Moving from pi 2 with Zipigate to p3 with Zigate usb
Posted: Sunday 24 November 2019 15:38
I am migrating from pi 2 with Zipigate to p3 with Zigate usb.
I try to get the data about the lights over by copy the devicelist txt file. I copy paste the lines from the old pi to the new one (DeviceList 29.txt)
But i get these errors in de log :
What am i doing wrong?
Greets Gijs
2019-11-24 15:27:54.142 Status: PluginSystem: Entering work loop.
2019-11-24 15:27:54.603 Status: (Zigate ) Entering work loop.
2019-11-24 15:27:54.604 Status: (Zigate ) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-11-24 15:27:54.610 Status: (Zigate ) Zigate plugin stable-4.5.6 started
2019-11-24 15:27:54.610 Status: (Zigate ) Python Version - 3.7.3 (default, Apr 3 2019, 05:39:12)
2019-11-24 15:27:54.610 [GCC 8.2.0]
2019-11-24 15:27:54.610 Status: (Zigate ) Switching Heartbeat to 5 s interval
2019-11-24 15:27:54.610 Status: (Zigate ) DomoticzVersion: 4.11474
2019-11-24 15:27:54.610 Status: (Zigate ) DomoticzHash: 12feb06f1
2019-11-24 15:27:54.610 Status: (Zigate ) DomoticzBuildTime: 2019-11-08 16:33:53
2019-11-24 15:27:54.610 Status: (Zigate ) load PluginConf
2019-11-24 15:27:54.612 Status: (Zigate ) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-29.json
2019-11-24 15:27:54.612 Status: (Zigate ) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-24 15:27:54.612 Status: (Zigate ) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-24 15:27:54.612 Status: (Zigate ) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-11-24 15:27:54.612 Status: (Zigate ) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-11-24 15:27:54.612 Status: (Zigate ) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-24 15:27:54.612 Status: (Zigate ) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-11-24 15:27:54.612 Status: (Zigate ) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-11-24 15:27:54.612 Status: (Zigate ) Opening DomoticzDB in raw
2019-11-24 15:27:54.617 Status: (Zigate ) Plugin Database: DeviceList-29.txt
2019-11-24 15:27:54.638 Status: (Zigate ) DeviceConf loaded
2019-11-24 15:27:54.638 Status: (Zigate ) load ListOfDevice
2019-11-24 15:27:54.654 Status: (Zigate ) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-29.txt : 0
2019-11-24 15:27:54.655 Status: (Zigate ) Transport mode: USB
2019-11-24 15:27:54.656 Status: (Zigate ) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2019-11-24 15:27:54.668 Status: (Zigate ) Zigate set Time Server
2019-11-24 15:27:54.668 Status: (Zigate ) Configure Permit To Join
2019-11-24 15:27:54.668 Status: (Zigate ) Request Accepting new Hardware for ever
2019-11-24 15:27:54.668 Status: (Zigate ) Trigger a Topology Scan
2019-11-24 15:27:54.668 Status: (Zigate ) Trigger a Energy Level Scan
2019-11-24 15:27:54.669 Status: (Zigate ) Network Energy Level Report: 0000
2019-11-24 15:27:54.669 Status: (Zigate ) -----------------------------------------------
2019-11-24 15:27:54.669 Status: (Zigate ) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-11-24 15:27:54.765 Status: Python EventSystem: Initalizing event module.
2019-11-24 15:27:54.765 Status: EventSystem: Started
2019-11-24 15:27:54.765 Status: EventSystem: Queue thread started...
