Issue with ZMNHDDx
Posted: Friday 13 December 2019 8:28
by hestia
when I include a Qubino Flush Dimmer+ZMNHDDx and after do Add device there Domoticz crashes
Product type: Flush Dimmer
SN: 19119A1DD03C
P/N: ZMNHDD1 H1S4P5
domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (exited) since Fri 2019-12-13 07:45:11 CET; 23min ago
Docs: man:systemd-sysv-generator(8)
Process: 5635 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUC
Process: 5645 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/S
Dec 13 08:07:45 hestia domoticz[5652]: OpenZWave: Received timeout notification
Dec 13 08:07:52 hestia domoticz[5652]: OpenZWave: Received timeout notification
Dec 13 08:07:55 hestia domoticz[5652]: OpenZWave: Received timeout notification
Dec 13 08:08:07 hestia domoticz[5652]: OpenZWave: Received timeout notification
Dec 13 08:08:15 hestia domoticz[5652]: OpenZWave: Received timeout notification
Dec 13 08:08:28 hestia domoticz[5652]: EventSystem: reset all device statuses...
Dec 13 08:08:34 hestia domoticz[5652]: User: pascal initiated a switch command (
Dec 13 08:08:34 hestia domoticz[5652]: Domoticz(pid:5652, tid:5661('WebServer_80
Dec 13 08:08:34 hestia domoticz[5652]: siginfo address=0x1614, address=(nil)
Dec 13 08:08:38 hestia domoticz[5652]: Thread 7 (Thread 0x73478440 (LWP 5661)):
After restart the device doesn't work properly
When I turn it off with the GUI, the widget go again to "On"
When I use the switch, the state is not refreshed in Domoticz
Version: 4.11563
Build Hash: d5e8a14bf
Compile Date: 2019-12-09 20:21:24
I known there are some works on Domoticz regarding z-wave, but I see no progress on this device.
I've contacted Qubino support with no clues for me to get it work
"The gateway configures a multi channel lifeline association, using MULTI_CHANNEL_ASSOCIATION_SET(groupId=1, multichannelnodeId=1, endpoint=1). The gateway should have configured an ordinary lifeline association, using ASSOCIATION_SET(groupId=1, nodeId=1)."
The node in Group 1 was empty, I put 1 and there is 1.1
Re: Issue with ZMNHDDx
Posted: Friday 13 December 2019 9:02
by Egregius
I guess the most important part is your lifeline. That should be linked to 1.
I have 5 of those dimmers in the house. They work as expected, except some minor glitches.
2 sometimes report 100% level while they're actually at 30%.
1 has a glitch that after domoticz is restarted it reports 100%, after switch off it reports 12% and after a second switch off it works good.
Posted: Friday 13 December 2019 13:59
by hestia
Egregius wrote: Friday 13 December 2019 9:02 I have 5 of those dimmers in the house. They work as expected, except some minor glitches.
Thanks for the answer
Do you have the same HW version: P/N: ZMNHDD1 H1S4P5 ?
Posted: Friday 13 December 2019 15:10
by Egregius
I have no clue at all. The last 2 are about 4 months old.
I guess I could only see it on the switch, I don’t have the intention of opening them to see.
Posted: Sunday 29 December 2019 19:10
by hestia
Resolved in this topic viewtopic.php?f=24&t=29715
