Graph for one phase of my P1 connection not working
Posted: Wednesday 04 December 2019 22:49
by ykuijs
I recently upgraded my electricity to a 3 phase connection. The new power meter also had a P1 port, so I connected it to my Domoticz system. I am now trying to show the power used for each phase. Phase 1 and 2 are displaying just fine, however phase 3 doesn't show any graph, but does show the correct current usage in the header so it is able retrieve data from Domoticz. However, the graph for Last Month does show some output, similar to the graph in Domoticz.
All graphs in Domoticz for this device are displaying just fine, so the device is generating output. Currently I am not using any graph customization (yet).
How can I get this third graph to also work like the other two phases?
Re: Graph for one phase of my P1 connection
Posted: Wednesday 04 December 2019 23:03
by FireWizard
One question.
You posted recently another issue, where you indicated, that you use Dashticz.
Do you mean the Dashticz graphs here as well?
If so, how do the Domoticz sensors and graphs look like?
Re: Graph for one phase of my P1 connection not working
Posted: Wednesday 04 December 2019 23:12
by Lokonli
ykuijs wrote: Wednesday 04 December 2019 22:49 I recently upgraded my electricity to a 3 phase connection. The new power meter also had a P1 port, so I connected it to my Domoticz system. I am now trying to show the power used for each phase. Phase 1 and 2 are displaying just fine, however phase 3 doesn't show any graph, but does show the correct current usage in the header so it is able retrieve data from Domoticz. However, the graph for Last Month does show some output, similar to the graph in Domoticz.
Can you send the Domoticz json output of the 3-phase device? Then I'll have a look.
Posted: Thursday 05 December 2019 9:01
by ykuijs
@FireWizard, yes I mean the graphs in Dashticz. The graphs in Domoticz look just fine.
@Lokonli, here the info you requested:
The JSON output for phase 2 (which is working fine):
   "ActTime" : 1575532613,
   "AstrTwilightEnd" : "18:33",
   "AstrTwilightStart" : "06:26",
   "CivTwilightEnd" : "17:09",
   "CivTwilightStart" : "07:50",
   "DayLength" : "08:00",
   "NautTwilightEnd" : "17:52",
   "NautTwilightStart" : "07:07",
   "ServerTime" : "2019-12-05 08:56:53",
   "SunAtSouth" : "12:30",
   "Sunrise" : "08:29",
   "Sunset" : "16:30",
   "app_version" : "4.10717",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "54 Watt",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 7,
         "HardwareName" : "Slimme Meter",
         "HardwareType" : "P1 Smart Meter USB",
         "HardwareTypeVal" : 4,
         "HaveTimeout" : false,
         "ID" : "0000000",
         "LastUpdate" : "2019-12-05 08:56:52",
         "Name" : "Stroomverbruik Fase 2",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Electric",
         "Timers" : "false",
         "Type" : "Usage",
         "TypeImg" : "current",
         "Unit" : 2,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "44"
   "status" : "OK",
   "title" : "Devices"
The JSON output for phase 3 (which isn't working):
   "ActTime" : 1575532701,
   "ServerTime" : "2019-12-05 08:58:21",
   "Sunset" : "16:30",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0 Watt",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 7,
         "ID" : "0000000",
         "LastUpdate" : "2019-12-05 08:58:21",
         "Name" : "Stroomverbruik Fase 3",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "Usage",
         "Unit" : 3,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "45"
   "status" : "OK",
   "title" : "Devices"
Posted: Monday 09 December 2019 22:15
by Lokonli
I don't have a 3 phase device, so it's difficult to reproduce.
Could you post the graph data as well?
http://<Domoticz IP address>/json.htm?type=graph&sensor=counter&idx=44&range=day&method=1
http://<Domoticz IP address>/json.htm?type=graph&sensor=counter&idx=45&range=day&method=1
The first line (idx44) is your phase 2, and the second line (idx45) your phase 3.
Posted: Thursday 12 December 2019 22:40
by ykuijs
Here the requested graph data:
Phase 2 (idx 44)
   "result" : [
         "d" : "2019-12-11 22:30",
         "u" : 198.0
         "d" : "2019-12-11 22:35",
         "u" : 92.0
         "d" : "2019-12-11 22:40",
         "u" : 96.0
         "d" : "2019-12-11 22:45",
         "u" : 84.0
         "d" : "2019-12-11 22:50",
         "u" : 123.0
         "d" : "2019-12-11 22:55",
         "u" : 133.0
         "d" : "2019-12-11 23:00",
         "u" : 45.0
         "d" : "2019-12-11 23:05",
         "u" : 45.0
         "d" : "2019-12-11 23:10",
         "u" : 45.0
         "d" : "2019-12-11 23:15",
         "u" : 44.0
         "d" : "2019-12-11 23:20",
         "u" : 131.0
         "d" : "2019-12-11 23:25",
         "u" : 45.0
         "d" : "2019-12-11 23:30",
         "u" : 44.0
         "d" : "2019-12-11 23:35",
         "u" : 45.0
         "d" : "2019-12-11 23:40",
         "u" : 45.0
         "d" : "2019-12-11 23:45",
         "u" : 45.0
         "d" : "2019-12-11 23:50",
         "u" : 124.0
         "d" : "2019-12-11 23:55",
         "u" : 46.0
         "d" : "2019-12-12 00:00",
         "u" : 46.0
         "d" : "2019-12-12 00:05",
         "u" : 46.0
         "d" : "2019-12-12 00:10",
         "u" : 45.0
         "d" : "2019-12-12 00:15",
         "u" : 45.0
         "d" : "2019-12-12 00:20",
         "u" : 124.0
         "d" : "2019-12-12 00:25",
         "u" : 102.0
         "d" : "2019-12-12 00:30",
         "u" : 106.0
         "d" : "2019-12-12 00:35",
         "u" : 46.0