2019-11-24 15:27:54.773 Status: (Zigate ) Major Version Num: 0003
2019-11-24 15:27:54.773 Status: (Zigate ) Installer Version Number: 031a
2019-11-24 15:27:54.851 Status: dzVents: Info: Handling events for: "Bell", value: "On"
2019-11-24 15:27:54.851 Status: dzVents: Info: ------ Start internal script: Bell tussen: Device: "Bell (Gateway 16)", Index: 519
2019-11-24 15:27:54.851 Status: dzVents: Info: ------ Finished Bell tussen
2019-11-24 15:27:54.883 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:27:54.650 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': '', 'MacCapa': '80', 'Attributes List': {}, 'Manufacturer': '', 'ReadAttributes': {'TimeStamps': {'01-0006': 1565965036}, 'Ep': {'01': {'0000': {'0005': '$
2019-11-24 15:27:54.650 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': 'FFD', 'MacCapa': '8e', 'Attributes List': {'Ep': {'01': {'0003': {'fffd': '21', '0000': '21'}, '0b05': {'0107': '21', '0000': '21', '0106': '21', '0100':$
2019-11-24 15:27:54.651 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': 'FFD', 'MacCapa': '8e', 'Attributes List': {'Ep': {'01': {'0b05': {'0107': '21', '0000': '21', '0106': '21', '0100': '23', '0101': '23'}, '0004': {'fffd':$
2019-11-24 15:27:54.652 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': 'FFD', 'MacCapa': '8e', 'Attributes List': {'Ep': {'01': {'0003': {'fffd': '21', '0000': '21'}, '0b05': {'0107': '21', '0000': '21', '0106': '21', '0100':$
2019-11-24 15:27:54.652 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': '', 'MacCapa': '80', 'Attributes List': {}, 'Manufacturer': '', 'ReadAttributes': {'TimeStamps': {'01-0006': 1565964161}, 'Ep': {'01': {'0406': {'0000': '$
2019-11-24 15:27:54.653 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': '', 'MacCapa': '80', 'Attributes List': {}, 'Manufacturer': '', 'ReadAttributes': {'TimeStamps': {'01-0406': 0, '01-0006': 1565964466}, 'Ep': {'01': {'040$
2019-11-24 15:27:54.653 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': '', 'MacCapa': '80', 'Attributes List': {}, 'Manufacturer': '', 'ReadAttributes': {}, 'ZDeviceName': '', 'ZCL Version': '', 'ProfileID': 'c05e', 'Status':$
2019-11-24 15:27:54.653 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': 'FFD', 'MacCapa': '8e', 'Attributes List': {'Ep': {'01': {'0004': {'fffd': '21', '0000': '18'}, '0003': {'fffd': '21', '0000': '21'}, '0000': {'0003': '20$
2019-11-24 15:27:54.653 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': 'FFD', 'MacCapa': '8e', 'Attributes List': {'Ep': {'01': {'0b05': {'0107': '21', '0000': '21', '0106': '21', '0100': '23', '0101': '23'}, '0004': {'fffd':$
2019-11-24 15:27:54.654 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': 'FFD', 'MacCapa': '8e', 'Attributes List': {'Ep': {'01': {'0b05': {'0107': '21', '0000': '21', '0106': '21', '0100': '23', '0101': '23'}, '0004': {'fffd':$
2019-11-24 15:27:54.654 Error: (Zigate ) LoadDeviceList failed on {'DeviceType': '', 'MacCapa': '80', 'Attributes List': {}, 'Manufacturer': '', 'ReadAttributes': {'TimeStamps': {'01-0006': 1565295228}, 'Ep': {'01': {'0000': {'0001': '$
2019-11-24 15:27:54.654 Error: (Zigate ) checkListOfDevice2Devices - Gang T - 000d6ffffe250060 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Japan Klein - 000d6ffffe1b724b not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Muurlamp T - 000d6ffffe1e31de not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - BadkamerT - 000b57fffe8ced2e not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate jezus - Voltage-0017880104f29cc9-02 - 0017880104f29cc9 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate jezus - LvlControl-0017880104f29cc9-02 - 0017880104f29cc9 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate jezus - LvlControl-0017880104f29cc9-01 - 0017880104f29cc9 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - BadkamerTT - 000b57fffeb2d124 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01 - 90fd9ffffe32ae6d not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01 - d0cf5efffeb400bc not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01 - d0cf5efffe2fa637 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - GangZ - 00158d00015efc6d not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Motion Woon Deur - 00158d0002c0924f not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Motion Slaap - 00158d0002c4c1f3 not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - KoffieZ - 00158d0001b1825d not found in Plugin Database
