[SOLVED] Shutters and sensors don't show up on Dashticz screen Topic is solved
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Hi All,
I am trying to create a simple Dashticz dashboard. Nothing fancy, I just want to be able to re-order the devices which I can do with theming.
I have got my light switches and dimmers working and I also managed (somewhat) to show the output of my new smart meter in graph form. ;)
But I can't get the the shutters and sensors to show up on the dashboard. It is probably stupidly simple but I can't see what I am doing wrong. So if one you more experienced Dashticz users can shed a light I would be most grateful.
The contents of my CONFIG.js (I haven't modified the custom.css):
var config = {}
config['domoticz_ip'] = 'http://xxx.xxx.xxx.xxx:2080';
config['login_timeout'] = '60';
config['user_name'] = 0;
config['pass_word'] = 0;
config['app_title'] = '@Home';
config['room_plan'] = 0;
config['default_news_url'] = 'https://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = 0;
config['standby_call_url_on_end'] = 0;
config['theme'] = 'default';
config['background_image'] = 'img/bg14.jpg';
config['standby_after'] = 0;
config['start_page'] = 1;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['speak_lang'] = 'en-US';
config['wu_api'] = 'xxxxx';
config['wu_city'] = 'xxxxx';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['owm_api'] = 0;
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = 0;
config['owm_country'] = 'de';
config['owm_lang'] = 0;
config['owm_cnt'] = '4';
config['idx_moonpicture'] = 0;
config['longfonds_zipcode'] = 0;
config['longfonds_housenumber'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['disable_googleanalytics'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
// Screen definitions
var max_resolution_desktop    = 'default';
var max_resolution_smart      = 'tablet';
// Title Definitions
var title_lampen          = 'title_lampen';
var title_dimmers         = 'title_dimmers';
var title_vochtsensors    = 'title_vochtsensors';
var title_ventilator1     = 'title_ventilator1';
var title_rookmelders     = 'title_rookmelders';
var title_gas_en_elektra  = 'title_gas_en_elektra';
var title_luikensets      = 'title_luikensets';
var title_luiken          = 'title_luiken';
var title_datum_tijd      = 'title_datum_tijd'
var title_weer            = 'title_weer';
var title_klimaatsensoren = 'title_klimaatsensoren';
var title_deurbel         = 'title_deurbel';
var title_raspberry       = 'title_raspberry';
// IDX Definitions
// Verlichting
var ventilator_lamp            = 47;
var simon_levelt               = 59;
var wandbord                   = 60;
var cd_rek                     = 61;
var eettafel                   = 62;
var plafondspot_tv             = 64;
var secretaire                 = 65;
var buffetkast                 = 66;
var dressoir                   = 73;
var traplicht                  = 75;
var plafondspot_haard          = 76;
var hobby_hedwig               = 78;
var hobby_algemeen             = 79;
var slaapkamer_bed             = 82;
var slaapkamer_plafond         = 83;
var hobby_jan                  = 85;
var theaterspot                = 86;
var mondriaan_tv               = 107;
var mondriaan_dressoir         = 108;
