Page 1 of 5
Python plugin: Slide by Innovation in Motion
Posted: Friday 06 December 2019 22:27
by Lokonli
I've created a Python plugin for Slide by Innovation in Motion.
https://github.com/lokonli/slide-domoticz
Re: Python plugin: Slide by Innovation in Motion
Posted: Thursday 12 December 2019 15:27
by heggink
Great plugin. Installed and works
. Do get a bunch of error messages which I posed as a bug on Github.
Posted: Thursday 12 December 2019 17:17
by Lokonli
heggink wrote: Thursday 12 December 2019 15:27
ok, I'll check.
What kind of system are you using?
Posted: Friday 13 December 2019 9:12
by heggink
Raspberry pi 3.
Sent from phone.
Posted: Friday 13 December 2019 9:25
by Lokonli
ok, thanks.
To be clear:
The plugin is working correctly, you only see some unexpected messages in the Domoticz log?
Do you see any problem with the functionality?
Posted: Friday 13 December 2019 14:21
by mschut
Thanks! Just needed this. I followed the instructions, however I cant see " Slide" . in the hardware list. What name should I look for (Slide I suppose)?
Posted: Friday 13 December 2019 14:56
by Lokonli
mschut wrote: Friday 13 December 2019 14:21
The hardware name is 'Slide by Innovation in Motion'.
Did you restart Domoticz?
Is Python installed? Domoticz reports the Python version in the ''Settings'->about' window.
You might have to set the right access permissions for the folder and for plugin.py
Posted: Friday 13 December 2019 18:31
by mschut
Python Version: None
That explains
Verstuurd vanaf mijn SM-A530F met Tapatalk
Posted: Friday 13 December 2019 22:08
by mschut
Fixed the Python issue, and my Slides are showing! Great!
Would be great if you could integrate the Zones as well. I am using my Slides in one zone, which would be great to control as well.
Posted: Friday 13 December 2019 22:59
by Lokonli
mschut wrote: Friday 13 December 2019 22:08
Good!
You can create groups in Domoticz.
I could create dummy devices for each slide zone.
Or create the group in Domoticz automatically.
I'll add it to the feature request list.
Posted: Friday 13 December 2019 23:25
by mschut
Thanks, I am trying hard to setup a switch to control my slides. I do have made a Dummy switch, and by Blocky events this switch controls the Slides in the zone.
However, I don't know how to setup this dummy switch to be controlled by my Zwave wall switch,
With a group I cant get it to work either. The slides are controlled by percentages, so a group will only switch to 0 or 100, I cant get it to work to open and close it by a group. And thus, with 1 switch I can only Open or Close my curtains. Still thinking about a way to use 1 button to Open and Close the curtains....
Posted: Friday 13 December 2019 23:45
by heggink
Lokonli wrote:ok, thanks.
To be clear:
So far only the messages in the log. I did run into another issue that I need to investigate: I added all the devices in a group in order to switch them all at once. That crashed Domoticz... Anyways, I'll investigate and get back on that.
Great to have the plugin though!
Sent from phone.
Posted: Friday 13 December 2019 23:49
by mschut
I think I experienced that crash too
By now I have a working setup, a bit complicated, but working.
Zwave switch -> Zwave plug -> Event triggered by plug -> Individual slides.
Happy as can be, with my built in wall switch I can control my curtains
Posted: Saturday 14 December 2019 0:39
by Lokonli
mschut wrote: Friday 13 December 2019 23:49
There seems to be a bug in Domoticz in handling the disconnect of the https connections.
As a partial patch(?) I've increased the polling rate to once per 40 seconds in the latest version. Hopefully this keeps the connection alive.
In one of the Domoticz commits I see a report of the error in combination with zwave. There might be a relation.
I have 4 slides in one Domoticz group without issues.
Posted: Sunday 22 December 2019 13:37
by packetloss
Thanks Lokonli, works great!
For others: I had to do
and then restart domoticz.
Some day, in Domoticz, an other icon for curtains instead of blinds would be nice.
And using an API key instead of login/password would be nice. Not sure if Slide supports this.
Posted: Sunday 22 December 2019 18:29
by Lokonli
packetloss wrote: Sunday 22 December 2019 13:37
Thanks for the feedback!
I'll add this to the installation instructions.
Posted: Monday 23 December 2019 23:29
by RogerSch
Hello packetloss can you explain which problem was solved by installing libpython3-dev? I`m trying to use the Python plugin on my Synology NAS but I can`t get it to work. My Synology NAS doesn`t have this pyhton module installed.
@Lokonli: Would you be so kind to explain why this dev python module is needed and would it be possible to create a python version of Slide which wouldn`t need this dev python module?
Posted: Tuesday 24 December 2019 0:07
by Lokonli
RogerSch wrote: Monday 23 December 2019 23:29
It's not needed for my plugin, but for the Domoticz plugin system in general.
Is python detected by Domoticz? Domoticz reports the python version in Settings->About.
If not: did you install the correct Domoticz version on your Synology?
See
http://www.jadahl.com/
Install a version including Python
Posted: Tuesday 24 December 2019 15:12
by RogerSch
Lokonli wrote: Tuesday 24 December 2019 0:07
See
Yes Domotics recognize Python:
PluginSystem: Started, Python version '3.5.1'.
Which is the version I have activited in the package manager and from Jadahl I have donloaded the Pyhton version.
As soon as I instruct Domoticz to enable new sensors for 5 minutes the following erro message appears in the log file:
PluginList: Parsing '/usr/local/domoticz/var/plugins/slide-domoticz/', 'Error document empty.' at line 0 column 0 in XML ''.
plugin.py file in this folder has all the required rights...
Posted: Tuesday 24 December 2019 16:12
by Lokonli
RogerSch wrote:Lokonli wrote: Tuesday 24 December 2019 0:07
See
I have no experience with Synology...
Maybe try the following:
On the hardware configurarion page set the debug info to all.
Then enable the hardware, without allowing new devices.
In the log file filter 'slide'. Do you see any result?
(I assume you filled in your email and password on the slide hardware configuration page)
