The group in blockly does not work in dzVents
Posted: Thursday 21 November 2019 11:12
by besix
Hello
i have script blockly which works
Script Blockly
IF Time => 14:00 and Lux <= 560 and device "Jadalnia" state Off and group "Salon" state Off
SET Jadalnia and Salon On
SET Write to log Light is On
ELSEIF Time => 14:00 and Lux > 570 and device "Jadalnia" state On and group "Salon" state On
SET Jadalnia and Salon Off
SET Write to log Light is Off
I want to try with dzVents and for start I have a script that also works
		devices = {'Ogród'},
		logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = 'Jadalnia',
		execute = function(dz,item)
		local lampa = dz.devices('Jadalnia')
		local Lux = dz.devices('Ogród')
		local LUX = Lux.lux
		if (lampa.state == 'Off' and LUX <= 560 ) then
		    lampa.switchOn()
	elseif  (lampa.state == 'On'and  LUX > 570 ) then
	        lampa.switchOff()
However, as I add to this group does not work anymore
[return {
		logging =
		local group = dz.groups('Salon')
		local LUX = Lux.lux
		if (lampa.state == 'Off' and group.state == 'Off' and LUX <= 560 ) then
		    lampa.switchOn()
		    group.switchOn()
	elseif  (lampa.state == 'On'and group.state == 'On' and LUX > 570 ) then
	        lampa.switchOff()
	        group.switchOff()
I have logs that there is no Salon group but it is because it works in blockly
2019-11-21 10:29:59.314 Status: dzVents: Info: Handling events for: "Ogród", value: "825.00"
2019-11-21 10:29:59.315 Status: dzVents: Info: Jadalnia: ------ Start internal script: Script #2: Device: "Ogród (Ogród)", Index: 193
2019-11-21 10:29:59.316 Status: dzVents: Error (2.4.19): Jadalnia: There is no group or scene with that name or id: Salon. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
2019-11-21 10:29:59.317 Status: dzVents: Debug: Jadalnia: Processing device-adapter for Jadalnia: Switch device adapter
2019-11-21 10:29:59.317 Status: dzVents: Error (2.4.19): Jadalnia: An error occured when calling event handler Script #2
2019-11-21 10:29:59.317 Status: dzVents: Error (2.4.19): Jadalnia: ...domoticz/scripts/dzVents/generated_scripts/Script #2.lua:17: attempt to index local 'group' (a nil value)
2019-11-21 10:29:59.317 Status: dzVents: Info: Jadalnia: ------ Finished Script #2
Who will help
Re: The group in blockly does not work in dzVents
Posted: Thursday 21 November 2019 11:29
by waaren
besix wrote: Thursday 21 November 2019 11:12 However, as I add to this group does not work anymore
The log message (and the advise to restart domoticz)
Might point in the right direction. Did you try to restart domoticz ?
Posted: Thursday 21 November 2019 11:33
by besix
Thank you for the quick response. Domoticz restart service was twice
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Uptime: 3 Hours, 2 Minutes , 45 Seconds
Uptime is fresh
Posted: Thursday 21 November 2019 12:28
by waaren
besix wrote: Thursday 21 November 2019 11:33 Thank you for the quick response. Domoticz restart service was twice
Can you try domoticz stop / domoticz start ?
What do see when executing this script ?
return
	on =
		devices =
		  'Ogród'
		logging =
            level = domoticz.LOG_ERROR, -- set to LOG_ERROR when tested and OK
		local function lpad(str, len, char)
             if char == nil then char = ' ' end
             return str .. string.rep(char, len - #str)
		dz.groups().forEach(function(gp)
            dz.log(lpad(gp.name, 30, '.') .. ' is seen by dzVents as group.' ,dz.LOG_FORCE)
        end)
        dz.scenes().forEach(function(sc)
            dz.log(lpad(sc.name, 30, '.' ) .. ' is seen by dzVents as scene.' ,dz.LOG_FORCE)
        end)
Re: The group in blockly does not work in dzVents  [Solved]
Posted: Thursday 21 November 2019 13:18
by besix
@waaren
Your script gives me all my scenes and groups
2019-11-21 12:57:15.909 Status: dzVents: Info: Handling events for: "Ogród", value: "643.00"
2019-11-21 12:57:15.910 Status: dzVents: !Info: Jadalnia: Salon ........................ is seen by dzVents as group.
2019-11-21 12:57:15.911 Status: dzVents: !Info: Jadalnia: Oświetlenie Pietro........... is seen by dzVents as group.
2019-11-21 12:57:15.911 Status: dzVents: !Info: Jadalnia: Oświetlenie Parter........... is seen by dzVents as group.
2019-11-21 12:57:15.912 Status: dzVents: !Info: Jadalnia: Idziemy spać................. is seen by dzVents as scene.
2019-11-21 12:57:15.912 Status: dzVents: !Info: Jadalnia: Światła wszystkie OFF....... is seen by dzVents as scene.
But it is not so simple anymore
Did not work
      groups = { ['Salon'] = {'at daytime'} }
    execute = function(domoticz, group)
      if (group.state == 'On') then
         domoticz.log('group is on!', domoticz.LOG_INFO)
Ok thank you for your help.
I deleted the "Salon" group and made a new one and the script works
I just have to add a time condition
		logging =
		local group = dz.groups('Lampki Salon')
		local LUX = Lux.lux
		    lampa.switchOn()
		    group.toggleGroup()
	        lampa.switchOff()
	        group.toggleGroup()
Posted: Thursday 21 November 2019 17:45
by besix
Just starting with dzVents helps a lot Wiki I made the script work but I want to see how to do it better.
It works
Trigger it
Lux or TV Status or Time.
TV Status is a virtual switch
	    timer = {' at 13:30-23:59'},
		devices = {'Ogród',
		           'TV Status',
		logging =
        marker = 'Wieczorne oświetlenie',
		local lampa1 = dz.devices('Salon Kinkiety')
		local TV = dz.devices('TV Status')
		local LUX = Lux.lux
		if (item.isTimer) then
		if (TV.state == 'On'and lampa.state == 'Off' and  LUX <= 300 ) then
		    lampa.switchOn()
	elseif (TV.state == 'On'and lampa.state == 'Off' and  LUX > 450 ) then
	        lampa.switchOff()
	elseif (TV.state == 'On' and lampa1.state == 'Off' and group.state == 'Off'and LUX <= 220 ) then
	       lampa1.switchOn()
	       group.switchOn()
	elseif (TV.state == 'On'and lampa1.state == 'On' and group.state == 'On'and  LUX > 360 ) then
	        lampa1.switchOff()
	        group.switchOff()