// Luiken
var luik_keuken                = 63;
var luik_dressoir              = 67;
var luik_haard                 = 68;
var luik_kop_tuin              = 69;
var luik_tuindeur              = 70;
var luik_tuinraam              = 71;
var luik_secretaire            = 72;
var luik_eettafel              = 77;
var luik_hobby_waterzijde      = 80;
var luik_hobby_kop             = 81;
// Luikensets (Scenes)
var luiken_waterzijde          = 1;
var luiken_tuinzijde           = 2;
var luiken_hobby               = 3;
// Weer
var tuinvilla_buiten           = 89;
var schuur                     = 90;
var tuinvilla                  = 91;
var kelder_achter              = 92;
var regen                      = 111;
var grafiek_regen              = 'graph_111';
// Sensoren
var vochtsensor_ontvochtiger   = 100;
var vochtsensor_cv_ketel       = 101;
var vochtsensor_wasmachine     = 102;
var vochtsensor_waterontharder = 103;
var rookmelder_woonkamer       = 97;
var rookmelder_gang            = 98;
var rookmelder_slaapkamer      = 99;
// Gas en elektra
var elektra                    = 112;
var gas                        = 113;
var elektra_nu                 = '112_1';
var elektra_vandaag            = '112_2';
var elektra_totaal             = '112_3';
var grafiek_gas                = 'graph_113';
var grafiek_elektra            = 'graph_112';
// Deurbel
var deurbel                    = 104;
// Ventilator
var ventilator1_stand_0         = 48;
var ventilator1_stand_1         = 49;
var ventilator1_stand_2         = 50;
var ventilator1_stand_3         = 51;
// Buttons
var buttons = {}
// Buttons - Nieuws sites
buttons.nunl = { key: 'nunl',  width:6, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl',  image:'img/NU.nl.png' }
buttons.nos  = { key: 'nos',   width:6, icon: 'fa-newspaper-o', title: 'Nos',   url: 'http://www.nos.nl', image:'img/NOS.png'   }
// Buttons Buienradar
buttons.buienradar = {width:3, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=100&h=85', url: 'https://www.accuweather.com/en/nl/xxxxx/250615/weather-forecast/250615'}
// Blocks
var blocks = {}
// Title: Lampen
blocks[title_lampen] = {}
blocks[title_lampen]['type'] = 'blocktitle'
blocks[title_lampen]['title'] = 'Lampen'
// Lampen - Simon Lévelt
blocks[simon_levelt] = {}
blocks[simon_levelt]['title'] = 'Simon Lévelt';
blocks[simon_levelt]['width'] = 3;
blocks[simon_levelt]['hide_data'] = true;
// Lampen - Wandbord
blocks[wandbord] = {}
blocks[wandbord]['title'] = 'Wandbord';
blocks[wandbord]['width'] = 3;
blocks[wandbord]['hide_data'] = true;
// Lampen - CD Rek
blocks[cd_rek] = {}
blocks[cd_rek]['title'] = 'CD Rek';
blocks[cd_rek]['width'] = 3;
blocks[cd_rek]['hide_data'] = true;
// Lampen - Secretaire
blocks[secretaire] = {}
blocks[secretaire]['title'] = 'Secretaire';
blocks[secretaire]['width'] = 3;
blocks[secretaire]['hide_data'] = true;
// Lampen - Buffetkast
blocks[buffetkast] = {}
blocks[buffetkast]['title'] = 'Buffetkast';
blocks[buffetkast]['width'] = 3;
blocks[buffetkast]['hide_data'] = true;
// Lampen - Dressoir
blocks[dressoir] = {}
blocks[dressoir]['title'] = 'Dressoir';
blocks[dressoir]['width'] = 3;
blocks[dressoir]['hide_data'] = true;
// Lampen - Theaterspot
blocks[theaterspot] = {}
blocks[theaterspot]['title'] = 'Theaterspot';