         "d" : "2019-12-12 00:40",
         "u" : 45.0
         "d" : "2019-12-12 00:45",
         "u" : 46.0
         "d" : "2019-12-12 00:50",
         "u" : 126.0
         "d" : "2019-12-12 00:55",
         "u" : 45.0
         "d" : "2019-12-12 01:00",
         "u" : 45.0
         "d" : "2019-12-12 01:05",
         "u" : 46.0
         "d" : "2019-12-12 01:10",
         "u" : 46.0
         "d" : "2019-12-12 01:15",
         "u" : 45.0
         "d" : "2019-12-12 01:20",
         "u" : 46.0
         "d" : "2019-12-12 01:25",
         "u" : 126.0
         "d" : "2019-12-12 01:30",
         "u" : 45.0
         "d" : "2019-12-12 01:35",
         "u" : 46.0
         "d" : "2019-12-12 01:40",
         "u" : 47.0
         "d" : "2019-12-12 01:45",
         "u" : 132.0
         "d" : "2019-12-12 01:50",
         "u" : 46.0
         "d" : "2019-12-12 01:55",
         "u" : 45.0
         "d" : "2019-12-12 02:00",
         "u" : 45.0
         "d" : "2019-12-12 02:05",
         "u" : 46.0
         "d" : "2019-12-12 02:10",
         "u" : 45.0
         "d" : "2019-12-12 02:15",
         "u" : 46.0
         "d" : "2019-12-12 02:20",
         "u" : 126.0
         "d" : "2019-12-12 02:25",
         "u" : 45.0
         "d" : "2019-12-12 02:30",
         "u" : 45.0
         "d" : "2019-12-12 02:35",
         "u" : 46.0
         "d" : "2019-12-12 02:40",
         "u" : 46.0
         "d" : "2019-12-12 02:45",
         "u" : 125.0
         "d" : "2019-12-12 02:50",
         "u" : 46.0
         "d" : "2019-12-12 02:55",
         "u" : 47.0
         "d" : "2019-12-12 03:00",
         "u" : 45.0
         "d" : "2019-12-12 03:05",
         "u" : 46.0
         "d" : "2019-12-12 03:10",
         "u" : 46.0
         "d" : "2019-12-12 03:15",
         "u" : 127.0
         "d" : "2019-12-12 03:20",
         "u" : 46.0
         "d" : "2019-12-12 03:25",
         "u" : 46.0
         "d" : "2019-12-12 03:30",
         "u" : 46.0
         "d" : "2019-12-12 03:35",
         "u" : 46.0
         "d" : "2019-12-12 03:40",
         "u" : 45.0
         "d" : "2019-12-12 03:45",
         "u" : 130.0
         "d" : "2019-12-12 03:50",
         "u" : 45.0
         "d" : "2019-12-12 03:55",
         "u" : 45.0
         "d" : "2019-12-12 04:00",
         "u" : 46.0
         "d" : "2019-12-12 04:05",
         "u" : 46.0
         "d" : "2019-12-12 04:10",
         "u" : 46.0
         "d" : "2019-12-12 04:15",
         "u" : 46.0
         "d" : "2019-12-12 04:20",
         "u" : 46.0
         "d" : "2019-12-12 04:25",
         "u" : 126.0
         "d" : "2019-12-12 04:30",
         "u" : 46.0
         "d" : "2019-12-12 04:35",
         "u" : 45.0
         "d" : "2019-12-12 04:40",
         "u" : 46.0
         "d" : "2019-12-12 04:45",
         "u" : 46.0
         "d" : "2019-12-12 04:50",
         "u" : 127.0
         "d" : "2019-12-12 04:55",
         "u" : 46.0
         "d" : "2019-12-12 05:00",
         "u" : 46.0
         "d" : "2019-12-12 05:05",
         "u" : 45.0
         "d" : "2019-12-12 05:10",
         "u" : 45.0
         "d" : "2019-12-12 05:15",
         "u" : 45.0
         "d" : "2019-12-12 05:20",
         "u" : 45.0
         "d" : "2019-12-12 05:25",
         "u" : 44.0
         "d" : "2019-12-12 05:30",
         "u" : 44.0
         "d" : "2019-12-12 05:35",
         "u" : 44.0
         "d" : "2019-12-12 05:40",
         "u" : 45.0
         "d" : "2019-12-12 05:45",
         "u" : 79.0
         "d" : "2019-12-12 05:50",
         "u" : 122.0
         "d" : "2019-12-12 05:55",
         "u" : 122.0
         "d" : "2019-12-12 06:00",
         "u" : 71.0
         "d" : "2019-12-12 06:05",
         "u" : 123.0
         "d" : "2019-12-12 06:10",
         "u" : 126.0
         "d" : "2019-12-12 06:15",
         "u" : 184.0
         "d" : "2019-12-12 06:20",
         "u" : 187.0
         "d" : "2019-12-12 06:25",
         "u" : 125.0
         "d" : "2019-12-12 06:30",
         "u" : 126.0
         "d" : "2019-12-12 06:35",
         "u" : 125.0
         "d" : "2019-12-12 06:40",
         "u" : 202.0
         "d" : "2019-12-12 06:45",
         "u" : 743.0
         "d" : "2019-12-12 06:50",
         "u" : 243.0
         "d" : "2019-12-12 06:55",
         "u" : 243.0
         "d" : "2019-12-12 07:00",
         "u" : 241.0
         "d" : "2019-12-12 07:05",
         "u" : 324.0
         "d" : "2019-12-12 07:10",
         "u" : 221.0
         "d" : "2019-12-12 07:15",
         "u" : 199.0
         "d" : "2019-12-12 07:20",
         "u" : 211.0
         "d" : "2019-12-12 07:25",
         "u" : 214.0
         "d" : "2019-12-12 07:30",
         "u" : 225.0
         "d" : "2019-12-12 07:35",
         "u" : 295.0
         "d" : "2019-12-12 07:40",
         "u" : 210.0
         "d" : "2019-12-12 07:45",
         "u" : 202.0
         "d" : "2019-12-12 07:50",
         "u" : 195.0
         "d" : "2019-12-12 07:55",
         "u" : 100.0
         "d" : "2019-12-12 08:00",
         "u" : 116.0
         "d" : "2019-12-12 08:05",
         "u" : 211.0
         "d" : "2019-12-12 08:10",
         "u" : 137.0
         "d" : "2019-12-12 08:15",
         "u" : 125.0
         "d" : "2019-12-12 08:20",
         "u" : 101.0
         "d" : "2019-12-12 08:25",
         "u" : 85.0
         "d" : "2019-12-12 08:30",
         "u" : 162.0
         "d" : "2019-12-12 08:35",
         "u" : 72.0
         "d" : "2019-12-12 08:40",
         "u" : 117.0
         "d" : "2019-12-12 08:45",
         "u" : 135.0
         "d" : "2019-12-12 08:50",
         "u" : 59.0
         "d" : "2019-12-12 08:55",
         "u" : 72.0
         "d" : "2019-12-12 09:00",
