how to use seticon function?
Posted: Thursday 26 December 2019 21:48
by papoo
hello
i try to use this function in a script :
setIcon(iconNumber): Function. 2.4.17 method to update the icon for devices. Supports command options.
like this
device.switchOn().seticon(105)
but i have this error : attempt to call a nil value (field 'seticon')
i know how i can replace with a json request but i want to work in pure lua if is possible.
Re: how to use seticon function?
Posted: Thursday 26 December 2019 21:50
by waaren
papoo wrote: Thursday 26 December 2019 21:48
but i have this error attempt to call a nil value (field 'seticon')
the method is setIcon() -- case matters !
Posted: Thursday 26 December 2019 21:52
by papoo
i try it also
attempt to call a nil value (field 'setIcon')
I don't write the function correctly surely
Posted: Thursday 26 December 2019 22:43
by waaren
papoo wrote: Thursday 26 December 2019 21:52
Hard to tell without knowing what device is and without seeing the script...
How did you find the Icon number 105 ?
Posted: Thursday 26 December 2019 23:17
by papoo
i use custom icons. the first is 101, etc
like this
- 2019-12-15 20_32_57-Window.png (186.22 KiB) Viewed 2241 times
it work fine with this json request
dz.settings['Domoticz url'] .. '/json.htm?type=setused&used=true&name=' .. dz.utils.urlEncode(device.name) ..
'&description=' .. dz.utils.urlEncode(device.description) .. -- Required. If not set it will be blanked out.
'&idx=' .. device.id ..
'&switchtype=' .. device.switchTypeValue ..
'&customimage=' .. iconNumber
but i want to use the setIcon dzents function
like this
i try also
device.switchOn().setIcon(iconNumber)
my selector switch have 9 levels, level 0 not show
custom icon for level 10 to 80 :
[10] = 128,
[20] = 129,
[30] = 130,
[40] = 131,
[50] = 132,
[60] = 133,
[70] = 134,
[80] = 135,
Posted: Friday 27 December 2019 0:49
by waaren
papoo wrote: Thursday 26 December 2019 23:17
but i want to use the setIcon dzVents function
Can you please share the complete script, the relevant loglines, the device type and subtype and the content of <domoticz dir>/dzVents/runtime/device-adapters/generic_device.lua ?
That will help me finding the root cause of your problem. Thx
Re: how to use seticon function? [Solved]
Posted: Friday 27 December 2019 22:00
by papoo
I tested my script again to collect the info to answer you, and it works now.
Unfortunately,
I don't know what was wrong.
sorry for inconvenience, thanks.
please, can you tell me if there is a possibility to display the name of Custom icons and their number with dzvents or json?
Posted: Friday 27 December 2019 23:21
by waaren
papoo wrote: Friday 27 December 2019 22:00
Good to hear it is working now.
I don't know how to get the name of Custom icons. maybe if you add one or two an look in the database table CustomImages you can see a relation that make sense to you.
Posted: Saturday 28 December 2019 10:32
by papoo
thanks