blocks[theaterspot]['width'] = 3;
blocks[theaterspot]['hide_data'] = true;
// Lampen - Mondriaan TV
blocks[mondriaan_tv] = {}
blocks[mondriaan_tv]['title'] = 'Mondriaan TV';
blocks[mondriaan_tv]['width'] = 3;
blocks[mondriaan_tv]['hide_data'] = true;
// Lampen - Mondriaan Dressoir
blocks[mondriaan_dressoir] = {}
blocks[mondriaan_dressoir]['title'] = 'Mondriaan Dressoir';
blocks[mondriaan_dressoir]['width'] = 3;
blocks[mondriaan_dressoir]['hide_data'] = true;
// Lampen - Hobby Jan
blocks[hobby_jan] = {}
blocks[hobby_jan]['title'] = 'Hobby Me';
blocks[hobby_jan]['width'] = 3;
blocks[hobby_jan]['hide_data'] = true;
// Lampen - Hobby Hedwig
blocks[hobby_hedwig] = {}
blocks[hobby_hedwig]['title'] = 'Hobby She';
blocks[hobby_hedwig]['width'] = 3;
blocks[hobby_hedwig]['hide_data'] = true;
// Lampen - Hobby Algemeen
blocks[hobby_algemeen] = {}
blocks[hobby_algemeen]['title'] = 'Hobby Algemeen';
blocks[hobby_algemeen]['width'] = 3;
blocks[hobby_algemeen]['hide_data'] = true;
// Lampen - Traplicht
blocks[traplicht] = {}
blocks[traplicht]['title'] = 'Traplicht';
blocks[traplicht]['width'] = 3;
blocks[traplicht]['hide_data'] = true;
// Title Dimmers
blocks[title_dimmers] = {}
blocks[title_dimmers]['type'] = 'blocktitle'
blocks[title_dimmers]['title'] = 'Dimmers'
// Dimmers - Eettafel
blocks[eettafel] = {}
blocks[eettafel]['title'] = 'Eettafel';
blocks[eettafel]['width'] = 12;
blocks[eettafel]['hide_data'] = true;
// Dimmers - Plafondspots TV
blocks[plafondspot_tv] = {}
blocks[plafondspot_tv]['title'] = 'Plafondspots TV';
blocks[plafondspot_tv]['width'] = 12;
blocks[plafondspot_tv]['hide_data'] = true;
// Dimmers - Plafondspot Haard Dimmer
blocks[plafondspot_haard] = {}
blocks[plafondspot_haard]['title'] = 'Plafondspots Haard';
blocks[plafondspot_haard]['width'] = 12;
blocks[plafondspot_haard]['hide_data'] = true;
// Title Vochtsensors
blocks[title_vochtsensors] = {}
blocks[title_vochtsensors]['type'] = 'blocktitle'
blocks[title_vochtsensors]['title'] = 'Vochtsensors'
// Vochtsensors - Ontvochtiger
blocks[vochtsensor_ontvochtiger] = {};
blocks[vochtsensor_ontvochtiger]['title'] = 'Ontvochtiger';
blocks[vochtsensor_ontvochtiger]['width'] = 3;
blocks[vochtsensor_ontvochtiger]['icon'] = 'fa fa-water';
blocks[vochtsensor_ontvochtiger]['protected'] = true;
blocks[vochtsensor_ontvochtiger]['hide_data'] = true;
// Vochtsensors - CV ketel
blocks[vochtsensor_cv_ketel] = {};
blocks[vochtsensor_cv_ketel]['title'] = 'CV ketel';
blocks[vochtsensor_cv_ketel]['width'] = 3;
blocks[vochtsensor_cv_ketel]['icon'] = 'fa fa-water';
blocks[vochtsensor_cv_ketel]['protected'] = true;
blocks[vochtsensor_cv_ketel]['hide_data'] = true;
// Vochtsensors - Wasmachine
blocks[vochtsensor_wasmachine] = {};
blocks[vochtsensor_wasmachine]['title'] = 'CV ketel';
blocks[vochtsensor_wasmachine]['width'] = 3;
blocks[vochtsensor_wasmachine]['icon'] = 'fa fa-water';
blocks[vochtsensor_wasmachine]['protected'] = true;
blocks[vochtsensor_wasmachine]['hide_data'] = true;
// Vochtsensors - Waterontharder
blocks[vochtsensor_waterontharder] = {};
blocks[vochtsensor_waterontharder]['title'] = 'CV ketel';
blocks[vochtsensor_waterontharder]['width'] = 3;
blocks[vochtsensor_waterontharder]['icon'] = 'fa fa-water';
