RFLink and sudden range drop
Posted: Monday 23 December 2019 9:07
I know this is probably not directly linked to Domoticz but as there are probably many people here using RFLink with Domoticz I thought I'd ask if there are any who have experienced what I just did. And if you have, did you find some root cause or good troubleshooting methods.
My issue was that RFLink (latest official firmware) has been working very stable and it has a good range with external antenna. But suddenly on last Saturday evening it first looked liked it had stopped working - although a bit later I concluded that just the range had dramatically dropped. I wasn't even at home at that time so I first really noticed it on Sunday morning when my Nexa swtiches didn't work. A couple of them, closer to the RFLink's antenna still worked. I then checked 433Mhz thermometers and they had stopped updating on Saturday evening around 10PM.
I then stopped the RFLink hardware and restarted, then rebooted the Raspberry Pi to which it is connected, and finally tested also with another antenna and different antenna positioning. All this had no or little effect on the range. At this point I started thinking it has just died as it is few years old already. I was away from home most of the remaining day and to my surprise when I came back it was again working as it used to.
But now I'm left puzzled that what just happened. Why the range dropped, why it came back? If this happens again, is there something I can do to fix it quicker?
Thanks in advance for any insights you might have on this...