2019-11-24 15:27:54.655 Error: (Zigate ) checkListOfDevice2Devices - Zigate - LED1536G5_LvlControl-d0cf5efffe6d7205-01 - d0cf5efffe6d7205 not found in Plugin Database
2019-11-24 15:27:54.884 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:27:55.077 (Zigate ) Permit Join status: 01
2019-11-24 15:27:55.077 (Zigate ) ---> self.permitTojoin['Starttime']: 1574605674
2019-11-24 15:27:55.077 (Zigate ) ---> Current time : 1574605675
2019-11-24 15:27:55.077 (Zigate ) ---> self.Ping['Permit'] (prev) : None
2019-11-24 15:27:55.077 (Zigate ) ---> self.Ping['Permit'] (new ) : On
2019-11-24 15:27:55.077 Status: (Zigate ) Accepting new Hardware: On
2019-11-24 15:27:55.192 Status: (Zigate ) Zigate addresses ieee: 00158d0001edfa0d , short addr: 0000
2019-11-24 15:27:55.192 Status: (Zigate ) Network state UP, PANID: 0996 extPANID: 0x569fc2453d100479 Channel: 12
2019-11-24 15:27:55.296 Status: (Zigate ) Number of devices recently active in Zigate = 0
2019-11-24 15:27:55.397 Error: (Zigate ) LQI:LQIresp - Status: c1 for d9c10100000000
2019-11-24 15:27:56.716 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:27:56.725 (Thermosmart) Temp (room temperature)
2019-11-24 15:27:56.729 (Thermosmart) Temp (outside temperature)
2019-11-24 15:27:56.258 Status: Thermosmart: Login successfull!...
2019-11-24 15:27:59.610 (Netatmo) Temp + Humidity (Buiten 2)
2019-11-24 15:27:59.611 (Netatmo) Temp + Humidity + Baro (Binnen 2)
2019-11-24 15:27:59.612 (Netatmo) Air Quality (Binnen 2)
2019-11-24 15:27:59.612 (Netatmo) General/Sound Level (Binnen 2)
2019-11-24 15:28:04.985 (Zigate ) TxPower set to: 00
2019-11-24 15:28:04.619 Status: (Zigate ) Zigate set to Certification : CE
2019-11-24 15:28:04.620 Status: (Zigate ) Start Web Server connection
2019-11-24 15:28:04.637 Status: (Zigate ) Web backend for Web User Interface started on port: 9440
2019-11-24 15:28:04.637 Status: (Zigate ) Plugin with Zigate firmware 031a correctly initialized
2019-11-24 15:28:04.846 Status: (Zigate ) checkPluginVersion - Upgrade available: 4.5.7
2019-11-24 15:28:04.846 Status: (Zigate ) There is a newer plugin version available on gitHub
2019-11-24 15:28:23.919 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:28:23.920 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:28:27.175 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:28:27.184 (Thermosmart) Temp (room temperature)
2019-11-24 15:28:27.188 (Thermosmart) Temp (outside temperature)
2019-11-24 15:28:53.966 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:28:53.967 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:28:57.649 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:28:57.658 (Thermosmart) Temp (room temperature)
2019-11-24 15:28:57.663 (Thermosmart) Temp (outside temperature)
2019-11-24 15:29:23.998 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:29:24.000 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:29:28.124 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:29:28.133 (Thermosmart) Temp (room temperature)
2019-11-24 15:29:28.138 (Thermosmart) Temp (outside temperature)
2019-11-24 15:29:46.039 (Gateway 16) Light/Switch (Motion woon 2)
2019-11-24 15:29:46.138 Status: dzVents: Info: Handling events for: "Motion woon 2", value: "On"
2019-11-24 15:29:46.138 Status: dzVents: Info: ------ Start internal script: Iemand thuis final: Device: "Motion woon 2 (Gateway 16)", Index: 639
2019-11-24 15:29:46.140 Status: dzVents: Info: ------ Finished Iemand thuis final
2019-11-24 15:29:46.142 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-11-24 15:29:54.028 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:29:54.029 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:29:58.560 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:29:58.569 (Thermosmart) Temp (room temperature)
2019-11-24 15:29:58.574 (Thermosmart) Temp (outside temperature)
2019-11-24 15:30:24.056 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:30:24.058 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:30:29.000 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:30:29.009 (Thermosmart) Temp (room temperature)
2019-11-24 15:30:29.013 (Thermosmart) Temp (outside temperature)
2019-11-24 15:30:54.086 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:30:54.087 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:30:59.431 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:30:59.439 (Thermosmart) Temp (room temperature)
