Can't set temprature via bash script
Posted: Tuesday 10 December 2019 13:39
I'm trying to set the temprature of one dummy hardware temperature sensor.
Here's what I've so far:
Result looks like this:
So as you can see my variable is filled corretly but the temperature is still 0 in domoticz (I've checked the IDX multiple times, it's correct and sensor type is Temp).
Any hints?
echo $MEASURED
curl 'http://127.0.0.1:8080/json.htm?username=XXX&password=XXX&type=command¶m=udevice&idx=175&nvalue=0&svalue=$MEASURED'Code: Select all
19.5
"status" : "OK",
"title" : "Update Device"
}Any hints?
