dimming a group
Posted: Wednesday 27 November 2019 16:52
by snellejellep
i tried making a script which allows a dimmer switch control and dim a group.
simple on/off worked but i tried reading this script and use some things to let the group dim: https://www.domoticz.com/forum/viewtopi ... 28&t=23568
but unfortunately i get this error and i have no clue:
2019-11-27 16:51:02.266 Error: dzVents: Error: (2.5.0) An error occurred when calling event handler knop group tk
2019-11-27 16:51:02.266 Error: dzVents: Error: (2.5.0) ...ticz/scripts/dzVents/generated_scripts/knop group tk.lua:14: attempt to index a nil value (field 'data')
this is the script:
		devices = {
			'Tuinkamer licht'
	execute = function(dz, device)
		dz.log('Device ' .. device.name .. ' was changed', dz.LOG_INFO)
		local switch        = dz.devices("Tuinkamer licht")
		local group         = dz.groups("Tuinkamer licht")
		if switch.state == "On" and switch.level > 0 then
		    dz.data.dimLevel =  switch.level
		    group.switchOn()
		    group.dimTo(tonumber(dz.data.dimLevel))
		elseif switch.state == "Off" then
		    group.switchOff()
i hope someone can help me
Re: dimming a group
Posted: Wednesday 27 November 2019 17:10
by zicht
As far as i know a group cannot be dimmed, lamps can be dimmed.
What you can do is read one switch (define that as somekind of a group master in your thoughts)
Then with a script like above change the dimming value based on that master switch value for every individual lamp :)
Maybe that way it will work.
Not sure how it works in dzevents
in lua it would be something like
a=otherdevices["lamp1"]
commandArray["lamp2"]=a
commandArray["lamp3"]=a
commandArray["lamp4"]=a
this way the value of lamp1 will be copied to the others :)
Re: dimming a group
Posted: Wednesday 27 November 2019 17:33
by snellejellep
zicht wrote: Wednesday 27 November 2019 17:10 As far as i know a group cannot be dimmed, lamps can be dimmed.
you can with a script, i tried before and it seems to work.
unfortunately i do not know lua, all my scripts are in dzvents
Re: dimming a group
Posted: Wednesday 27 November 2019 18:00
by zicht
"you can with a script, i tried before and it seems to work."
Maybe you can use same approach in DZ ? dimm all lamps upon value change ?
Re: dimming a group
Posted: Wednesday 27 November 2019 18:03
by snellejellep
zicht wrote: Wednesday 27 November 2019 18:00 "you can with a script, i tried before and it seems to work."
yes but i need to extract the current value of the switch and use that value to dim the group to that value
the only thing is i do not know how to do that... setting a static dimmed value i do know but this i don't ant that is exactly my question, how do i do that in dzvents
Re: dimming a group
Posted: Wednesday 27 November 2019 18:50
by waaren
snellejellep wrote: Wednesday 27 November 2019 18:03 yes but i need to extract the current value of the switch and use that value to dim the group to that value
Something like this ?
return
    on =
        devices =
            'Tuinkamer licht' -- device Trigger
    logging =
        level = domoticz.LOG_DEBUG
    execute = function(dz, item)
        _G.logMarker =  _G.moduleLabel
        local myGroup = dz.groups('Tuinkamer licht') -- Confusing ! Can you rename device or group ?
        if item.state ~= 'Off' and item.level > 0 then
            myGroup.devices().forEach(function(dv)
                dz.log(dv.name ..' ==>> device-level: ' .. dv.level,dz.LOG_FORCE)
                dv.dimTo(item.level)
           end)
        elseif item.state == 'Off' then
            dz.log(item.name ..'; state: ' .. item.state,dz.LOG_FORCE)
            myGroup.switchOff()
Re: dimming a group  [Solved]
Posted: Wednesday 27 November 2019 19:32
by snellejellep
waaren wrote: Wednesday 27 November 2019 18:50
great! that is exactly what i was looking for!
Re: dimming a group
Posted: Friday 15 May 2020 8:41
by dheuts
Thanks a lot for this script, great.
I'm looking for some script like this, to control the color temperature (Kelvin) of a group (RGBWW).
Can someone please help me with this? I think we have to do something in the script with:
getColor
SetKelvin
But I'm not sure how to get this running. Is it possible with the same device as the brightness slider? Or do we need another one?
UPDATE: Got it running with this script:
viewtopic.php?f=59&t=29498&p=247523#p224734
return
    on =
        devices =
    logging =
           end)
            myGroup.switchOff()
