domoticz chrashes when i install latest beta.
tjabas
Post by tjabas »
Hi!
i have for about a year installed and used the betas of domoticz without any problem, but about 1 month ago domoticz froze after i installed the beta, dont remeber which version it was, luckily i had an backup that i installed and everything has been working since then, and i havent tried any more betas after that, but today i gave it a try again, i thought that if there was a problem with that beta that time, they have fixed it, but domoticz froze again after the latest beta, it freezes when domoticz is about to start, the webpage starts to appear, but then it freezes.
what can be wrong, am i the only one?
any suggestions?
tobydeteckel
Domoticz version: V12461
Re: domoticz chrashes when i install latest beta.
Post by tobydeteckel »
Can you try renaming the plugin directory?
Ive got same problem with domoticz since a couple of days.
see:
https://www.domoticz.com/forum/viewtopi ... =6&t=30317
Thijs
tjabas
Post by tjabas »
thanks, i read that post, it seems like the same problem i have, but should i try to solve it, or do you think that it will be fixed in future releases of domoticz?
tobydeteckel
I hope they help us,
Just bought a Raspberry PI 4 to solve the problem.
No luck......
tobydeteckel
You can try replace the specific plugin folders 1-by-1 to determine which plugin crashing your installation.
Thijs
gizmocuz
Post by gizmocuz »
@tjabas, I don't think it is the same issue as it seems your Domoticz installation is freezing right at the start.
Could you try the following:
make sure you have a backup
login to you pi
cd domoticz
./updatebeta
now you are on the latest backup
stop domoticz with
sudo service domoticz stop
Now start Domoticz by hand with:
./domoticz
What do you see, does it start correctly, does it show any errors ?
tjabas
Post by tjabas »
Thanks for your help, i did what you told me, and i get alot of strange error codes, it seems like the webinterface crashes, also zigate and z-wave chrashes. i will try to post a part of the log:
pi@raspberrypi:~/domoticz $ ./domoticz
2019-12-09 21:46:31.071  Status: Domoticz V4.11563 (c)2012-2019 GizMoCuz
2019-12-09 21:46:31.071  Status: Build Hash: d5e8a14bf, Date: 2019-12-09 20:21:2        4
2019-12-09 21:46:31.071  Status: Startup Path: /home/pi/domoticz/
2019-12-09 21:46:31.100  Sunrise: 08:50:00 SunSet: 15:22:00
2019-12-09 21:46:31.100  Day length: 06:32:00 Sun at south: 12:06:00
2019-12-09 21:46:31.101  Civil twilight start: 07:58:00 Civil twilight end: 16:1        4:00
2019-12-09 21:46:31.101  Nautical twilight start: 07:05:00 Nautical twilight end        : 17:07:00
2019-12-09 21:46:31.101  Astronomical twilight start: 06:16:00 Astronomical twil        ight end: 17:56:00
2019-12-09 21:46:31.182  Status: PluginSystem: Started, Python version '3.4.2'.
2019-12-09 21:46:31.192  Active notification Subsystems: email, kodi, pushbullet        , pushover (4/13)
2019-12-09 21:46:31.194  Status: WebServer(HTTP) started on address: :: with por        t 8080
2019-12-09 21:46:31.204  Error: WebServer(SSL) startup failed on address 0.0.0.0        with port: 443: bind: Permission denied
2019-12-09 21:46:31.204  Error: WebServer(SSL) check privileges for opening port        s below 1024
2019-12-09 21:46:31.206  Status: Camera: settings (re)loaded
2019-12-09 21:46:31.207  Starting shared server on: :::6144
2019-12-09 21:46:31.208  Status: TCPServer: shared server started...
2019-12-09 21:46:31.208  Status: RxQueue: queue worker started...
2019-12-09 21:46:33.212  Status: RFXCOM: Worker started...
2019-12-09 21:46:33.212  Status: Kodi: Started
2019-12-09 21:46:33.212  Status: Hardware Monitor: Started
2019-12-09 21:46:33.229  Status: (Roborock s50) Started.
2019-12-09 21:46:33.229  Status: (zigate) Started.
2019-12-09 21:46:33.230  Status: EventSystem: reset all events...
2019-12-09 21:46:33.239  Status: EventSystem: reset all device statuses...
2019-12-09 21:46:33.313  Kodi: (kodi) Starting thread.
2019-12-09 21:46:33.379  Status: Python EventSystem: Initalizing event module.
2019-12-09 21:46:33.379  Status: EventSystem: Started
2019-12-09 21:46:33.380  Status: EventSystem: Queue thread started...
