Installing Domoticz on an existing configuration
MrJown
Post by MrJown »
I have a Raspberry PI 3 B+ with Raspbian Lite.
On it I have apache2, PHP, MariaDB to manage 2 or 3 hosts :
blog.example.com
house.example.com
I want to add Domoticz on this actual configuration but I'm scared to destroy all if I launch the command :
curl -L https://install.domoticz.com | bash
Thanks for your help !
Nathan.
Re: Installing Domoticz on an existing configuration
MrJown wrote: Friday 20 December 2019 11:40 On it I have apache2, PHP, MariaDB to manage 2 or 3 hosts :
domoticz can live happily alongside these packages. If you don't trust it make sure you have a recent backup before installing.
MrJown
Post by MrJown »
Thanks for your reply.
When I launch the command to install Domoticz,
it will be use the port 443 to access to the interface in HTTPS.
But the 443 port is already used.
There will be a conflict with my others hosts ?
Nathan.
MrJown wrote: Friday 20 December 2019 12:04 When I launch the command to install Domoticz, it will be use the port 443 to access to the interface in HTTPS.
The default ports (8080 and 443) can be changed during the installation conversation. Just type new port numbers when asked to confirm the defaults.
MrJown
Post by MrJown »
Ok thanks for your help.
I will post here when the installation is finished :)
Nathan.
MrJown
Post by MrJown »
Everything worked fine !
Thank you for your tip :)
Nathan.
