Auto Night Mode
Posted: Thursday 26 December 2019 20:40
by djdevil
Hi everyone I am looking for advice, I would like to create a script that when the presence switch is on and at a certain time like from 21:00 to 23:00 I check the latest update of my sensors and PIR and if after 20 minutes have not been updated automatically activated night mode! it's possible?
Thx
Re: Auto Night Mode
Posted: Thursday 26 December 2019 21:02
by waaren
djdevil wrote: Thursday 26 December 2019 20:40 I would like to create a script that when the presence switch is on and at a certain time like from 21:00 to 23:00 I check the latest update of my sensors and PIR and if after 20 minutes have not been updated automatically activated night mode!
Yes that would be possible but the approach to choose is depending on the dzVents version you are on. What is you domoticz / dzVents level ?
Re: Auto Night Mode
Posted: Thursday 26 December 2019 22:03
by djdevil
hello waaren thanks for the answer, I tried to write some code what do you think?
    on = { timer = {"every 1 minutes"}
	 local presenza = domoticz.devices('Presenza')
	 local ModalitaNotte = domoticz.devices('Modalità Notte')
	 local PIR1 = domoticz.devices('Sensore Corridoio')
	 local PIR2 = domoticz.devices('Sensore Living')
	 local Tramonto = domoticz.devices('Tramonto')
	   if  presenza.state == 'On' and ModalitaNotte.state == 'Off'and Tramonto.state == 'On' and PIR1.lastUpdate.secondsAgo > 300 and PIR2.lastUpdate.secondsAgo > 300 then
                if domoticz.time.matchesRule('at 21:30-01:00') then
	ModalitaNotte.switchOn()
Re: Auto Night Mode
Posted: Thursday 26 December 2019 23:51
by djdevil
waaren wrote: Thursday 26 December 2019 21:02
my code works, is the approach ok?
Re: Auto Night Mode
Posted: Thursday 26 December 2019 23:56
by waaren
djdevil wrote: Thursday 26 December 2019 22:03 hello waaren thanks for the answer, I tried to write some code what do you think?
Looks about OK to me. I would change one aspect because you don't need to run the scrip 24/7
return
    on =
        timer = { "at 21:30-01:00" },
        if presenza.state == 'On' and ModalitaNotte.state == 'Off' and Tramonto.state == 'On' and PIR1.lastUpdate.secondsAgo > 300 and PIR2.lastUpdate.secondsAgo > 300 then
Re: Auto Night Mode
Posted: Thursday 26 December 2019 23:59
by djdevil
waaren wrote: Thursday 26 December 2019 23:56
return
    on =
in this case using
timer = {"at 21: 30-01: 00"},
how often is the script triggered? do I always check every minute in this time slot?
Re: Auto Night Mode
Posted: Friday 27 December 2019 0:05
by djdevil
return
    on =
From Wiki
"It is important to know that Domoticz timer events only trigger once every minute, so one minute is the smallest interval for your timer scripts."
'at 12:45-21:15', -- between 12:45 and 21:15. You cannot use '*'!
Trigger every minute right?
Re: Auto Night Mode
Posted: Friday 27 December 2019 0:21
by waaren
djdevil wrote: Friday 27 December 2019 0:05 'at 12:45-21:15', -- between 12:45 and 21:15. You cannot use '*'!
'at 12:45-21:15', -- between 12:45 and 21:15. You cannot use '*'! [/qoute]
This means that the script will trigger every minute between 12:45 and 21:45 and that you cannot use wildcards here.
So for example 'at *:45-*:55' will not work
Re: Auto Night Mode  [Solved]
Posted: Friday 27 December 2019 0:28
by djdevil
Thank you for help ;)