         "u" : 63.0
         "d" : "2019-12-12 09:05",
         "u" : 107.0
         "d" : "2019-12-12 09:10",
         "u" : 125.0
         "d" : "2019-12-12 09:15",
         "u" : 217.0
         "d" : "2019-12-12 09:20",
         "u" : 204.0
         "d" : "2019-12-12 09:25",
         "u" : 85.0
         "d" : "2019-12-12 09:30",
         "u" : 74.0
         "d" : "2019-12-12 09:35",
         "u" : 59.0
         "d" : "2019-12-12 09:40",
         "u" : 162.0
         "d" : "2019-12-12 09:45",
         "u" : 71.0
         "d" : "2019-12-12 09:50",
         "u" : 75.0
         "d" : "2019-12-12 09:55",
         "u" : 65.0
         "d" : "2019-12-12 10:00",
         "u" : 76.0
         "d" : "2019-12-12 10:05",
         "u" : 67.0
         "d" : "2019-12-12 10:10",
         "u" : 54.0
         "d" : "2019-12-12 10:15",
         "u" : 66.0
         "d" : "2019-12-12 10:20",
         "u" : 136.0
         "d" : "2019-12-12 10:25",
         "u" : 65.0
         "d" : "2019-12-12 10:30",
         "u" : 52.0
         "d" : "2019-12-12 10:35",
         "u" : 65.0
         "d" : "2019-12-12 10:40",
         "u" : 54.0
         "d" : "2019-12-12 10:45",
         "u" : 120.0
         "d" : "2019-12-12 10:50",
         "u" : 121.0
         "d" : "2019-12-12 10:55",
         "u" : 200.0
         "d" : "2019-12-12 11:00",
         "u" : 87.0
         "d" : "2019-12-12 11:05",
         "u" : 78.0
         "d" : "2019-12-12 11:10",
         "u" : 74.0
         "d" : "2019-12-12 11:15",
         "u" : 57.0
         "d" : "2019-12-12 11:20",
         "u" : 74.0
         "d" : "2019-12-12 11:25",
         "u" : 56.0
         "d" : "2019-12-12 11:30",
         "u" : 136.0
         "d" : "2019-12-12 11:35",
         "u" : 57.0
         "d" : "2019-12-12 11:40",
         "u" : 53.0
         "d" : "2019-12-12 11:45",
         "u" : 113.0
         "d" : "2019-12-12 11:50",
         "u" : 114.0
         "d" : "2019-12-12 11:55",
         "u" : 56.0
         "d" : "2019-12-12 12:00",
         "u" : 55.0
         "d" : "2019-12-12 12:05",
         "u" : 144.0
         "d" : "2019-12-12 12:10",
         "u" : 54.0
         "d" : "2019-12-12 12:15",
         "u" : 66.0
         "d" : "2019-12-12 12:20",
         "u" : 52.0
         "d" : "2019-12-12 12:25",
         "u" : 151.0
         "d" : "2019-12-12 12:30",
         "u" : 53.0
         "d" : "2019-12-12 12:35",
         "u" : 65.0
         "d" : "2019-12-12 12:40",
         "u" : 53.0
         "d" : "2019-12-12 12:45",
         "u" : 91.0
         "d" : "2019-12-12 12:50",
         "u" : 119.0
         "d" : "2019-12-12 12:55",
         "u" : 168.0
         "d" : "2019-12-12 13:00",
         "u" : 69.0
         "d" : "2019-12-12 13:05",
         "u" : 54.0
         "d" : "2019-12-12 13:10",
         "u" : 40.0
         "d" : "2019-12-12 13:15",
         "u" : 57.0
         "d" : "2019-12-12 13:20",
         "u" : 53.0
         "d" : "2019-12-12 13:25",
         "u" : 135.0
         "d" : "2019-12-12 13:30",
         "u" : 52.0
         "d" : "2019-12-12 13:35",
         "u" : 66.0
         "d" : "2019-12-12 13:40",
         "u" : 54.0
         "d" : "2019-12-12 13:45",
         "u" : 65.0
         "d" : "2019-12-12 13:50",
         "u" : 59.0
         "d" : "2019-12-12 13:55",
         "u" : 157.0
         "d" : "2019-12-12 14:00",
         "u" : 53.0
         "d" : "2019-12-12 14:05",
         "u" : 65.0
         "d" : "2019-12-12 14:10",
         "u" : 51.0
         "d" : "2019-12-12 14:15",
         "u" : 64.0
         "d" : "2019-12-12 14:20",
         "u" : 52.0
         "d" : "2019-12-12 14:25",
         "u" : 64.0
         "d" : "2019-12-12 14:30",
         "u" : 144.0
         "d" : "2019-12-12 14:35",
         "u" : 76.0
         "d" : "2019-12-12 14:40",
         "u" : 79.0
         "d" : "2019-12-12 14:45",
         "u" : 73.0
         "d" : "2019-12-12 14:50",
         "u" : 66.0
         "d" : "2019-12-12 14:55",
         "u" : 114.0
         "d" : "2019-12-12 15:00",
         "u" : 120.0
         "d" : "2019-12-12 15:05",
         "u" : 159.0
         "d" : "2019-12-12 15:10",
         "u" : 66.0
         "d" : "2019-12-12 15:15",
         "u" : 79.0
         "d" : "2019-12-12 15:20",
         "u" : 66.0
         "d" : "2019-12-12 15:25",
         "u" : 77.0
         "d" : "2019-12-12 15:30",
         "u" : 66.0
         "d" : "2019-12-12 15:35",
         "u" : 78.0
         "d" : "2019-12-12 15:40",
         "u" : 170.0
         "d" : "2019-12-12 15:45",
         "u" : 131.0
         "d" : "2019-12-12 15:50",
         "u" : 132.0
         "d" : "2019-12-12 15:55",
         "u" : 104.0
         "d" : "2019-12-12 16:00",
         "u" : 82.0
         "d" : "2019-12-12 16:05",
         "u" : 81.0
         "d" : "2019-12-12 16:10",
         "u" : 80.0
         "d" : "2019-12-12 16:15",
         "u" : 79.0
         "d" : "2019-12-12 16:20",
         "u" : 80.0
         "d" : "2019-12-12 16:25",
         "u" : 80.0
         "d" : "2019-12-12 16:30",
         "u" : 82.0
         "d" : "2019-12-12 16:35",
         "u" : 83.0
         "d" : "2019-12-12 16:40",
         "u" : 83.0
         "d" : "2019-12-12 16:45",
         "u" : 98.0
         "d" : "2019-12-12 16:50",
         "u" : 106.0
         "d" : "2019-12-12 16:55",
         "u" : 181.0
         "d" : "2019-12-12 17:00",
         "u" : 99.0
         "d" : "2019-12-12 17:05",
         "u" : 116.0
         "d" : "2019-12-12 17:10",
         "u" : 114.0
         "d" : "2019-12-12 17:15",
         "u" : 108.0
         "d" : "2019-12-12 17:20",
         "u" : 107.0
         "d" : "2019-12-12 17:25",
