Using SQLite3 with LUA script
Froggy
Post by Froggy »
I'm trying to use an external SQLite3 DB with a lua script running under domoticz. Maybe i forget something but most of function seems to not work.
db:execute("INSERT INTO temperature (date, heure, temperature) VALUES (date('now', 'localtime'), time('now', 'localtime'), '0.1')")
Work, but :
db:exec("INSERT INTO temperature (date, heure, temperature) VALUES (date('now', 'localtime'), time('now', 'localtime'), '0.1')")
Don't work.
it's same for :
db:nrows
db:rows
and more. Is it a limitation of domoticz or did i miss something ?
Thanks in advance,
aleph0
Domoticz version: 11838
Re: Using SQLite3 with LUA script
Post by aleph0 »
I've had many problems trying to access the dB that way including, when things seems to work, memory leaks crashing domoticz every once and then.
I use now the quick'n dirty workaround os.execute('sqlite3 domoticz.db "SQL statement"') or os.capture if I need some result back. This has been working like a charm for years
I made this choice a few years ago and I didn't try again the other ways, so things may have improved since then...
Envoyé de mon moto g(6) en utilisant Tapatalk
Froggy
Post by Froggy »
Hi !
Will take a look on it, it's crappy
