random on / random duration
mash47
Domoticz version: v4.10717
Post by mash47 »
dzVents allows randomised switch times using withinMin(minutes) etc but I've been unable to find anything in dzVents for a randomised duration. Here's the code to operate a switch with random on times and random duration ...
	    timer = {'every 30 minutes'}
	execute = function(dz)
	    local n = tostring(math.random(5, 15))
	    if( dz.time.matchesRule('between sunset and 23:00') ) then
	        dz.devices(15).switchOn().withinMin(15).forMin(n)
imdos
Domoticz version: 2023.2
Re: random on / random duration
Post by imdos »
Well; as you have already found. The randomised duration is within! There is: withinMin(minutes); this enables to switch off or on within a random time.
But I guess it might influence too much with your current idea.
If you have:
dz.devices(15).switchOff().withinMin(15)
This might already switch off the light before the switch on.
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
mash47
Post by mash47 »
imdos wrote: Thursday 19 December 2019 11:38 If you have:
Yes I agree, that is why I used the math.random(n, m) function to ensure that the randomised duration was applied after the switch had been turned on. It also has the advantage of being able to specify a minimum duration.
