dimTo not doing what I would expect.  [Solved]
bert
Post by bert »
V4.10717
Wrote a little script to switch on a dimmer at a certain level (50%) for a number of minutes when a doorbell is pressed.
If pressed again while the light is on, the light should be a tad brighter (50 + 25 = 75%).
if pressed again, the light must switch off.
For some reason though, dimTo seems to fail setting 50%...
local INPUT_DEV='Elin drukknop'
local OUTPUT ='Hue Ikea lamp PC beneden'
local INIT_LEVEL = 50
local LEVEL_STEP = 25
local DURATION = 1
		devices = {
			INPUT_DEV
	local dimmer = domoticz.devices(OUTPUT)
	if (switch.state == 'Chime') then
		domoticz.log('dimmerlevel: ' .. dimmer.level .. '; INIT_LEVEL: '.. INIT_LEVEL ..'; dimmerstate: ' .. dimmer.state , domoticz.LOG_INFO)
		if (dimmer.level == INIT_LEVEL) then
			domoticz.log('!dimmerlevel = INIT_LEVEL. dimmerlevel: ' .. dimmer.level , domoticz.LOG_INFO)
			dimmer.dimTo(dimmer.level + LEVEL_STEP)
			domoticz.log('dimmerlevel = INIT_LEVEL+LEVEL_STEP. dimmerlevel: ' .. dimmer.level , domoticz.LOG_INFO)
		elseif (dimmer.state == 'Off') then
			domoticz.log('dimmerstate = off. dimmerlevel: ' .. dimmer.level , domoticz.LOG_INFO)
			dimmer.dimTo(INIT_LEVEL)
			domoticz.log('dimmerstate = off; dimto '.. INIT_LEVEL .. '. dimmerlevel: ' .. dimmer.level , domoticz.LOG_INFO)
			--dimmer.dump()
			dimmer.switchOff().checkFirst().afterMin(DURATION)
			dimmer.switchOn().checkFirst().forMin(DURATION)
			dimmer.cancelQueuedCommands()
			dimmer.switchOff()
	domoticz.log('Device ' .. dimmer.name .. ' was changed', domoticz.LOG_INFO)
pressing the doorbell switch results in the following:
2019-11-22 00:26:32.932  (rfxcom) Lighting 1 (Elin drukknop)
2019-11-22 00:26:33.016  Status: dzVents: Info:  Handling events for: "Elin drukknop", value: "Chime"
2019-11-22 00:26:33.016  Status: dzVents: Info:  ------ Start internal script: DzVents device Elin drukknop: Device: "Elin drukknop (rfxcom)", Index: 656
2019-11-22 00:26:33.017  Status: dzVents: Info:  dimmerlevel: 75; INIT_LEVEL: 50; dimmerstate: Off
2019-11-22 00:26:33.018  Status: dzVents: Info:  dimmerstate = off. dimmerlevel: 75
2019-11-22 00:26:33.018  Status: dzVents: Info:  dimmerstate = off; dimto 50. dimmerlevel: 75
2019-11-22 00:26:33.018  Status: dzVents: Info:  Device Hue Ikea lamp PC beneden was changed
2019-11-22 00:26:33.018  Status: dzVents: Info:  ------ Finished DzVents device Elin drukknop
And the light is at 75%!
bert
Re: dimTo not doing what I would expect.
Post by bert »
Hmmm...
it seems to be caused by
removing the second line resolves the issue.. not sure why though.. just trying to follow the wiki :-/
bert wrote: Friday 22 November 2019 0:30 Wrote a little script to switch on a dimmer at a certain level (50%) for a number of minutes when a doorbell is pressed.
Please note that when you change the state or level of a device in a dzVents or Lua script, the change will only take place after the script finished. The command is stored in a table and that table is passed back to domoticz when the script finished.
So you cannot check the result of a command during the execution of the originating script.
bert
Re: dimTo not doing what I would expect.  [Solved]
Post by bert »
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
the wiki states:
..... And there you have it: the light is not switched off and never will be because future commands will always be checked against the current on-state.
That's just how it works and you will have to deal with it in your script. So, instead of simply re-issuing switchOn().forMin(5) you have to check the switch's state first:
if (light.active) then
light.switchOff().afterMin(5)
light.switchOn().forMin(5)
or issue these two commands both as they are mutually exclusive:
light.switchOff().checkFirst().afterMin(5)
light.switchOn().checkFirst().forMin(5)
For dimmers it seems a bit more tricky though; checking seems to go wrong..
anyway, the following seems to work as expected; works for me now..
local DURATION = 1
		devices = {
			INPUT_DEV
			dimmer.dimTo(LEVEL_STEP + INIT_LEVEL)
			dimmer.dimTo(INIT_LEVEL).forMin(DURATION)
			dimmer.switchOff()