         "u" : 107.0
         "d" : "2019-12-12 17:30",
         "u" : 107.0
         "d" : "2019-12-12 17:35",
         "u" : 96.0
         "d" : "2019-12-12 17:40",
         "u" : 108.0
         "d" : "2019-12-12 17:45",
         "u" : 94.0
         "d" : "2019-12-12 17:50",
         "u" : 167.0
         "d" : "2019-12-12 17:55",
         "u" : 244.0
         "d" : "2019-12-12 18:00",
         "u" : 115.0
         "d" : "2019-12-12 18:05",
         "u" : 96.0
         "d" : "2019-12-12 18:10",
         "u" : 116.0
         "d" : "2019-12-12 18:15",
         "u" : 95.0
         "d" : "2019-12-12 18:20",
         "u" : 456.0
         "d" : "2019-12-12 18:25",
         "u" : 109.0
         "d" : "2019-12-12 18:30",
         "u" : 109.0
         "d" : "2019-12-12 18:35",
         "u" : 121.0
         "d" : "2019-12-12 18:40",
         "u" : 105.0
         "d" : "2019-12-12 18:45",
         "u" : 161.0
         "d" : "2019-12-12 18:50",
         "u" : 96.0
         "d" : "2019-12-12 18:55",
         "u" : 148.0
         "d" : "2019-12-12 19:00",
         "u" : 161.0
         "d" : "2019-12-12 19:05",
         "u" : 120.0
         "d" : "2019-12-12 19:10",
         "u" : 190.0
         "d" : "2019-12-12 19:15",
         "u" : 186.0
         "d" : "2019-12-12 19:20",
         "u" : 97.0
         "d" : "2019-12-12 19:25",
         "u" : 98.0
         "d" : "2019-12-12 19:30",
         "u" : 109.0
         "d" : "2019-12-12 19:35",
         "u" : 97.0
         "d" : "2019-12-12 19:40",
         "u" : 190.0
         "d" : "2019-12-12 19:45",
         "u" : 141.0
         "d" : "2019-12-12 19:50",
         "u" : 110.0
         "d" : "2019-12-12 19:55",
         "u" : 97.0
         "d" : "2019-12-12 20:00",
         "u" : 144.0
         "d" : "2019-12-12 20:05",
         "u" : 241.0
         "d" : "2019-12-12 20:10",
         "u" : 132.0
         "d" : "2019-12-12 20:15",
         "u" : 117.0
         "d" : "2019-12-12 20:20",
         "u" : 101.0
         "d" : "2019-12-12 20:25",
         "u" : 94.0
         "d" : "2019-12-12 20:30",
         "u" : 99.0
         "d" : "2019-12-12 20:35",
         "u" : 97.0
         "d" : "2019-12-12 20:40",
         "u" : 187.0
         "d" : "2019-12-12 20:45",
         "u" : 95.0
         "d" : "2019-12-12 20:50",
         "u" : 106.0
         "d" : "2019-12-12 20:55",
         "u" : 157.0
         "d" : "2019-12-12 21:00",
         "u" : 249.0
         "d" : "2019-12-12 21:05",
         "u" : 95.0
         "d" : "2019-12-12 21:10",
         "u" : 107.0
         "d" : "2019-12-12 21:15",
         "u" : 96.0
         "d" : "2019-12-12 21:20",
         "u" : 141.0
         "d" : "2019-12-12 21:25",
         "u" : 161.0
         "d" : "2019-12-12 21:30",
         "u" : 211.0
         "d" : "2019-12-12 21:35",
         "u" : 148.0
         "d" : "2019-12-12 21:40",
         "u" : 109.0
         "d" : "2019-12-12 21:45",
         "u" : 95.0
         "d" : "2019-12-12 21:50",
         "u" : 107.0
         "d" : "2019-12-12 21:55",
         "u" : 95.0
         "d" : "2019-12-12 22:00",
         "u" : 189.0
         "d" : "2019-12-12 22:05",
         "u" : 95.0
         "d" : "2019-12-12 22:10",
         "u" : 107.0
         "d" : "2019-12-12 22:15",
         "u" : 96.0
         "d" : "2019-12-12 22:20",
         "u" : 108.0
         "d" : "2019-12-12 22:25",
         "u" : 189.0
         "d" : "2019-12-12 22:30",
         "u" : 131.0
   "status" : "OK",
   "title" : "Graph counter day"
Phase 3 (idx 45)
   "result" : [
         "u" : 2025.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2105.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2204.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2078.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2124.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2136.0
         "u" : 4064.0
         "u" : 2133.0
         "u" : 2166.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 2151.0
         "u" : 85.0
         "u" : 84.0
         "u" : 84.0
         "u" : 84.0
         "u" : 85.0
         "u" : 2188.0
         "u" : 2106.0
         "u" : 2105.0
         "u" : 86.0
         "u" : 0.0
         "u" : 21.0
         "u" : 21.0
         "u" : 21.0
         "u" : 21.0
         "u" : 22.0
         "u" : 21.0
         "u" : 20.0
         "u" : 21.0
         "u" : 20.0
         "u" : 20.0
         "u" : 20.0
         "u" : 20.0
         "u" : 20.0
         "u" : 21.0
         "u" : 2.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "d" : "2019-12-12 22:35",
         "u" : 0.0
   "status" : "OK",
The third phase isn't being used constantly, but has a boiler, dishwasher, oven connected. I would suspect the graph to display spikes, like it does in Domoticz.
Posted: Friday 13 December 2019 8:48
by ykuijs
Last night (shortly after posting previous post) the "Last hours" graph showed some output, but the "Today" graph still didn't work:
Last Hours:
Today:
Graph in Domoticz:
This morning both graphs weren't working again. So it probably looks like an issue where the usage is consistently low, but has spikes every now and then.
Posted: Friday 13 December 2019 11:17
by Lokonli
I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
Just to be sure, can you post the block definition for your graphs from config.js?
Which exact Dashticz version are you running?
In the latest beta there is an update on the chart x-axis setting, which might solve this issue.
Posted: Friday 13 December 2019 11:32
by Lokonli
I think I've found the issue:
If the first datapoint is 0, then whole data range will not be used...
I'll fix it this weekend.
