How to get Scenes from Hue bridge Topic is solved
kas1kas
Post by kas1kas »
My Domoticz V4.10717 is not importing new scenes from the Hue bridge. In the past it did, as I have a whole lot of them in the devices.
How can I get scenes into Domoticz? Are there any tricks?
Dis-abling/En-abling does not work.
In the hardware overview under Hue, there is a slider "Add Scenes" and it is on/green, but no scenes are added.
Does anybody know?
Kranendijk
Domoticz version: 4.10717
Re: How to get Scenes from Hue bridge
Post by Kranendijk »
Same here, enabled both scenes and groups. Restarted domoticz and even re-enabled the hue. Nothimg.
snellejellep
Post by snellejellep »
mine appeared automatically...
Kranendijk
Weird, using Domoticz v4.10717 as well?
Kranendijk
Works! Removed bridge, added, registered anew, enable scenes and groups and allow new hardware in settings.
AthomeDomotica
Domoticz version: 2022.2
Post by AthomeDomotica »
Hello All,
I've done above settings....
Scenes will be available as devices, but not as scenes?
Somthing like (42 Philips Hue 000007D4 1 Scene Energize Color Switch RGBW Off)
Am I doing something wrong?
Thanks,
Mike
Domoticz, Controlicz, Philips HUE Gateway and bulbs, Z-Wave (Aecotec Stick) and Fibaro Dimmers, RFLink Gateway.
AthomeDomotica wrote: Saturday 28 December 2019 9:45 Scenes will be available as devices, but not as scenes?
Yes, the device in domoticz can be considered as a trigger for a Hue scene. It would not make sens to add it as a domoticz scene because that is meant to activate settings for multiple devices.
If you want something like that you can create a domoticz scene and add Hue devices to that scene.
AthomeDomotica
waaren wrote: Saturday 28 December 2019 10:40
Waaren,
Thanks for the reply.
I'll start with that info to make my own.
Greetings,
Mike
AthomeDomotica
Hello all,
Does somebody have examples to do this? Or a link to give me a hint?
How to set-up in combination with a "HUE Gateway"?
Thanks for you're time.
Greatings,
Mike
