scripts stop working after some time
Posted: Wednesday 04 December 2019 21:37
by snellejellep
platform: raspberry pi
domoticz version: 4.11506
after some time all scripts stop working and i get this log message:
2019-12-04 19:44:06.954 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
what can be wrong?
when i restart domoticz it all works again for some time
just updated again to the latest beta, hope it will be better.
(v 4.11550)
Re: scripts stop working after some time
Posted: Wednesday 04 December 2019 22:14
by waaren
snellejellep wrote: Wednesday 04 December 2019 21:37
This can be caused by a busy system, -a database lock or -a dzVents user script waiting for an OS call to return and blocking the event system during that wait. It might help to look at the domoticz and system logfile to see what happens in the seconds before this message. Also running a monitoring tool like top or htop could reveal something.
In it self this message should not be too alarming if it only happens a couple of times a day. I see it around the times my test systems make a backup using the domoticz auto backup mechanism.
Re: scripts stop working after some time [SOLVED]
Posted: Thursday 05 December 2019 13:18
by snellejellep
thank you, have not had it happen since the update to the latest beta.
for future things, where can i find the system and domoticz log files?
Posted: Thursday 05 December 2019 14:55
by waaren
snellejellep wrote: Thursday 05 December 2019 13:18
The domoticz logfile location and other settings are defined in
/etc/init.d/domoticz.sh
the relevant settings are in set to the DAEMON_ARGS var.
as example you could change the file like this
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log" # or any other OS file
#DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error, debug" # debug disabled for now
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error" # these loglevels will make it to th elogfile
#DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id"
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz start
sudo tail -f /var/log/domoticz.log
The system and other logfiles can be found with sudo ls -lrt /var/log/*log
Posted: Thursday 05 December 2019 17:07
by snellejellep
thank you, i will take a look over there once it goes wrong again
