Evohome, setpoint for HR92
Bertvdw
Post by Bertvdw »
I control my evohome system through the HGi80.
This works correct.
I do have a question about the HR92.
Is it possible to change the setpoint if the HR92 is set to OFF on the device itselfs?
Greets Bert
Kid0
Re: Evohome, setpoint for HR92
Post by Kid0 »
Bertvdw wrote: Saturday 28 December 2019 16:13 I control my evohome system through the HGi80.
This works correct.
Greets Bert
If required, the 12 basic settings (parameters) can be adjusted. Factory settings have a grey background.
In order to change the parameters:
Keep the User-added image button pressed for approximately 5 seconds until Parameter 1 flashes (left-hand digit).
The right hand digit shows the current setting
The parameter is displayed additionally in plain text ; for example, the display 1 1 stands for Parameter 1 (language) with Setting 1 (English)
Use the adjustment dial to select the desired parameter (left-hand digit).
Press the User-added image button to edit the parameter.
The current setting of the parameter flashes (right-hand digit)
Use the adjustment dial to set the desired setting (right-hand digit) and confirm with User-added image.
For the further parameters repeat Steps 2 to 4.
To exit the menu, select "EXIT" using the adjustment dial and confirm with the User-added image button.
FILE 1
FILE 2
FILE 3
evohome
Thermostats
RELATED ARTICLES
Can the screen backlight be turned off on the HR92 Wireless Radiator Controller?
Number of Views 162
Can I have an explanation of the evohome WiFi System?
Number of Views 9.8K
The evohome controller and radiators are in 'off' setting but the boiler continues to fire
Number of Views 5.12K
Where can I find an installation guide for the WiFi evohome system?
Number of Views 3.55K
How to obtain an installation guide for the HR92UK Thermostatic Valve?
Number of Views 1.07K
TRENDING ARTICLES
Why is my Honeywell Home Wi-Fi device not connecting to the Internet?
What do the BDR91 LED indicators mean?
Why does the thermostat make a buzzing noise?
How to check the MAC and CRC on the T6 Smart Thermostats?
What should I do if I get a "System is offline" message on the T6/T6R Smart Thermostat?
