Looking for a wall device or remote for room temperature set
Posted: Thursday 21 November 2019 14:32
by al300kr
Could somebody please recommend me some device that i can put on the wall(or use as remote) to set temperature and send it to domoticz?
wifi or rfxcom(433mhz)? it will be also good if it will send current room temperature too.
later this data will be used to switch on/off air conditions and set different modes depending on conditions.
it should work local, without any api,clouds and without internet
it should be not expensive
thank you.
Re: Looking for a wall device or remote for room temperature set
Posted: Thursday 21 November 2019 16:13
by kirelam
You could use a Xiaomi gateway, together with the wall humid en temp sensor.
https://nl.aliexpress.com/item/33015694 ... b201603_52
https://nl.aliexpress.com/item/32920731 ... b201603_52
You could also buy them in packages!
Posted: Thursday 21 November 2019 19:13
by al300kr
thanks, but i mean device to SET temperature, like thermostat
i will try to use this devices:
https://www.aliexpress.com/item/4000046 ... b201603_55
Posted: Thursday 21 November 2019 20:02
by ropske
its used for floor heating i see? can you also use it then for no floor heating?
Posted: Thursday 21 November 2019 21:03
by al300kr
i will use it just like a remote to set a temperature, next this data will be send to domoticz to control aircoin unit in this room
