Detailed NTP Server Monitoring script for Monit / MMonit
All kinds of 'OS' scripts
ben53252642
Post by ben53252642 »
This is a script I wrote for detailed monitoring of an NTP server (ntpd) via Monit / MMonit:
Checks:
1) If NTP server is synchronised or unsynchronised
2) If NTP server is synchronised to an acceptable time level in ms
Below is an image showing example output into mmonit for status coming from the NTP server via the bash script:
ntpsync.sh
#!/bin/bash
# Configuration
timeaccuracy="200" # Level of accuracy in ms before alert
# Get output
output=$(/usr/bin/ntpstat)
outputrawms=$(echo "$output" | grep -Eo '\w+ ms' | awk '{ print $1 }')
# If NTP server is unsynchronised exit and display error
if [[ $output == *"unsynchronised"* ]]; then
  echo "$output"
  exit 1
fi
# If NTP server is synchronised within acceptable ms display data and exit
if (( $outputrawms < "$timeaccuracy" )); then
  echo "$output"
  exit 0
fi
# If NTP server is synchronised output acceptable ms display message and exit
if (( $outputrawms >= "$timeaccuracy" )); then
  echo -e "Time accuracy is outside acceptable range of less than $timeaccuracy ms, output:\n$output" >&2
  exit 1
fi
Here is the section that goes in /etc/monit/monitrc:
# Check if NTP is synchronised
check program ntp_synchronisation with path "/etc/monit/customscripts/ntpsync.sh"
 with timeout 5 seconds
 if status != 0 then alert
Re: Detailed NTP Server Monitoring script for Monit / MMonit
Nice one. Thx
marmachine
Domoticz version: 3.4834
Post by marmachine »
Nice, but needs some work...
Last output:
/etc/monit/ntpsync.sh: regel 7: /usr/bin/ntpstat: Bestand of map bestaat niet
/etc/monit/ntpsync.sh: regel 17: ((: < 200 : syntaxfout: operator verwacht (het onjuiste symbool is "< 200 ")
/etc/monit/ntpsync.sh: regel 23: ((: >= 200 : syntaxfout: operator verwacht (het onjuiste symbool is ">= 200 ")
Kedi
Domoticz version: latest
Post by Kedi »
A lot of systems don't have ntpstat installed.
A lot of systems don't have ntpd running.
A lot of systems have time synchronized by systemd.
And then this monit solution won't work.
ben53252642
I setup a dedicated physical server thats only job was to operate as a ntp-server.
Kedi
Post by Kedi »
When you use this command in a running Raspberry
sudo ntpdate nl.pool.ntp.org
Then I get a respons
14 Jun 12:11:27 ntpdate[11647]: adjust time server 164.92.216.152 offset 0.001751 sec
So my system (using systemd) is after 38 days of the last boot accurate on 1.751 milliseconds.
That's enough for me, no need for a separate time-server and more accurate than the limit of 200 ms in the script.
