Part of script does not work
Posted: Wednesday 27 November 2019 16:57
by Havym
Hello everyone,
I am new to using domoticz
V4.11468
Build Hash: 508cc66a1
Build Date: 2019-11-05 16:05:44
and I like it so far. I started to study the Lua scripts and dzVents.
I get the code below working half way and I get no errors.
I use a hacked tone and when the burner(Branderinfo) comes on, the floor heating pump (Kaku switch 'Vloerverwarming') also comes on.
If the burner goes out, the pump continues to run for an hour and then goes out.
This part of the script works.
Next, i tried but didn't get it to work, if the burner does not start due to summer, the pump will start running if 'Vloerverwarming' is off for 24 hours for at least 1 hour to prevent from getting stuck.
Can you tell me what I'm doing wrong?
devices = {'ToonBranderInfo','Vloerverwarming'},
if domoticz.devices('ToonBranderInfo').levelName == 'CV'
then
domoticz.log('Brander is aan!')
local Vloerverwarming = domoticz.devices('Vloerverwarming')
Vloerverwarming.switchOn()
domoticz.log('Brander is uit!')
Vloerverwarming.switchOff().afterHour(1)
if domoticz.devices('Vloerverwarming').state == 'Off'
then
domoticz.log('Vloerverwarming pompt even rond door inactiviteit')
Vloerverwarming.switchOn().afterHour(24).forHour(1)
Re: Part of script does not work
Posted: Wednesday 27 November 2019 19:09
by waaren
Havym wrote: Wednesday 27 November 2019 16:57
.... Next, i tried but didn't get it to work, if the burner does not start due to summer, the pump will start running if 'Vloerverwarming' is off for 24 hours for at least 1 hour to prevent from getting stuck.
Can you check this one ?
local summer = '1/5-30/9'
return
on =
devices = { 'ToonBranderInfo'},
timer = { 'at 03:19 on ' .. summer},
logging =
level = domoticz.LOG_DEBUG
_G.logMarker = _G.moduleLabel
if item.isDevice then
if domoticz.devices('ToonBranderInfo').levelName == 'CV' then
Vloerverwarming.switchOn().checkFirst()
elseif Vloerverwarming.state == 'On' then
else -- triggered by timer
Re: Part of script doenst work
Posted: Wednesday 27 November 2019 20:10
by Havym
Thank you for your answer. I'm a newby with scripting in any language lol
I need to study your way thats for sure..
I will give it a try.
So if i understand you correctly.. the activation for the vloerverwarming in summer needs a time trigger instead of afterHour()?
What is _G.logMarker and _G.moduleLabel? Can this be found in the manual?
Do i need the checkfirst option for a kaku? Action switches dont give a responce back what state their in.
A lot of questions, i know but with dzVents script you can create more options then with blocky.
Posted: Thursday 28 November 2019 0:20
by waaren
Havym wrote: Wednesday 27 November 2019 20:10
There are many ways to do things in any script- or programming language. I think that for your requirement this is a workable solution but I am sure there will be other ways. Just pick one that suits you
_G is the global Lua table. logMarker is used as prefix for dzVents log lines and moduleLabel is the name of the script. So what I do here is set the log prefix equal to the scriptname. Both these variables are used in dzVents runtime modules (<domoticz dir>/dzVents/runtime/*.lua)
Do i need the checkFirst() option for a kaku? Action switches don't give a response back what state their in.
You don't need the option but is kind of short for
if device.state ~= 'Off' then device.switchOff() end
so it prevents unnecessary signals and change of lastUpdated timestamps (not only for KlikAan KlikUit)
Sure. That's why I post a lot of examples. Maybe it will help other forum members to enjoy domoticz / dzVents even more.
Posted: Thursday 28 November 2019 12:17
by Havym
Some things i understand and some things i don't.
I tried your way of scripting and it works. The vloerverwarming turns on if Brander is on and shuts off an hour after stopping brander.
The other part where the vloerverwarming runs in summer time i didn't explain very wel. Summer time was an example why i would like to run the vloerverwarming 1 hour in 24 hours. But i need it to work in (not only summer) holidays of long weekends away when brander is off too because we are not at home.
