Somfy Blinds stop command Siri
Posted: Saturday 28 December 2019 11:04
by nitro
Hello All,
Hopefully you can help me out. I have installed a Somfy blind and that is working well with Domoticz (followed this topic: viewtopic.php?f=44&t=2567&hilit=somfy).
Also i have Domoticz connected to Homebrige (siri). It is now possible to say "Hey Siri open the blinds (In dutch then), and the blinds will open.
If I say "Hey Siri close the blinds, the blind will go down. The only thing that is not working is when I say "Hey Siri, open the blinds 50% or Hey Siri stop the blinds (when the blinds is halfway) or Hey Siri Pause the blinds".
In Domoticz I see 3 commands: On / Off / Stop. But the Stop function is not working with Siri.
The stop function is working when I click on the "Stop button".
I hope you have a sollution for this problem, else if I want to open the blinds for a little bit I need to use the Telis 1 remote control and press the "My" button.
thank you.
Best regards,
Nitro
Re: Somfy Blinds stop command Siri
Posted: Sunday 15 November 2020 2:35
by HvdW
Bump
Posted: Tuesday 17 November 2020 12:25
by erem
How did you connect Domoticz to Siri/apple home?
Homebridge with eDomotiz?
if homebridge, does homebridge show the stop button?
Posted: Tuesday 17 November 2020 12:57
by DewGew
Posted: Wednesday 18 November 2020 13:11
by erem
i have no experience with that add-in, but it seems to support the stop button, and positioning if you use the advanced config.
What config did you use?
Does the stop/position button show up in homebridge accessories at all?
it should work from homebridge before Siri can operate it correctly
we know it works from domoticz, so the next step in the chain to check is homebridge.
Posted: Wednesday 18 November 2020 17:19
by DewGew
If you use hombridge UI its simple.You just add domoticz json request for up/down/stop
http://localhost:8080/json.htm?type=command&param=switchlight&idx=123&switchcmd=On
http://localhost:8080/json.htm?type=command&param=switchlight&idx=123&switchcmd=Off
http://localhost:8080/json.htm?type=command&param=switchlight&idx=123&switchcmd=Stop
You can also add time, then it works lika e percentage blind.
my config for one of my blinds look like this:
"accessories": [
         "name": "Bedroom Blind",
         "up_url": "http://localhost:8080/json.htm?type=command&param=switchlight&idx=127&switchcmd=Off",
         "motion_up_time": 28000,
         "down_url": "http://localhost:8080/json.htm?type=command&param=switchlight&idx=127&switchcmd=On",
         "motion_down_time": 28000,
         "stop_url": "http://localhost:8080/json.htm?type=command&param=switchlight&idx=127&switchcmd=Stop",
         "show_stop_button": yes,
         "http_options": {
            "method": "GET"
         "accessory": "BlindsHTTP"
Posted: Monday 14 November 2022 19:59
by Hann1BaL
This topic is a good reference on how to make it work with the eDomoticz plugin in Homebridge
https://domoticz.com/forum/viewtopic.ph ... 73#p294473
