On/off switch report
forkboy
Post by forkboy »
An on/off switch does not have a report available through logs - reports.
I would like to have a report showing the time in a state. So for instance it will indicate that the switch was turned on for 1 hours, and 23 hours it was off for a day. Of course then totals per week, month et cetera
Egregius
Domoticz version: v2024.7
Re: On/off switch report
Post by Egregius »
Something like this?
Screenshot at dec. 24 07-16-37.png (136.46 KiB) Viewed 641 times
This shows the on/off times of the last 24 hours.
My log history is set to 1 day to keep the SQLite database as small as possible.
I also run a script every hour to remove records from not used devices and non-interest ones.
Still in 1 day there're already 3000 records. You want to keep that for years?
That'll be a huge growing table.
What I do besides this is pushing the switch times to a MySQL database for a few devices I want to monitor.
I do this since December 1st for 7 devices , the table already holds 3734 records.
forkboy
Post by forkboy »
Yes something like that. Yes history keeping might be a next thing, but I would only need the totals to be saved. So if I have a total for a day, and save that it would be good. This would mean 365 values per year for a single device.
How did you construct your output? I am guessing with your Pass2php script, but then?
forkboy
Post by forkboy »
I now managed this via a LUA script and virtual devices. The script is like this; in this case I did not use the switches as input but rather a state variable. Using switches would be somewhat similar.
function datetimedifferencenow(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
local function DeviceUpdateCounter(name, value1)
	local idx = otherdevices_idx[name]
	if Debug=='YES' then
		print('setting '..name..'; to value '..tostring(value1))
	local cmd = string.format("%d|%d|%d", idx, value1, value1)
  --print(cmd)
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
local function UpdateTimeCounter(name)
	local deltaSeconds = datetimedifferencenow(uservariables_lastupdate['WPTimestamp'])
	local deltaMinutes = deltaSeconds / 60
	local previousCount = otherdevices_svalues[name]
	-- print('previous count was ' .. previousCount)
	DeviceUpdateCounter(name, tonumber(previousCount) + deltaMinutes)
-- WP State: 0=init,1=uit,2=CV,3=boiler,4=vrijkoel,5=ontluchten
Debug = 'YES'
local hour = tonumber(os.date("%H"))
local minute = tonumber(os.date("%M"))
if ((minute % 3) == 0) then
	local wpState = otherdevices['WP State']
	if wpState=='1' then
		UpdateTimeCounter('WP Standby Tijd')
	elseif wpState=='2' then
		UpdateTimeCounter('WP CV Tijd Actief')
	elseif wpState=='3' then
		UpdateTimeCounter('WP Boiler Tijd Actief')
	elseif wpState=='4' then
		UpdateTimeCounter('WP Koel Tijd Actief')
	commandArray['Variable:WPTimestamp']=tostring(os.date("%H:%M"))