Posted: Friday 13 December 2019 13:15
by ykuijs
Lokonli wrote: Friday 13 December 2019 11:17 I've to check how the chart.js module handles subsampling of device data, because the main difference between 'laatste uren' and 'vandaag' is the amount of data that is received.
I haven't defined any graph settings yet, so am using the default settings. Wanted to make sure it wasn't caused by anything I did ;)
I am using v3.1.2 Master
Lokonli wrote: Friday 13 December 2019 11:32 I think I've found the issue:
That is excellent, that totally makes sense based on the behavior I have seen so far. Waiting anxiously for the update! Thanks for your effort!
Posted: Friday 13 December 2019 23:57
by Lokonli
ykuijs wrote: Friday 13 December 2019 13:15
Should be fixed in latest beta. Can you test?
Posted: Saturday 14 December 2019 10:54
by ykuijs
Just pulled the latest bits from GitHub and used that. It is a little better, but isn't correct yet:
The graph for "Laatste Uren" now shows info, however just one data point with the value of 2019. I think this is displaying the year instead of the data from Domoticz:
The x-axis for graph for "Vandaag" shows increments of 10 or 15 minutes, but at the end of the graph jumps from 21.30 to 6.15
The data for this phase:
   "result" : [
         "d" : "2019-12-13 10:50",
         "u" : 75.0
         "d" : "2019-12-13 10:55",
         "u" : 137.0
         "d" : "2019-12-13 11:00",
         "u" : 127.0
         "d" : "2019-12-13 11:05",
         "u" : 80.0
         "d" : "2019-12-13 11:10",
         "u" : 68.0
         "d" : "2019-12-13 11:15",
         "u" : 80.0
         "d" : "2019-12-13 11:20",
         "u" : 146.0
         "d" : "2019-12-13 11:25",
         "u" : 77.0
         "d" : "2019-12-13 11:30",
         "u" : 67.0
         "d" : "2019-12-13 11:35",
         "u" : 79.0
         "d" : "2019-12-13 11:40",
         "u" : 154.0
         "d" : "2019-12-13 11:45",
         "u" : 79.0
         "d" : "2019-12-13 11:50",
         "u" : 66.0
         "d" : "2019-12-13 11:55",
         "u" : 110.0
         "d" : "2019-12-13 12:00",
         "u" : 132.0
         "d" : "2019-12-13 12:05",
         "u" : 133.0
         "d" : "2019-12-13 12:10",
         "u" : 110.0
         "d" : "2019-12-13 12:15",
         "u" : 71.0
         "d" : "2019-12-13 12:20",
         "u" : 68.0
         "d" : "2019-12-13 12:25",
         "u" : 85.0
         "d" : "2019-12-13 12:30",
         "u" : 56.0
         "d" : "2019-12-13 12:35",
         "u" : 146.0
         "d" : "2019-12-13 12:40",
         "u" : 55.0
         "d" : "2019-12-13 12:45",
         "u" : 68.0
         "d" : "2019-12-13 12:50",
         "u" : 54.0
         "d" : "2019-12-13 12:55",
         "u" : 65.0
         "d" : "2019-12-13 13:00",
         "u" : 57.0
         "d" : "2019-12-13 13:05",
         "u" : 65.0
         "d" : "2019-12-13 13:10",
         "u" : 136.0
         "d" : "2019-12-13 13:15",
         "u" : 73.0
         "d" : "2019-12-13 13:20",
         "u" : 120.0
         "d" : "2019-12-13 13:25",
         "u" : 120.0
         "d" : "2019-12-13 13:30",
         "u" : 84.0
         "d" : "2019-12-13 13:35",
         "u" : 66.0
         "d" : "2019-12-13 13:40",
         "u" : 67.0
         "d" : "2019-12-13 13:45",
         "u" : 54.0
         "d" : "2019-12-13 13:50",
         "u" : 207.0
         "d" : "2019-12-13 13:55",
         "u" : 115.0
         "d" : "2019-12-13 14:00",
         "u" : 66.0
         "d" : "2019-12-13 14:05",
         "u" : 54.0
         "d" : "2019-12-13 14:10",
         "u" : 66.0
         "d" : "2019-12-13 14:15",
         "u" : 54.0
         "d" : "2019-12-13 14:20",
         "u" : 101.0
         "d" : "2019-12-13 14:25",
         "u" : 120.0
         "d" : "2019-12-13 14:30",
         "u" : 169.0
         "d" : "2019-12-13 14:35",
         "u" : 87.0
         "d" : "2019-12-13 14:40",
         "u" : 74.0
         "d" : "2019-12-13 14:45",
         "u" : 80.0
         "d" : "2019-12-13 14:50",
         "u" : 151.0
         "d" : "2019-12-13 14:55",
         "u" : 79.0
         "d" : "2019-12-13 15:00",
         "u" : 66.0
         "d" : "2019-12-13 15:05",
         "u" : 87.0
         "d" : "2019-12-13 15:10",
         "u" : 78.0
         "d" : "2019-12-13 15:15",
         "u" : 79.0
         "d" : "2019-12-13 15:20",
         "u" : 85.0
         "d" : "2019-12-13 15:25",
         "u" : 155.0
         "d" : "2019-12-13 15:30",
         "u" : 211.0
         "d" : "2019-12-13 15:35",
         "u" : 133.0
         "d" : "2019-12-13 15:40",
         "u" : 87.0
         "d" : "2019-12-13 15:45",
         "u" : 80.0
         "d" : "2019-12-13 15:50",
         "u" : 67.0
         "d" : "2019-12-13 15:55",
         "u" : 68.0
         "d" : "2019-12-13 16:00",
         "u" : 69.0
         "d" : "2019-12-13 16:05",
         "u" : 147.0
         "d" : "2019-12-13 16:10",
         "u" : 86.0
         "d" : "2019-12-13 16:15",
         "u" : 73.0
         "d" : "2019-12-13 16:20",
         "u" : 79.0
         "d" : "2019-12-13 16:25",
         "u" : 67.0
         "d" : "2019-12-13 16:30",
         "u" : 77.0
         "d" : "2019-12-13 16:35",
         "u" : 168.0
         "d" : "2019-12-13 16:40",
         "u" : 153.0
         "d" : "2019-12-13 16:45",
         "u" : 141.0
         "d" : "2019-12-13 16:50",
         "u" : 93.0
         "d" : "2019-12-13 16:55",
         "u" : 81.0
         "d" : "2019-12-13 17:00",