blocks[vochtsensor_waterontharder]['protected'] = true;
blocks[vochtsensor_waterontharder]['hide_data'] = true;
// Title Ventilator1
blocks[title_ventilator1] = {}
blocks[title_ventilator1]['type'] = 'blocktitle'
blocks[title_ventilator1]['title'] = 'Ventilator 1'
// Title rookmelders
blocks[title_rookmelders] = {}
blocks[title_rookmelders]['type'] = 'blocktitle'
blocks[title_rookmelders]['title'] = 'Rookmelders'
// Rookmelder Woonkamer
blocks[rookmelder_woonkamer] = {};
blocks[rookmelder_woonkamer]['title'] = 'Woonkamer';
blocks[rookmelder_woonkamer]['width'] = 4;
blocks[rookmelder_woonkamer]['switch'] = true;
blocks[rookmelder_woonkamer]['icon'] = 'fa fa-fire';
blocks[rookmelder_woonkamer]['protected'] = true;
blocks[rookmelder_woonkamer]['hide_data'] = true;
// Rookmelder Gang
blocks[rookmelder_gang] = {};
blocks[rookmelder_gang]['title'] = 'Gang';
blocks[rookmelder_gang]['width'] = 4;
blocks[rookmelder_gang]['icon'] = 'fa fa-fire';
blocks[rookmelder_gang]['protected'] = true;
blocks[rookmelder_gang]['hide_data'] = true;
// Rookmelder Slaapkamer
blocks[rookmelder_slaapkamer] = {};
blocks[rookmelder_slaapkamer]['title'] = 'Slaapkamer';
blocks[rookmelder_slaapkamer]['width'] = 4;
blocks[rookmelder_slaapkamer]['icon'] = 'fa fa-fire';
blocks[rookmelder_slaapkamer]['protected'] = true;
blocks[rookmelder_slaapkamer]['hide_data'] = true;
// Title Gas en Elektra
blocks[title_gas_en_elektra] = {}
blocks[title_gas_en_elektra]['type'] = 'blocktitle'
blocks[title_gas_en_elektra]['title'] = 'Gas en Elektra'
blocks[elektra_nu] = {}
blocks[elektra_nu]['width'] = 4;
blocks[elektra_nu]['show_lastupdate'] = false;
blocks[elektra_nu]['protected'] = true;
blocks[elektra_vandaag] = {}
blocks[elektra_vandaag]['width'] = 4;
blocks[elektra_vandaag]['show_lastupdate'] = false;
blocks[elektra_vandaag]['protected'] = true;
blocks[elektra_totaal] = {}
blocks[elektra_totaal]['width'] = 4;
blocks[elektra_totaal]['show_lastupdate'] = false;
blocks[elektra_totaal]['protected'] = true;
blocks[gas] = {}
blocks[gas]['width'] = 4;
blocks[gas]['show_lastupdate'] = false;
blocks[gas]['protected'] = true;
blocks[grafiek_elektra] = {}
blocks[grafiek_elektra]['title'] = 'Elektriciteit';
blocks[grafiek_elektra]['width'] = 12;
//blocks[p1_grafiek_elektra]['graph'] = 'bar';
//blocks[p1_grafiek_elektra]['pointFillColors'] = ['#aaa9a9', '#7e7e7e'];
//blocks[p1_grafiek_elektra]['pointSize'] = 3;
//blocks[p1_grafiek_elektra]['lineColors'] = ['#aaa9a9', '#7e7e7e'];
blocks[grafiek_gas] = {}
blocks[grafiek_gas]['title'] = 'Gas';
blocks[grafiek_gas]['width'] = 12;
//blocks[p1_grafiek_gas]['graph'] = 'bar';
//blocks[p1_grafiek_gas]['pointFillColors'] = ['#aaa9a9', '#7e7e7e'];
//blocks[p1_grafiek_gas]['pointSize'] = 3;
//blocks[p1_grafiek_gas]['lineColors'] = ['#aaa9a9', '#7e7e7e'];
// Title Luikensets
blocks[title_luikensets] = {}
blocks[title_luikensets]['type'] = 'blocktitle'
blocks[title_luikensets]['title'] = 'Luikensets'
// Luikenset - Waterzijde
blocks[luiken_waterzijde] = {}
blocks[luiken_waterzijde]['title'] = 'Luiken waterzijde';
blocks[luiken_waterzijde]['width'] = 4;
//blocks[luiken_waterzijde]['icon'] = 'blinds-open blinds-closed';
blocks[luiken_waterzijde]['hide_data'] = true;
// Luikenset - Tuinzijde
blocks[luiken_tuinzijde] = {}
