Posted: Sunday 29 March 2020 9:24
by F4ntY
Same issue here.
Version: 2020.1
Running on a rasperry pi:
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Re: custom icons
Posted: Sunday 31 May 2020 11:09
by kitopopo
Same problem in a raspberry pi 4
Version: 2020.2 (build 12106)
Build Hash: b08d17c2d-modified
Compile Date: 2020-05-29 09:01:13
dzVents Version: 3.0.8
thanks in advanced
Re: custom icons
Posted: Sunday 31 May 2020 11:34
by zicht
Just tried in windows test environment with latest update, created a test icon with an excisting name and a unique name.
Python Version: None
I noticed a writing right issue in the domoticz dir (Win10)
On a second try i saw overwriting was still an issue (have a unique name)
After solving the writing right issues all worked fine --> = Platform related and not domoticz related.
Re: custom icons
Posted: Sunday 31 May 2020 12:04
by kitopopo
I have given write permissions to the entire domoticz folder and it still does not work, they should tell us which folder needs these permissions in order to solve the problem, an end user does not know these things, please explain well how to solve it. thanks in advance
Re: custom icons
Posted: Tuesday 29 September 2020 15:23
by rgroothuis
I'm having the same problem, have not found a solution yet:
My Domoticz is running on a Raspberry Pi 4, software details:
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Would be great to have a solution and/or a work around.
Re: custom icons
Posted: Wednesday 30 September 2020 13:19
by K3rryBlue
It seems that ICON upload is not supported via Linux or MAC. Had the same issue uploading from my MAC. Uploading the same on a WIN10 PC didn't give any errors.
Re: custom icons
Posted: Wednesday 30 September 2020 13:23
by rgroothuis
K3rryBlue wrote: Wednesday 30 September 2020 13:19
Confirmed, I finally got this info from another thread in this forum. I've confirmed there it was working from a Windows Virtual Machine on my Mac.
Re: custom icons
Posted: Tuesday 24 November 2020 19:12
by wkossen
i have the same problem. linux rpi.
i kinda think it might be a write-access problem as that is a difference between windows and the 'ux-based' filesystems of macos and linux.
i can't find where the icons are supposed to be stored, else i would try some chown and chmod commands on those folders.... maybe some of the specialists can have a look at this?
Re: custom icons
Posted: Tuesday 24 November 2020 19:24
by wkossen
a bit of searching on the pi taught me that the icons might be in the www/images folder under /home/pi/domoticz. i noticed something interesting there. the icons added by plugins (like fritzpresence) are owned by root, as the rest is owned by pi (from which user i installed domoticz). Doing a sudo chmod -R a+w images on that folder doesn't help anything, so it's not just access on that folder. i'm now wondering where the temporary (zip)file is uploaded to and unzipped from, and wether that is allowed. again. i'm not the expert here...
Re: custom icons
Posted: Monday 25 April 2022 14:11
by JuanUil
I have made 4 custom icons with the icon generator.
Uploaded them in Domoticz on my pi4, no problem.
Now I have made a fifth one and I can not upload it anymore.
When I click upload nothing happens.
anyone any idea?
grtz
Jan
