Aeotec Energy Meter Gen5
Posted: Tuesday 19 November 2019 14:26
I have few issue with Aeotec Energy Meter (3 Clamps)
Maybe someone else had similar issue and was able to resolve it.
Issue 1.
Refreshing.
It doesn't work. Data are refreshed only when I go to Zwave control panel and click "Refresh". Changes in refresh time have no effect.
When I added meter to Domoticz fist time - refreshing was ok - based on settings on control panel. After this I was removing and adding meter many times and now refreshing doesn't work.
Issue 2.
Reset
Because od issue 1 I wanted to reset controller but I can't. Removing, resetting by control panel doesn't work correctly. Only basic settings are restored to factory defaults. Rest like counters stay with old values. Removing Node also doesn't work. After adding there are old values.
Issue 3.
Clamp direction
To have correct reporting I had to change direction of one clamp (this is against manual)
Issue 4.
Type of reporting
I have PV installation and if I choose report of consumed power I see power that is generated.
If I have report of generating in the settings - I see power that is consumed.
Issue 5.
Power calculation
Counting of power is incorrect. Calculation is to low. Current seems ok because If I multiple Current by 240V I receive power that is really similar that is showed by my main power meter.
Issue 6.
Lack of data
i.e. I have report group set to 15 (reporting total voltage, current, Power consumed,current power) in the control panel I see all data I need. In Domoticz in devices data are not showing. It works only for Kwh. For Reporting absolute value it shows all data.
Issue 1.
Refreshing.
Issue 2.
Reset
Issue 3.
Clamp direction
Issue 4.
Type of reporting
Issue 5.
Power calculation
Issue 6.
Lack of data