blocks[luiken_tuinzijde]['title'] = 'Luiken tuinzijde';
blocks[luiken_tuinzijde]['width'] = 4;
//blocks[luiken_tuinzijde]['icon'] = 'blinds-open blinds-closed';
blocks[luiken_tuinzijde]['hide_data'] = true;
// Luikenset - Hobby
blocks[luiken_hobby] = {}
blocks[luiken_hobby]['title'] = 'Luiken hobby';
blocks[luiken_hobby]['width'] = 4;
//blocks[luiken_hobby]['icon'] = 'blinds-open blinds-closed';
blocks[luiken_hobby]['hide_data'] = true;
// Title Luiken
blocks[title_luiken] = {}
blocks[title_luiken]['type'] = 'blocktitle'
blocks[title_luiken]['title'] = 'Luiken'
// Luiken - Secretaire
blocks[luik_secretaire] = {}
blocks[luik_secretaire]['width'] = 3;
//blocks[luik_secretaire]['icon'] = 'blinds_open blinds_closed';
// Luiken - Eettafel
blocks[luik_eettafel] = {}
blocks[luik_eettafel]['width'] = 3;
//blocks[luik_eettafel]['icon'] = 'blinds_open blinds_closed';
// Luiken - Tuin Raam
blocks[luik_tuinraam] = {}
blocks[luik_tuinraam]['width'] = 3;
//blocks[luik_tuinraam]['icon'] = 'blinds_open blinds_closed';
// Luiken - Tuin Deur
blocks[luik_tuindeur] = {}
blocks[luik_tuindeur]['width'] = 3;
blocks[luik_tuindeur]['icon'] = 'blinds_open blinds_closed';
// Luiken - Kop Tuin
blocks[luik_kop_tuin] = {}
blocks[luik_kop_tuin]['width'] = 3;
blocks[luik_kop_tuin]['icon'] = 'blinds_open blinds_closed';
// Luiken - Haard
blocks[luik_haard] = {}
blocks[luik_haard]['width'] = 3;
blocks[luik_haard]['icon'] = 'blinds_open blinds_closed';
// Luiken - Dressoir
blocks[luik_dressoir] = {}
blocks[luik_dressoir]['width'] = 3;
blocks[luik_dressoir]['icon'] = 'blinds_open blinds_closed';
// Luiken - Keuken
blocks[luik_keuken] = {}
blocks[luik_keuken]['width'] = 3;
blocks[luik_keuken]['icon'] = 'blinds_open blinds_closed';
// Luiken - Hobby Waterzijde
blocks[luik_hobby_waterzijde] = {}
blocks[luik_hobby_waterzijde]['width'] = 3;
blocks[luik_hobby_waterzijde]['icon'] = 'blinds_open blinds_closed';
// Luiken - Hobby Kop
blocks[luik_hobby_kop] = {}
blocks[luik_hobby_kop]['width'] = 3;
blocks[luik_hobby_kop]['icon'] = 'blinds_open blinds_closed';
// Title Datum & Tijd
blocks[title_datum_tijd] = {}
blocks[title_datum_tijd]['type'] = 'blocktitle'
blocks[title_datum_tijd]['title'] = 'Datum & Tijd'
// Title Weer
blocks[title_weer] = {}
blocks[title_weer]['type'] = 'blocktitle'
blocks[title_weer]['title'] = 'Weer'
// Title Klimaatsensoren
blocks[title_klimaatsensoren] = {}
blocks[title_klimaatsensoren]['type'] = 'blocktitle'
blocks[title_klimaatsensoren]['title'] = 'Klimaatsensors'
//regen, tuinvilla_buiten, tuinvilla, schuur, kelder_achter
blocks[regen] = {}
blocks[regen]['width'] = 12;
//blocks[regen]['show_lastupdate'] = false;
//blocks[regen]['protected'] = true;
blocks[tuinvilla_buiten] = {}
blocks[tuinvilla_buiten]['width'] = 6;
//blocks[tuinvilla_buiten]['show_lastupdate'] = false;
//blocks[tuinvilla_buiten]['protected'] = true;
blocks[tuinvilla] = {}
blocks[tuinvilla]['width'] = 6;
//blocks[tuinvilla]['show_lastupdate'] = false;
//blocks[tuinvilla]['protected'] = true;
blocks[schuur] = {}
blocks[schuur]['width'] = 6;
//blocks[schuur]['show_lastupdate'] = false;
//blocks[schuur]['protected'] = true;
blocks[kelder_achter] = {}
blocks[kelder_achter]['width'] = 6;
//blocks[kelder_achter]['show_lastupdate'] = false;