2019-11-24 15:30:59.443 (Thermosmart) Temp (outside temperature)
2019-11-24 15:31:24.114 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:31:24.115 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:31:29.887 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:31:29.895 (Thermosmart) Temp (room temperature)
2019-11-24 15:31:29.899 (Thermosmart) Temp (outside temperature)
2019-11-24 15:31:45.856 (Gateway 16) Light/Switch (Motion woon 2)
2019-11-24 15:31:45.953 Status: dzVents: Info: Handling events for: "Motion woon 2", value: "Off"
2019-11-24 15:31:45.953 Status: dzVents: Info: ------ Start internal script: Iemand thuis final: Device: "Motion woon 2 (Gateway 16)", Index: 639
2019-11-24 15:31:45.953 Status: dzVents: Info: ------ Finished Iemand thuis final
2019-11-24 15:31:54.144 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:31:54.145 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:32:00.338 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:32:00.342 (Thermosmart) Temp (room temperature)
2019-11-24 15:32:00.345 (Thermosmart) Temp (outside temperature)
2019-11-24 15:32:09.778 (Zigate ) Permit Join status: 01
2019-11-24 15:32:09.778 (Zigate ) ---> self.permitTojoin['Starttime']: 1574605674
2019-11-24 15:32:09.778 (Zigate ) ---> Current time : 1574605929
2019-11-24 15:32:09.778 (Zigate ) ---> self.Ping['Permit'] (prev) : On
2019-11-24 15:32:09.778 (Zigate ) ---> self.Ping['Permit'] (new ) : On
2019-11-24 15:32:24.173 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:32:24.174 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:32:30.795 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:32:30.804 (Thermosmart) Temp (room temperature)
2019-11-24 15:32:30.808 (Thermosmart) Temp (outside temperature)
2019-11-24 15:32:54.202 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:32:54.203 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:33:02.280 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:33:02.289 (Thermosmart) Temp (room temperature)
2019-11-24 15:33:02.294 (Thermosmart) Temp (outside temperature)
2019-11-24 15:33:14.812 Error: (Zigate ) LQI:LQIresp - Status: c1 for dac10100000000
2019-11-24 15:33:24.230 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:33:24.231 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:33:29.705 Status: (Zigate ) Network Topology report
2019-11-24 15:33:29.705 Status: (Zigate ) ------------------------------------------------------------------------------------------
2019-11-24 15:33:29.705 Status: (Zigate ) Node Node Relation Type Deepth LQI Rx-Idle
2019-11-24 15:33:29.705 Status: (Zigate ) 0000 - - - - - - TimedOut
2019-11-24 15:33:32.677 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:33:32.687 (Thermosmart) Temp (room temperature)
2019-11-24 15:33:32.691 (Thermosmart) Temp (outside temperature)
2019-11-24 15:33:54.259 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:33:54.260 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:34:03.127 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:34:03.136 (Thermosmart) Temp (room temperature)
2019-11-24 15:34:03.140 (Thermosmart) Temp (outside temperature)
2019-11-24 15:34:24.289 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:34:24.290 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:34:33.560 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:34:33.569 (Thermosmart) Temp (room temperature)
2019-11-24 15:34:33.573 (Thermosmart) Temp (outside temperature)
2019-11-24 15:34:54.319 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:34:54.320 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:35:04.002 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:35:04.011 (Thermosmart) Temp (room temperature)
2019-11-24 15:35:04.015 (Thermosmart) Temp (outside temperature)
2019-11-24 15:35:10.560 Status: Incoming connection from: 192.168.178.20
2019-11-24 15:35:24.348 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:35:24.349 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
2019-11-24 15:35:34.406 (Thermosmart) Thermostat (Setpoint)
2019-11-24 15:35:34.415 (Thermosmart) Temp (room temperature)
2019-11-24 15:35:34.423 (Thermosmart) Temp (outside temperature)
2019-11-24 15:35:54.378 Status: MQTT: Connecting to Localhost:1883
2019-11-24 15:35:54.379 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
© 2012-2019 Domoticz |
Greets Gijs
