HUE MQTT output format
Posted: Thursday 05 December 2019 18:08
i noticed that MQTT sends the hue light status as format
however when sending a command to domoticz you have several options
is there a way to change the mqtt output format to let's say hue so that instead of sending the m,t,r,g,b,cw and cw it sends out the hue and brightness status
so basically something like this
"Battery" : 255,
"Color" : {
"b" : 58,
"cw" : 0,
"g" : 175,
"m" : 3,
"r" : 254,
"t" : 0,
"ww" : 0
"Level" : 40,
"RSSI" : 12,
"description" : "",
"dtype" : "Color Switch",
"id" : "00000005",
"idx" : 15,
"name" : "LampachterTV",
"nvalue" : 1,
"stype" : "RGBWW",
"svalue1" : "40",
"switchType" : "Dimmer",
"unit" : 1
}Code: Select all
{"command": "setcolbrightnessvalue", "idx": 2450, "hue": 274, "brightness": 40, "iswhite": false }
{"command": "setcolbrightnessvalue", "idx": 2450, "hex": "RRGGBB", "brightness": 100, "iswhite": false }
{"command": "setcolbrightnessvalue", "idx": 2450, "color": {"m":3,"t":0,"r":0,"g":0,"b":50,"cw":0,"ww":0}, "brightness": 40}is there a way to change the mqtt output format to let's say hue so that instead of sending the m,t,r,g,b,cw and cw it sends out the hue and brightness status
"Battery" : 255,
"hue" : 274,
"Level" : 40,
"RSSI" : 12,
"description" : "",
"id" : "00000005",
"idx" : 15,
"nvalue" : 1,
"stype" : "RGBWW",
"svalue1" : "40",
"unit" : 1