//blocks[kelder_achter]['protected'] = true;
// Title Deurbel
blocks[title_deurbel] = {}
blocks[title_deurbel]['type'] = 'blocktitle'
blocks[title_deurbel]['title'] = 'Deurbel'
blocks[deurbel] = {}
blocks[deurbel]['width'] = 12;
// Title Raspberry
blocks[title_raspberry] = {}
blocks[title_raspberry]['type'] = 'blocktitle'
blocks[title_raspberry]['title'] = 'RPi3'
// Columns
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [title_lampen, simon_levelt, wandbord, cd_rek, theaterspot, title_dimmers, eettafel, plafondspot_tv, plafondspot_haard, title_luikensets, luiken_tuinzijde, luiken_waterzijde, luiken_hobby, title_luiken, luik_secretaire, luik_eettafel, luik_tuinraam, luik_tuindeur, luik_kop_tuin, luik_haard, luik_dressoir, luik_keuken, luik_hobby_waterzijde, luik_hobby_kop]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [title_gas_en_elektra, grafiek_elektra, elektra_nu, elektra_vandaag, elektra_totaal, grafiek_gas, gas, title_vochtsensors, vochtsensor_ontvochtiger, vochtsensor_cv_ketel, vochtsensor_waterontharder, vochtsensor_wasmachine, title_rookmelders, rookmelder_woonkamer, rookmelder_gang, rookmelder_slaapkamer]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [title_weer, buttons.buienradar, buttons.nunl, buttons.nos, title_klimaatsensoren, regen, tuinvilla_buiten, tuinvilla, schuur, kelder_achter, title_deurbel, title_raspberry]
columns[3]['width'] = 3;
// columns[4] = {}
// columns[4]['blocks'] = [ (maak hier een titel overige schakelaars)
// Screens
var screens = {}
screens[max_resolution_desktop] = {}
screens[max_resolution_desktop]['maxwidth'] = 1920;
screens[max_resolution_desktop]['maxheight'] = 1200;
screens[max_resolution_desktop][1] = {}
screens[max_resolution_desktop][1]['background'] = 'bg14_lightgray.jpg';
screens[max_resolution_desktop][1]['columns'] = [1,2,3]
//screens[max_resolution_desktop][2] = {}
//screens[max_resolution_desktop][2]['background'] = 'bg14_lightgray.jpg';
//screens[max_resolution_desktop][2]['columns'] = [4,5,6,7]
//screens[max_resolution_desktop][3] = {}
//screens[max_resolution_desktop][3]['background'] = 'bg14_lightgray.jpg';
//screens[max_resolution_desktop][3]['columns'] = [8,9,10]
screens[max_resolution_smart] = {}
screens[max_resolution_smart]['maxwidth'] = 1440;
screens[max_resolution_smart]['maxheight'] = 900;
screens[max_resolution_smart][1] = {}
screens[max_resolution_smart][1]['background'] = 'bg14_lightgray.jpg';
screens[max_resolution_smart][1]['columns'] = [1,2,3]
//screens[max_resolution_smart][2] = {}
//screens[max_resolution_smart][2]['background'] = 'bg14_lightgray.jpg';
//screens[max_resolution_smart][2]['columns'] = [4,5,6,7]
//screens[max_resolution_smart][3] = {}
//screens[max_resolution_smart][3]['background'] = 'bg14_lightgray.jpg';
//screens[max_resolution_smart][3]['columns'] = [8,9,10]
Hope you can help!
Greetz,
Sjonnie
Last edited by Sjonnie2017 on Thursday 19 December 2019 18:40, edited 1 time in total.
YouLess Energy meter
Lokonli
Re: Shutters and sensors don't show up on Dashticz screen
Post by Lokonli »
Try with:
config['use_favorites'] = 0
Sjonnie2017
Tx! That was the magic ingredient ;)
Now up for some polishing and re-arranging and then I am a happy camper :)
Greetz,
Sjonnie
