X10 mochad com error detection
Posted: Sunday 01 December 2019 10:24
I see that my old CM15Pro about once a month dies on me.. and domoticz cannot access the controller anymore and since i still have all kind of X10 devices in use i loose a lot of functionality.
I wrote a dz event script that checks the domoticz error log and if 5 communication errors occure in a row, resets my pi to get communication again.
I have made a uservariable MochadError to count, since I did not get the dz even data working properly
hope this might help others out!
i still need to figure out how to just reintialize the USB communication instead of a full reboot
myHttpResponse = "getDomoticzErrorLog"
PRINT_MODE = false
DEBUG_MODE = false
on = { httpResponses = { myHttpResponse },
timer = { "every 2 minutes"}
logging = { level = domoticz.LOG_DEBUG,
marker = "getStr from log"
data = { lastlogtime = { initial = 0 },
counter = { initial = 0 }
execute = function(dz, trigger)
MochadCounter = dz.variables('MochadError').value
if (PRINT_MODE==true) then
dz.log("MochadCounter " .. MochadCounter)
local searchStr = "Error: Mochad: Can not connect to: 127.0.0.1:1099" -- Change to reflect the messages you want to catch
local function askDomoticzForLogLines()
local lastLogTime = dz.data.lastlogtime -- get time last logrequest
local logLevel = 4 -- loglevel (1=normal,2=Status,4=error,268435455=all
local jsonString = "/json.htm?type=command" ..
"¶m=getlog" ..
"&lastlogtime=" .. tostring(lastLogTime) ..
"&loglevel=" .. tostring(logLevel)
local logURL = dz.settings["Domoticz url"] .. jsonString
dz.openURL ({ url = logURL,
method = "GET",
callback = myHttpResponse
dz.data.lastlogtime = dz.time.dDate -- store current Time as seconds from epoch
local function findString()
if trigger.json.result ~= nil then -- Only when there are errormessages in the log
local resultTable = trigger.json.result
for i = #resultTable,1,-1 do -- traverse backwards to get latest violation first
local s = resultTable[i].message
local found = s:find(searchStr,1,true) -- searcg plain string starting at pos 1 (no pattern)
local dzVents = s:find("dzVents")
if found and not(dzVents) then
return true
if trigger.isDevice or trigger.isTimer then
askDomoticzForLogLines() -- get the relevant loglines
elseif trigger.ok then
if (DEBUGT_MODE==true) then
dz.log("Show ALL: \n" .. trigger.data,dz.LOG_DEBUG)
if findString() then
dz.log("string " .. searchStr .. " found! ",dz.LOG_DEBUG)
dz.notify('No signal from Mochad, increasing error counter',dz.PRIORITY_LOW)
MochadCounter = MochadCounter + 1
dz.variables('MochadError').set(MochadCounter)
if (MochadCounter == 5) then
MochadCounter = 0
sleep(2)
dz.log('5 errors from mochad, rebooting system')
dz.devices('Reboot').switchOn()
os.execute('sudo reboot')
dz.log("No (new) occurrences of string " .. searchStr .. " in the domoticz log ",dz.LOG_DEBUG)
MochadCounter = 0
dz.log("Access problem to log. Data found: " .. trigger.data,dz.LOG_ERROR)
}i still need to figure out how to just reintialize the USB communication instead of a full reboot