         "u" : 94.0
         "d" : "2019-12-13 17:05",
         "u" : 74.0
         "d" : "2019-12-13 17:10",
         "u" : 89.0
         "d" : "2019-12-13 17:15",
         "u" : 166.0
         "d" : "2019-12-13 17:20",
         "u" : 107.0
         "d" : "2019-12-13 17:25",
         "u" : 89.0
         "d" : "2019-12-13 17:30",
         "u" : 101.0
         "d" : "2019-12-13 17:35",
         "u" : 96.0
         "d" : "2019-12-13 17:40",
         "u" : 101.0
         "d" : "2019-12-13 17:45",
         "u" : 88.0
         "d" : "2019-12-13 17:50",
         "u" : 223.0
         "d" : "2019-12-13 17:55",
         "u" : 169.0
         "d" : "2019-12-13 18:00",
         "u" : 144.0
         "d" : "2019-12-13 18:05",
         "u" : 116.0
         "d" : "2019-12-13 18:10",
         "u" : 103.0
         "d" : "2019-12-13 18:15",
         "u" : 195.0
         "d" : "2019-12-13 18:20",
         "u" : 106.0
         "d" : "2019-12-13 18:25",
         "u" : 104.0
         "d" : "2019-12-13 18:30",
         "u" : 104.0
         "d" : "2019-12-13 18:35",
         "u" : 255.0
         "d" : "2019-12-13 18:40",
         "u" : 233.0
         "d" : "2019-12-13 18:45",
         "u" : 230.0
         "d" : "2019-12-13 18:50",
         "u" : 228.0
         "d" : "2019-12-13 18:55",
         "u" : 200.0
         "d" : "2019-12-13 19:00",
         "u" : 180.0
         "d" : "2019-12-13 19:05",
         "u" : 202.0
         "d" : "2019-12-13 19:10",
         "u" : 178.0
         "d" : "2019-12-13 19:15",
         "u" : 101.0
         "d" : "2019-12-13 19:20",
         "u" : 181.0
         "d" : "2019-12-13 19:25",
         "u" : 102.0
         "d" : "2019-12-13 19:30",
         "u" : 156.0
         "d" : "2019-12-13 19:35",
         "u" : 162.0
         "d" : "2019-12-13 19:40",
         "u" : 101.0
         "d" : "2019-12-13 19:45",
         "u" : 101.0
         "d" : "2019-12-13 19:50",
         "u" : 228.0
         "d" : "2019-12-13 19:55",
         "u" : 193.0
         "d" : "2019-12-13 20:00",
         "u" : 208.0
         "d" : "2019-12-13 20:05",
         "u" : 135.0
         "d" : "2019-12-13 20:10",
         "u" : 124.0
         "d" : "2019-12-13 20:15",
         "u" : 126.0
         "d" : "2019-12-13 20:20",
         "u" : 110.0
         "d" : "2019-12-13 20:25",
         "u" : 115.0
         "d" : "2019-12-13 20:30",
         "u" : 187.0
         "d" : "2019-12-13 20:35",
         "u" : 115.0
         "d" : "2019-12-13 20:40",
         "u" : 101.0
         "d" : "2019-12-13 20:45",
         "u" : 123.0
         "d" : "2019-12-13 20:50",
         "u" : 101.0
         "d" : "2019-12-13 20:55",
         "u" : 255.0
         "d" : "2019-12-13 21:00",
         "u" : 101.0
         "d" : "2019-12-13 21:05",
         "u" : 102.0
         "d" : "2019-12-13 21:10",
         "u" : 108.0
         "d" : "2019-12-13 21:15",
         "u" : 108.0
         "d" : "2019-12-13 21:20",
         "u" : 129.0
         "d" : "2019-12-13 21:25",
         "u" : 183.0
         "d" : "2019-12-13 21:30",
         "u" : 166.0
         "d" : "2019-12-13 21:35",
         "u" : 87.0
         "d" : "2019-12-13 21:40",
         "u" : 70.0
         "d" : "2019-12-13 21:45",
         "u" : 70.0
         "d" : "2019-12-13 21:50",
         "u" : 83.0
         "d" : "2019-12-13 21:55",
         "u" : 152.0
         "d" : "2019-12-13 22:00",
         "u" : 81.0
         "d" : "2019-12-13 22:05",
         "u" : 70.0
         "d" : "2019-12-13 22:10",
         "u" : 95.0
         "d" : "2019-12-13 22:15",
         "u" : 101.0
         "d" : "2019-12-13 22:20",
         "u" : 150.0
         "d" : "2019-12-13 22:25",
         "u" : 143.0
         "d" : "2019-12-13 22:30",
         "u" : 69.0
         "d" : "2019-12-13 22:35",
         "u" : 69.0
         "d" : "2019-12-13 22:40",
         "u" : 55.0
         "d" : "2019-12-13 22:45",
         "u" : 55.0
         "d" : "2019-12-13 22:50",
         "u" : 54.0
         "d" : "2019-12-13 22:55",
         "u" : 53.0
         "d" : "2019-12-13 23:00",
         "u" : 131.0
         "d" : "2019-12-13 23:05",
         "u" : 53.0
         "d" : "2019-12-13 23:10",
         "u" : 53.0
         "d" : "2019-12-13 23:15",
         "u" : 57.0
         "d" : "2019-12-13 23:20",
         "u" : 137.0
         "d" : "2019-12-13 23:25",
         "u" : 53.0
         "d" : "2019-12-13 23:30",
         "u" : 51.0
         "d" : "2019-12-13 23:35",
         "u" : 50.0
         "d" : "2019-12-13 23:40",
         "u" : 51.0
         "d" : "2019-12-13 23:45",
         "u" : 140.0
         "d" : "2019-12-13 23:50",
         "u" : 51.0
         "d" : "2019-12-13 23:55",
         "u" : 51.0
         "d" : "2019-12-14 00:00",
         "u" : 51.0
         "d" : "2019-12-14 00:05",
         "u" : 51.0
         "d" : "2019-12-14 00:10",
         "u" : 52.0
         "d" : "2019-12-14 00:15",
         "u" : 52.0
         "d" : "2019-12-14 00:20",
         "u" : 132.0
         "d" : "2019-12-14 00:25",
         "u" : 52.0
         "d" : "2019-12-14 00:30",
         "u" : 51.0
         "d" : "2019-12-14 00:35",
         "u" : 52.0
         "d" : "2019-12-14 00:40",
         "u" : 77.0
         "d" : "2019-12-14 00:45",
         "u" : 51.0
         "d" : "2019-12-14 00:50",
         "u" : 138.0
         "d" : "2019-12-14 00:55",
         "u" : 51.0
         "d" : "2019-12-14 01:00",
         "u" : 52.0
