Dummy Device Attributes
Posted: Thursday 05 December 2019 9:29
by mash47
I've set up a virtual device of type 'Dummy (Does nothing, use for virtual switched only'. Data is inserted by @MikeF 's 'Another sun position calculator'. When I run this DzVents script ...
devices = {
'Sun azimuth'
I see this in the log file ...
2019-12-04 21:02:03.043 Status: dzVents: Info: Handling events for: "Sun azimuth", value: "296.4"
I cannot find a way to grab the device value. device.name returns the device name, but device.data returns nil. device.Data doesn't work either.
What are the Dummy device attributes?
Re: Dummy Device Attributes
Posted: Thursday 05 December 2019 10:03
by waaren
mash47 wrote: Thursday 05 December 2019 9:29
The Dummy (Does nothing, use for virtual switched only) is actually your "hardware" You probably defined a virtual device connected to this dummy.
The device attributes in dzVents depend on the type of device you defined.
you can get all attributes and methods for this device by using the generic dump() method.
Try this
devices = {
'Sun azimuth'
device.dump()
and check your log to see what the attributes are
Posted: Thursday 05 December 2019 10:05
by boum
Hi, if you used a custom sensor attribute, you can get the value in
device.state (and change it with device.updateCustomSensor(value))
But yes, when in doubt, use Waaren method and dump() to inspect the device innards
Re: Dummy Device Attributes [Solved]
Posted: Thursday 05 December 2019 13:32
by mash47
Thanks guys, I just have to work out the rest of the DzVents syntax! I've been using Lua on a mios vera box for the last 8 years, DzVents is a steep learning curve at my age!
Posted: Thursday 05 December 2019 23:29
by waaren
mash47 wrote: Thursday 05 December 2019 13:32
Maybe the
wiki and the
youtube will help ?