Next, i tried but didn't get it to work, if the burner does not start due to staying off or long summer, the pump will start running if 'Vloerverwarming' is off for 24 hours for at least 1 hour to prevent from getting stuck.
So if the vloerverwarming has not been turn on in 24 hours i would like to turn it on for 1 hour. Specific time is not necessary but can be useful(middle of the night). The script i put in the starttopic didn't work.
Sorry for the misunderstanding.
Posted: Friday 29 November 2019 9:58
by Havym
Ik denk dat ik het gevonden heb.
Ooops, english. I think i found it
return
on =
logging =
elseif Vloerverwarming.state == 'Off' then
domoticz.log('Pomp moet even draaien')
This is the result in the log
Status: dzVents: Info: ------ Start internal script: Vloerverwarming test: Device: "ToonBranderInfo (Dummy)", Index: 50
Status: dzVents: Debug: Vloerverwarming test: Processing device-adapter for Vloerverwarming: Switch device adapter
Status: dzVents: Info: Vloerverwarming test: Pomp moet even draaien
Status: dzVents: Debug: Vloerverwarming test: Constructed timed-command: On
Status: dzVents: Debug: Vloerverwarming test: Constructed timed-command: On AFTER 86400 SECONDS
Status: dzVents: Debug: Vloerverwarming test: Constructed timed-command: On AFTER 86400 SECONDS FOR 3600 SECONDS
Status: dzVents: Info: Vloerverwarming test: ------ Finished Vloerverwarming test
Status: dzVents: Debug: Commands sent to Domoticz:
Status: dzVents: Debug: - Vloerverwarming = On AFTER 86400 SECONDS FOR 3600 SECONDS
Status: dzVents: Debug: =====================================================
Re: Part of script does not work [Solved]
Posted: Friday 29 November 2019 10:19
by waaren
Havym wrote: Friday 29 November 2019 9:58
This will work in normal situations but will not do it's job when domoticz gets restarted in summer. The afterHour(24) will not work after that restart and the script will only be retriggered when it gets cold.
Maybe lastUpdate can help.
return
on =
timer = { 'at 03:19'},
logging =
elseif Vloerverwaming.lastUpdate.hoursAgo > 22 then -- true when triggered by timer and Vloerverwarming not active in last 23-24 hours
Posted: Friday 29 November 2019 11:54
by Havym
Maybe a stupid question but why is domoticz restarted in summer in my script?
I will try your script, thanks.
Edit: it gives me an error
Error: dzVents: Error: (2.5.0) error loading module 'Vloerverwarming test' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Vloerverwarming test.lua':
scripts/dzVents/generated_scripts/Vloerverwarming test.lua:28: 'then' expected near 'Vloerverwarming'
Edit: got it. Copy paste error. 'then' is missing in your script.
Posted: Friday 29 November 2019 14:14
by waaren
Havym wrote: Friday 29 November 2019 11:54
Domoticz is not restarted by your script; that is not what I meant. Let me try to explain.
First thing to understand is that any scheduled actions from commands like afterXXX, forXXX and the likes are stored in memory and not in the database. So if you say to domoticz do action-A after 24 hours it will store that in memory and when the time comes it will do action-A.
But if domoticz is restarted for whatever reason (new version, system reboot, etc..), it will start without the schedule for action-A in memory.
Hope this will make it more clear for you.
Posted: Friday 29 November 2019 16:03
by Havym
Thank you so much for your explanation. I understand now. 24 hours is to far away to be stored in memory because everything can happen. This kind of action should be stored in the database so when RPi restart for whatever reason (maybe power loss) it keeps the action.
Thank you for your help, i will study the script en try to make a new script for something else. Convert a blocky to DzVents with some extra's.
Posted: Friday 29 November 2019 16:48
by waaren
Havym wrote: Friday 29 November 2019 16:03
If you need this for whatever reason and do not want a script with a time trigger then you could also set a timer on the device itself. These timers are stored in the database. I prefer script time triggers because of the possibility to use additional conditions.
