SEAV sunscreens
Posted: Thursday 02 January 2020 14:41
Hello all,
I recently bought a RFXCom, which is doing a good job already!
Now I am trying if I can add our sunscreen to Domoticz by the RFXcom, since our sunscreen is fitted with SEAV devices.
The remote that I have is the SEAV TXS2 new, better known as the TXS212-1.
According to the RFXCom manual, the TXS4 is supported, so I thought maybe the TXS2 is also easy to connect.
Unfortunately, Domoticz tells me that the signal is already in use by my Philips Hue motion sensor.. which is strange because it uses a completely different type of broadcasting?
Is there anyone that haves experience with this? The remote does have the same settings as in the RFXcom manual, so I tried to use the same HEX as the manual, but that doesn't work. As an ultimate solution, I could buy a TXS4, and connect it, but I am quite sure there are better ways
Many thanks in advance!