         "d" : "2019-12-14 01:05",
         "u" : 51.0
         "d" : "2019-12-14 01:10",
         "u" : 58.0
         "d" : "2019-12-14 01:15",
         "u" : 58.0
         "d" : "2019-12-14 01:20",
         "u" : 59.0
         "d" : "2019-12-14 01:25",
         "u" : 134.0
         "d" : "2019-12-14 01:30",
         "u" : 53.0
         "d" : "2019-12-14 01:35",
         "u" : 47.0
         "d" : "2019-12-14 01:40",
         "u" : 47.0
         "d" : "2019-12-14 01:45",
         "u" : 46.0
         "d" : "2019-12-14 01:50",
         "u" : 46.0
         "d" : "2019-12-14 01:55",
         "u" : 102.0
         "d" : "2019-12-14 02:00",
         "u" : 105.0
         "d" : "2019-12-14 02:05",
         "u" : 46.0
         "d" : "2019-12-14 02:10",
         "u" : 47.0
         "d" : "2019-12-14 02:15",
         "u" : 46.0
         "d" : "2019-12-14 02:20",
         "u" : 128.0
         "d" : "2019-12-14 02:25",
         "u" : 46.0
         "d" : "2019-12-14 02:30",
         "u" : 45.0
         "d" : "2019-12-14 02:35",
         "u" : 46.0
         "d" : "2019-12-14 02:40",
         "u" : 45.0
         "d" : "2019-12-14 02:45",
         "u" : 46.0
         "d" : "2019-12-14 02:50",
         "u" : 127.0
         "d" : "2019-12-14 02:55",
         "u" : 45.0
         "d" : "2019-12-14 03:00",
         "u" : 46.0
         "d" : "2019-12-14 03:05",
         "u" : 45.0
         "d" : "2019-12-14 03:10",
         "u" : 131.0
         "d" : "2019-12-14 03:15",
         "u" : 46.0
         "d" : "2019-12-14 03:20",
         "u" : 46.0
         "d" : "2019-12-14 03:25",
         "u" : 46.0
         "d" : "2019-12-14 03:30",
         "u" : 46.0
         "d" : "2019-12-14 03:35",
         "u" : 47.0
         "d" : "2019-12-14 03:40",
         "u" : 126.0
         "d" : "2019-12-14 03:45",
         "u" : 47.0
         "d" : "2019-12-14 03:50",
         "u" : 46.0
         "d" : "2019-12-14 03:55",
         "u" : 47.0
         "d" : "2019-12-14 04:00",
         "u" : 129.0
         "d" : "2019-12-14 04:05",
         "u" : 46.0
         "d" : "2019-12-14 04:10",
         "u" : 47.0
         "d" : "2019-12-14 04:15",
         "u" : 47.0
         "d" : "2019-12-14 04:20",
         "u" : 45.0
         "d" : "2019-12-14 04:25",
         "u" : 47.0
         "d" : "2019-12-14 04:30",
         "u" : 46.0
         "d" : "2019-12-14 04:35",
         "u" : 46.0
         "d" : "2019-12-14 04:40",
         "u" : 128.0
         "d" : "2019-12-14 04:45",
         "u" : 47.0
         "d" : "2019-12-14 04:50",
         "u" : 46.0
         "d" : "2019-12-14 04:55",
         "u" : 46.0
         "d" : "2019-12-14 05:00",
         "u" : 46.0
         "d" : "2019-12-14 05:05",
         "u" : 46.0
         "d" : "2019-12-14 05:10",
         "u" : 74.0
         "d" : "2019-12-14 05:15",
         "u" : 47.0
         "d" : "2019-12-14 05:20",
         "u" : 46.0
         "d" : "2019-12-14 05:25",
         "u" : 47.0
         "d" : "2019-12-14 05:30",
         "u" : 126.0
         "d" : "2019-12-14 05:35",
         "u" : 46.0
         "d" : "2019-12-14 05:40",
         "u" : 46.0
         "d" : "2019-12-14 05:45",
         "u" : 47.0
         "d" : "2019-12-14 05:50",
         "u" : 45.0
         "d" : "2019-12-14 05:55",
         "u" : 48.0
         "d" : "2019-12-14 06:00",
         "u" : 47.0
         "d" : "2019-12-14 06:05",
         "u" : 45.0
         "d" : "2019-12-14 06:10",
         "u" : 125.0
         "d" : "2019-12-14 06:15",
         "u" : 47.0
         "d" : "2019-12-14 06:20",
         "u" : 45.0
         "d" : "2019-12-14 06:25",
         "u" : 45.0
         "d" : "2019-12-14 06:30",
         "u" : 125.0
         "d" : "2019-12-14 06:35",
         "u" : 205.0
         "d" : "2019-12-14 06:40",
         "u" : 125.0
         "d" : "2019-12-14 06:45",
         "u" : 124.0
         "d" : "2019-12-14 06:50",
         "u" : 125.0
         "d" : "2019-12-14 06:55",
         "u" : 126.0
         "d" : "2019-12-14 07:00",
         "u" : 125.0
         "d" : "2019-12-14 07:05",
         "u" : 211.0
         "d" : "2019-12-14 07:10",
         "u" : 125.0
         "d" : "2019-12-14 07:15",
         "u" : 116.0
         "d" : "2019-12-14 07:20",
         "u" : 76.0
         "d" : "2019-12-14 07:25",
         "u" : 104.0
         "d" : "2019-12-14 07:30",
         "u" : 121.0
         "d" : "2019-12-14 07:35",
         "u" : 132.0
         "d" : "2019-12-14 07:40",
         "u" : 59.0
         "d" : "2019-12-14 07:45",
         "u" : 152.0
         "d" : "2019-12-14 07:50",
         "u" : 99.0
         "d" : "2019-12-14 07:55",
         "u" : 109.0
         "d" : "2019-12-14 08:00",
         "u" : 96.0
         "d" : "2019-12-14 08:05",
         "u" : 189.0
         "d" : "2019-12-14 08:10",
         "u" : 98.0
         "d" : "2019-12-14 08:15",
         "u" : 231.0
         "d" : "2019-12-14 08:20",
         "u" : 226.0
         "d" : "2019-12-14 08:25",
         "u" : 229.0
         "d" : "2019-12-14 08:30",
         "u" : 283.0
         "d" : "2019-12-14 08:35",
         "u" : 268.0
         "d" : "2019-12-14 08:40",
         "u" : 900.0
         "d" : "2019-12-14 08:45",
         "u" : 267.0
         "d" : "2019-12-14 08:50",
         "u" : 241.0
         "d" : "2019-12-14 08:55",
         "u" : 140.0
         "d" : "2019-12-14 09:00",
         "u" : 138.0
         "d" : "2019-12-14 09:05",
         "u" : 183.0
         "d" : "2019-12-14 09:10",
