Popp Z-rain
Posted: Wednesday 01 January 2020 12:26
by TheHoff
Greetings
After my Oregon Scientific 433mhz rain gauge broke I got me a Z-wave rain gauge instead. Seems much more robust than the Oregon one. I've got the Aeon Z-stick connected to my Pi3 running Domoticz beta 4.11590 with one other Z-wave node connected, a Fibaro switch.
Pairing the Z-rain was pretty easy and Domoticz sees it as a rain rate/Custom sensor and rain sensor. However when I test the gauge, a few hours after pairing, by tipping a cup of water into the bucket only the rain rate is updated. The rain amount is not.
Also the Domoticz logs gives the error message when I include the Z-rain gauge, don't know if it's related.
"2020-01-01 13:28:22.390 Error: OpenZWave: Value_Changed: Unhandled value type ZDTYPE_SWITCH_NORMAL (2). Node: 14 (0x0e), CommandClass: SENSOR MULTILEVEL, Label: General Purpose, Instance: 1, Index: 2 (OpenZWave.cpp:3188)"
Any idea what this is?
/Fredrik
Re: Popp Z-rain
Posted: Sunday 16 February 2020 9:43
by kevster
Did you get any further with this. I'm looking for a new guage too...
Re: Popp Z-rain
Posted: Sunday 16 February 2020 12:51
by Snowtiger
It looks like it's interpreting this device as a Switch, 1 value, opposed to it being a Sensor multi level device - 1 instance, 2 index.
The module OpenZwave.cpp can not detect it as a multi level device and therefor throws this error in the specified line number.
Is it Popp product code 700168? If it is, then it is in the Zwave product database.
Re: Popp Z-rain
Posted: Tuesday 18 February 2020 9:42
by lander
If it's in the Zwave product database it should work, no?
Popp Z-rain
Posted: Tuesday 18 February 2020 13:41
by Snowtiger
Yes, it should work
BTW to be precise - it is the OpenZwave 'database' which is incorporated into Domoticz.
Re: Popp Z-rain
Posted: Sunday 22 March 2020 22:31
by Abber
How did this end? Does the Popp Z-rain work as expected? Is the rain amount monitoren correctly in Domoticz?
I am considering to buy the Popp z-rain, but fot €80 I want to be sure that the amount of rain is monitored correctly!
Thanks for letting me know!
Re: Popp Z-rain
Posted: Monday 23 March 2020 21:45
by mickmack82
For what it's worth, i use this device for over a year without any problems. Rain rate and total amount of rain is updated as expected.
Re: Popp Z-rain
Posted: Monday 23 March 2020 22:11
by Abber
Thanks Mickmack! Now I dare to invest my €80
Since you are using it for more than a year now, how is the accuracy? Does it register little amounts of rain as well?
Re: Popp Z-rain
Posted: Tuesday 24 March 2020 6:57
by mickmack82
It reports the rainfall with 0.5mm accuracy. I never compared it to a official rain gauge though. But overall I am quite satisfied with this device.
For the problem above: try to refresh node info. Not only from the ozw panel but also from the domoticz hardware page. That did resolve some zwave errors with other zwave devices generating messages like this.
Re: Popp Z-rain
Posted: Tuesday 24 March 2020 21:40
by Abber
Ok thanks. I am going to order one.
Re: Popp Z-rain
Posted: Saturday 18 April 2020 17:53
by mickmack82
After the update to the 2020 version I also receive the error mentioned in the first post:
Unhandled value type ZDTYPE_SWITCH_NORMAL (2). Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: General Purpose, Instance: 1, Index: 2 (OpenZWave.cpp:3189)
However, rainrate and rainfall is updated as it should.
Any progress with this?
Re: Popp Z-rain
Posted: Wednesday 22 April 2020 19:11
by Kyrille
mickmack82 wrote: Saturday 18 April 2020 17:53
I just discovered this topic and I have exactly the same issue as you. I created a new ticket yesterday (
https://www.domoticz.com/forum/viewtopi ... 24&t=32312) and I am still investigating. Even if the device is still working fine, I now receive emails everyday (I want to be warned when Domoticz encounters an error, and it happens for each exchange between the controller and the z-rain).
Regards.
Re: Popp Z-rain
Posted: Friday 01 May 2020 20:44
by mickmack82
Did some more digging and found the following:
The section of code mentioned in the error (line 3188 in OpenZWave.cpp) handles the datatypes bool, byte, string and list.
if (vType == OpenZWave::ValueID::ValueType_Bool)
if (bValue == true)
intValue = 255;
intValue = 0;
else if (vType == OpenZWave::ValueID::ValueType_Byte)
if (byteValue == 0)
intValue = 0;
intValue = 255;
else if (vType == OpenZWave::ValueID::ValueType_String)
if (commandclass == COMMAND_CLASS_COLOR_CONTROL)
//New color value received, not handled yet
return;
else if (vType == OpenZWave::ValueID::ValueType_List)
//Color Index changed, not used
return;
_log.Log(LOG_ERROR, "OpenZWave: Value_Changed: Unhandled value type ZDTYPE_SWITCH_NORMAL (%d). Node: %d (0x%02x), CommandClass: %s, Label: %s, Instance: %d, Index: %d (%s:%d)", vType, NodeID, NodeID, cclassStr(commandclass), vLabel.c_str(), vID.GetInstance(), vID.GetIndex(), std::string(__MYFUNCTION__).substr(std::string(__MYFUNCTION__).find_last_of("/\\") + 1).c_str(), __LINE__);
return;
However the datatype defined in Config/popp/700168.xml, for index 1 is "short". All other indexes have datatype "byte".
<Value genre="config" index="1" instance="1" label="Rain Counter" max="32000" min="0" size="2" type="short" units="mm" value="0">
<Help>
Ths values shows the total count of rain from the moment of inclusion in mm water level. By writing this value this counter can be reset.
Default Value: 0
</Help>
</Value>
<Value genre="config" index="2" instance="1" label="Rain Start Command" max="99" min="0" size="1" type="byte" units="" value="99">
<Help>
This BASIC Set Command value is sent out into Association Group 2 when the device detects start of rain.
Default Value: 99
</Help>
</Value>
Could it be that index 1, which has "short" as a datatype is causing this error?
The error message mentions index 2, but that index has "byte" as datatype, so that should be ok.
Re: Popp Z-rain
Posted: Thursday 09 July 2020 18:01
by mickmack
This issue is fixed in the latest beta.
Verstuurd vanaf mijn Nokia 8.1 met Tapatalk
Re: Popp Z-rain
Posted: Wednesday 19 August 2020 20:35
by commentator
TheHoff wrote: Wednesday 01 January 2020 12:26
Greetings
/Fredrik
had one for a year, then it stopped working when it was raining 55mm/hour. It was complete wet inside the device
Re: Popp Z-rain
Posted: Saturday 10 October 2020 8:07
by Solderbro
Let's figure that out, i changes the term in the popp file to byte and will see what happens. Because this bug is the major annoying thing, you have to total disable the email alerts or it spam your inbox every 5 minutes with the popp error.
General question, can we download beta and extract only the bugged files for the stable?
Solderbro
