logging heat demand in Evohome: no relays
Posted: Monday 16 December 2019 17:29
I think I asked this question before, but I still haven't an answer.
At the end of 2018 I was using domoticz v4.9700. Until then all went fine. I added the HGI80 via USB and all the devices would show up after a little time.
The components I'm using are the Evohome controller, DTS92 temperature sensors/thermostats (they give their information to the Evohome controller) and the HCE80 wich controls the underfloor heating. For every room I saw the temperature and the relays showing the heat demand. For the HCE80 I could also a relay for the pump. That was just what I want: I could log the behaviour of the Evohome system (when it asked for heat, when it started the pump etc...).
Now I have the latest beta version (but the same problem is with the stable version 4.10717) and now I don't see the relays anymore. Now after a year I gues why. In version v4.9700 there was no field for the controller id by installing the HGI80 hardware. In all the later versions there is a field for the controller id. Although the manual says it is optional, it is not. If I leave this field blank then no devices show up at all. If i enter the id for the Evohome controller then the temperature devices show up but, and that is the problem, not the relay switches. I lived with that for a year.
Suddenly I thought: mayby I should make a second hardware device for the HGI80 and fill in the id for he living room DTS92. Yes, this does work. Now I see the relay. But is that the right way? How should new users do that? I luckily had an old print screen where I could see the ID number for all the relays I saw before, but there is no way to get this normally. I added different hardware devices for every old room I used to log. Ok, for me, this is a workaroud, but I still can't get the relay back for the pump of the underfloor heating. I know the former ID (85ce9) and that is had the unit number 252 but when I make another hardware device for this id, the initial Evohome hardware device (with the id of the evohome controller) stops working...
It is a long story, but I'm still not satisfied. What am I doing wrong? Maybe there can be a repair that the field controller id is really optional as it used to be when there was no field at all....
I hope someone can help.
Hans
Hans
