Add device from node
Posted: Tuesday 03 December 2019 10:03
Hi All,
New to this forum. Just started Domoticz and I'm very stoked on getting things done. I read a lot of people are way ahead of me, but I see that as learning points.
I have domoticz running on my Synology NAS with an AEON Z-Wave stick. Currently, I only have one device, but while recontructing my home, I will be adding more stuff. I started out bad with several things not working as it should be, but after reading a lot, it seems the last stable version did not recognize my Fibaro switch very well. I upgraded to the current beta, and the switch is showing under de stick's setup tap (nodes):
012 (0x0c) Dining Room FIBARO System FGS223 Double Relay+ FIBARO System 0x1000 0x0203 2019-12-03 09:59:18 No Heal node
011 (0x0b) Unknown Unknown: id=0000 Unknown: type=0000, id=0000 Unknown: id=0000 0x0000 0x0000 2019-12-03 09:16:32 No Heal node
007 (0x07) Unknown Unknown: id=0000 Unknown: type=0000, id=0000 Unknown: id=0000 0x0000 0x0000 2019-12-03 09:16:32 No Heal node
006 (0x06) Unknown Unknown: id=0000 Unknown: type=0000, id=0000 Unknown: id=0000 0x0000 0x0000 2019-12-03 09:16:32 No Heal node
005 (0x05) Unknown Unknown: id=0000 Unknown: type=0000, id=0000 Unknown: id=0000 0x0000 0x0000 2019-12-03 09:16:32 No Heal node
004 (0x04) Unknown Unknown: id=0000 Unknown: type=0000, id=0000 Unknown: id=0000 0x0000 0x0000 2019-12-03 09:16:32 No Heal node
001 (0x01) Controller AEON Labs ZW090 Z-Stick Gen5 EU AEON Labs 0x005a 0x0001 2019-12-03 09:16:32 No Heal node
I have no clue what nodes 004, 005, 006, 007 and 011 are, but they must be some sort of sub-devices or something.
As you can see, the FIBARO FGS223 is showing up fine. Both lights work with the wall switches, so the device is setup as it should.
When I go to devices in Domoticz, I can only see the AEON stick.
Relevant info from the logging is this:
2019-12-03 09:16:42.270 Error: OpenZWave: Internal Node ValueID not found! NodeID: 12 (0x0c), instanceID: 44
How do I add this switch to my devices? Should I remove it somehwere and re-add it? I'm a bit stuck.