2019-12-09 21:46:33.414  Kodi: Starting I/O service thread.
2019-12-09 21:46:33.603  Status: PluginSystem: Entering work loop.
2019-12-09 21:46:33.729  Status: OpenZWave: using config in: /home/pi/domoticz/Config/
Could Not Open OZW Log File.
2019-12-09 21:46:33.733 Always, OpenZwave Version 1.6-943-gacce060e-dirty Starting Up
2019-12-09 21:46:33.762 Always, Using Language Localization
2019-12-09 21:46:33.773  Status: OpenZWave: Starting...
2019-12-09 21:46:33.774  Status: OpenZWave: Version: 1.6-943-gacce060e-dirty
2019-12-09 21:46:33.929  Status: (Roborock s50) Entering work loop.
2019-12-09 21:46:33.930  Status: (Roborock s50) Initialized version 0.1.3, author 'mrin'
2019-12-09 21:46:34.215  Status: RFXCOM: Using serial port: /dev/ttyUSB_RFX
2019-12-09 21:46:35.098  Status: (zigate) Entering work loop.
2019-12-09 21:46:35.099  Status: (zigate) Initialized version 4.5, author 'zaraki673  pipiche38'
2019-12-09 21:46:35.120  Status: (zigate) Zigate plugin stable-4.5.7 started
2019-12-09 21:46:35.120  (zigate) Debug: 0
2019-12-09 21:46:35.120  Status: (zigate) Python Version - 3.4.2 (default, Sep 16 2019, 20:33:47)
[GCC 4.9.2]
2019-12-09 21:46:35.121  Status: (zigate) Switching Heartbeat to 5 s interval
2019-12-09 21:46:35.121  Status: (zigate) DomoticzVersion: 4.11563
2019-12-09 21:46:35.121  Status: (zigate) DomoticzHash: d5e8a14bf
2019-12-09 21:46:35.121  Status: (zigate) DomoticzBuildTime: 2019-12-09 20:21:24
2019-12-09 21:46:35.121  Status: (zigate) load PluginConf
2019-12-09 21:46:35.122  Error: (zigate) 'onStart' failed 'PermissionError'.
2019-12-09 21:46:35.122  Error: (zigate) ----> Line 781 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-12-09 21:46:35.123  Error: (zigate) ----> Line 224 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-12-09 21:46:35.123  Error: (zigate) ----> Line 183 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/PluginConf.py', function __init__
2019-12-09 21:46:35.123  Error: (zigate) ----> Line 289 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/PluginConf.py', function _load_Settings
sudo2019-12-09 21:47:29.702 Error, Node162, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "SecurityCmd_SupportedGet (Node=162): 0x01, 0x09, 0x00, 0x13, 0xa2, 0x02, 0x98, 0x02, 0x25, 0x51, 0xab"
2019-12-09 21:47:29.702 Always,
the log was alot bigget ,but i tried to short it down a bit.
any suggestion of what to do?
gizmocuz
Post by gizmocuz »
Looks like there is a problem with the python scripts...
Could you move the files from the scripts/python folder somewhere else
then try to start domoticz again ?
I do not see a crash... was it crashed ?
tjabas
Post by tjabas »
yes i think it was chrashed, nothing worked anyway, i couldnt reach the webinterface and none of my swithes at home worked,
i will try to remove the python script and restart it, can i try to heal domoticz somehow?
or what if i install domoticz again,do i keep my settings in domoticz then?
or can i update pyton if its that one that fails?
if so, how do i update python?
tjabas
Post by tjabas »
so i have moved the python scripts to another folder, but i still get error codes, and domoticz wont start:
2019-12-10 14:20:10.398  Status: Domoticz V4.11563 (c)2012-2019 GizMoCuz
2019-12-10 14:20:10.398  Status: Build Hash: d5e8a14bf, Date: 2019-12-09 20:21:2        4
2019-12-10 14:20:10.398  Status: Startup Path: /home/pi/domoticz/
2019-12-10 14:20:10.429  Sunrise: 08:51:00 SunSet: 15:22:00
2019-12-10 14:20:10.429  Day length: 06:31:00 Sun at south: 12:06:00
2019-12-10 14:20:10.429  Civil twilight start: 07:59:00 Civil twilight end: 16:1        4:00
2019-12-10 14:20:10.429  Nautical twilight start: 07:06:00 Nautical twilight end        : 17:07:00
2019-12-10 14:20:10.429  Astronomical twilight start: 06:17:00 Astronomical twil        ight end: 17:55:00
2019-12-10 14:20:10.530  Status: PluginSystem: Started, Python version '3.4.2'.