         "u" : 90.0
         "d" : "2019-12-14 09:15",
         "u" : 70.0
         "d" : "2019-12-14 09:20",
         "u" : 69.0
         "d" : "2019-12-14 09:25",
         "u" : 78.0
         "d" : "2019-12-14 09:30",
         "u" : 66.0
         "d" : "2019-12-14 09:35",
         "u" : 166.0
         "d" : "2019-12-14 09:40",
         "u" : 172.0
         "d" : "2019-12-14 09:45",
         "u" : 316.0
         "d" : "2019-12-14 09:50",
         "u" : 256.0
         "d" : "2019-12-14 09:55",
         "u" : 144.0
         "d" : "2019-12-14 10:00",
         "u" : 68.0
         "d" : "2019-12-14 10:05",
         "u" : 127.0
         "d" : "2019-12-14 10:10",
         "u" : 133.0
         "d" : "2019-12-14 10:15",
         "u" : 222.0
         "d" : "2019-12-14 10:20",
         "u" : 204.0
         "d" : "2019-12-14 10:25",
         "u" : 155.0
         "d" : "2019-12-14 10:30",
         "u" : 68.0
         "d" : "2019-12-14 10:35",
         "u" : 87.0
         "d" : "2019-12-14 10:40",
         "u" : 55.0
         "d" : "2019-12-14 10:45",
         "u" : 123.0
         "d" : "2019-12-14 10:50",
         "u" : 56.0
   "status" : "OK",
Posted: Saturday 14 December 2019 13:17
by Lokonli
I don't see any relation between the data and the graph. Can you double check you sent the right data? (it resembles your phase 2 data ...)
Then of course there still is something strange between 21:30 and 6:00.
Does Domoticz show a correct graph in that time frame?
What are the high tariff-low tariff electricity switching moments in your city?
Posted: Saturday 14 December 2019 13:45
by ykuijs
Oeps, sorry. You are correct, my bad :)
   "result" : [
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2038.0
         "u" : 0.0
         "u" : 2140.0
         "u" : 4060.0
         "u" : 3992.0
         "u" : 84.0
         "u" : 85.0
         "u" : 85.0
         "u" : 84.0
         "u" : 84.0
         "u" : 83.0
         "u" : 84.0
         "u" : 83.0
         "u" : 83.0
         "u" : 83.0
         "u" : 16.0
         "u" : 84.0
         "u" : 2090.0
         "u" : 2141.0
         "u" : 2167.0
         "u" : 86.0
         "u" : 0.0
         "u" : 22.0
         "u" : 21.0
         "u" : 21.0
         "u" : 20.0
         "u" : 20.0
         "u" : 2063.0
         "u" : 20.0
         "u" : 21.0
         "u" : 20.0
         "u" : 19.0
         "u" : 20.0
         "u" : 20.0
         "u" : 22.0
         "u" : 21.0
         "u" : 2.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2034.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2048.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 2019.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "u" : 0.0
         "d" : "2019-12-14 10:55",
         "u" : 0.0
         "d" : "2019-12-14 11:00",
         "u" : 0.0
         "d" : "2019-12-14 11:05",
         "u" : 0.0
         "d" : "2019-12-14 11:10",
         "u" : 0.0
         "d" : "2019-12-14 11:15",
         "u" : 0.0
         "d" : "2019-12-14 11:20",
         "u" : 0.0
         "d" : "2019-12-14 11:25",
         "u" : 0.0
         "d" : "2019-12-14 11:30",
         "u" : 0.0
         "d" : "2019-12-14 11:35",
         "u" : 0.0
         "d" : "2019-12-14 11:40",
         "u" : 0.0
         "d" : "2019-12-14 11:45",
         "u" : 0.0
         "d" : "2019-12-14 11:50",
         "u" : 0.0
         "d" : "2019-12-14 11:55",
         "u" : 0.0
         "d" : "2019-12-14 12:00",
         "u" : 0.0
         "d" : "2019-12-14 12:05",
         "u" : 0.0
         "d" : "2019-12-14 12:10",
         "u" : 0.0
         "d" : "2019-12-14 12:15",
         "u" : 0.0
         "d" : "2019-12-14 12:20",
         "u" : 0.0
         "d" : "2019-12-14 12:25",
         "u" : 0.0
         "d" : "2019-12-14 12:30",
         "u" : 0.0
         "d" : "2019-12-14 12:35",
         "u" : 0.0
         "d" : "2019-12-14 12:40",
         "u" : 0.0
         "d" : "2019-12-14 12:45",
         "u" : 0.0
         "d" : "2019-12-14 12:50",
         "u" : 0.0
         "d" : "2019-12-14 12:55",
         "u" : 0.0
         "d" : "2019-12-14 13:00",
         "u" : 2093.0
         "d" : "2019-12-14 13:05",
         "u" : 0.0
         "d" : "2019-12-14 13:10",
         "u" : 0.0
         "d" : "2019-12-14 13:15",
         "u" : 0.0
         "d" : "2019-12-14 13:20",
         "u" : 0.0
         "d" : "2019-12-14 13:25",
         "u" : 0.0
   "status" : "OK",
The high/low tariff switching moments are: Evening 23.00, morning 7.00.
The x-axis for the first two phases is exactly the same, but the third is different:
The graph for that timeframe in Domoticz is displaying correctly:
Posted: Saturday 14 December 2019 17:44
by Lokonli
Thank, clear.
All 0 values disappeared.
I've made a fix in latest beta. Can you test again?
Posted: Saturday 14 December 2019 19:10
by ykuijs
Yes, that worked like a charm!! This also fixed the min/max values for the "Afgelopen maand" graph (monthly graphs don't show the average data points (u), but the min/max values (u_min and u_max)). So far that only showed the max values, since the min values had a value of 0. Now the graph shows two lines (one max/one min), just like it does in Domoticz!
Thanks a million!
Posted: Saturday 14 December 2019 19:18
by Lokonli
Good! Thanks for the feedback.
Posted: Sunday 19 July 2020 16:28
by mojojojo490
Hi @ykuis
Can you post your final code? So we can see what solution you have made?