2019-12-10 14:20:10.540  Active notification Subsystems: email, kodi, pushbullet        , pushover (4/13)
2019-12-10 14:20:10.542  Error: WebServer(HTTP) startup failed on address 0.0.0.        0 with port: 8080: bind: Address already in use
2019-12-10 14:20:10.542  Error: WebServer(HTTP) check if no other application is        using port: 8080
2019-12-10 14:20:10.550  Error: WebServer(SSL) startup failed on address 0.0.0.0        with port: 443: bind: Permission denied
2019-12-10 14:20:10.550  Error: WebServer(SSL) check privileges for opening port        s below 1024
2019-12-10 14:20:10.550  Error: No servers are configured. Hence mydomoticz will        not be started either (if configured)
terminate called without an active exception
2019-12-10 14:20:10.551  Error: Domoticz(pid:28974, tid:28974('domoticz')) recei        ved fatal signal 6 (Aborted)
2019-12-10 14:20:10.551  Error: siginfo address=0x712e, address=0x76c56f44
2019-12-10 14:20:15.756  Error: Failed to start gdb, will use backtrace() for printing stack frame
2019-12-10 14:20:15.758  Error: #0  ./domoticz() [0x30a744]
2019-12-10 14:20:15.758  Error: #1  ./domoticz : signal_handler(int, siginfo_t*, void*) + 0x27c [0x30b1dc]
2019-12-10 14:20:15.758  Error: #2  /lib/arm-linux-gnueabihf/libc.so.6 : __default_rt_sa_restorer_v2 + 0 [0x76c581a0]
2019-12-10 14:20:15.758  Error: #3  /lib/arm-linux-gnueabihf/libc.so.6 : gsignal + 0x38 [0x76c56f70]
Avbruten (SIGABRT)
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.530  Status: PluginSystem: Started, Python version '3.4.2'.
-bash: 2019-12-10: kommandot finns inte
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.540  Active notification Subsystems: email, kodi, pushbullet        , pushover (4/13)
-bash: syntaxfel nära den oväntade symbolen "("
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.542  Error: WebServer(HTTP) startup failed on address 0.0.0.        0 with port: 8080: bind: Address already in use
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.542  Error: WebServer(HTTP) check if no other application is        using port: 8080
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.550  Error: WebServer(SSL) startup failed on address 0.0.0.0        with port: 443: bind: Permission denied
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.550  Error: WebServer(SSL) check privileges for opening port        s below 1024
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.550  Error: No servers are configured. Hence mydomoticz will        not be started either (if configured)
pi@raspberrypi:~/domoticz $ terminate called without an active exception
-bash: terminate: kommandot finns inte
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.551  Error: Domoticz(pid:28974, tid:28974('domoticz')) recei        ved fatal signal 6 (Aborted)
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:10.551  Error: siginfo address=0x712e, address=0x76c56f44
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:15.756  Error: Failed to start gdb, will use backtrace() for printing stack frame
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:15.758  Error: #0  ./domoticz() [0x30a744]
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:15.758  Error: #1  ./domoticz : signal_handler(int, siginfo_t*, void*) + 0x27c [0x30b1dc]
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:15.758  Error: #2  /lib/arm-linux-gnueabihf/libc.so.6 : __default_rt_sa_restorer_v2 + 0 [0x76c581a0]
pi@raspberrypi:~/domoticz $ 2019-12-10 14:20:15.758  Error: #3  /lib/arm-linux-gnueabihf/libc.so.6 : gsignal + 0x38 [0x76c56f70]
tjabas wrote: Tuesday 10 December 2019 14:22 so i have moved the python scripts to another folder, but i still get error codes, and domoticz wont start:
It looks like your domoticz ports are already in use
You can try to identify which process(es) prevent domoticz from using these ports. You can do that with the netstat tool.
sudo netstat -tulpn | grep <portnumber to check>
if you get the message
command not found
then do a sudo apt install net-tools first.
tjabas
Post by tjabas »
Hi!
i think i have isolated the problem, i managed to install the beta, and during the boot of domoticz i disabled the zigate plugin before domoticz froze, after that everything works with the update, but not zigate, i had these problems 6 months ago when i started using zigate, the solution was to adress a specific port on the raspberry pi to zigate, after that it has work without any problems, i cant inderstand why this isnt working anymore.
tjabas
Post by tjabas »
well, didnt get it to work, am giving up at the moment, happily installed the backup sd card, but suddenly now i have lost 10 of the nodes in zigate, nothing works now, i thought that the zigate devices where stored in the sd card, but there must have been something wrong in the zigate usb itself. :(
