problem dusk sensor
smaus
problem dusk sensor
Post by smaus »
Schermafdruk 2019-10-09 20.47.55.png (16.5 KiB) Viewed 608 times
The blocky that I made works, but now I have the following problem, if I want to turn the lights off earlier, this will not work.
mrf68
Re: problem dusk sensor
Post by mrf68 »
So you have to add another check with which you can overrule the action. Create a dummy switch “autolights” (or whatever name you like) and add it to your current blockly and check whether ths dummy is ON. Then when you turn it OFF, this blockly will not trigger when licht sensor is ON.
smaus
Post by smaus »
Okay thanks for the info, just think if I can get this done.
it is also possible that blocky only listens once to the twilight sensor if it is on and then not anymore.
Treve
Domoticz version: v4.11474
problem dusk sensor
Post by Treve »
smaus wrote: it is also possible that blocky only listens once to the twilight sensor if it is on and then not anymore.
In 24h or 1 one week or six hours?
Or during the period 15:00-21:30?
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Treve
Post by Treve »
If you mean between 15:00 and 21:30, the following blockly is maybe the solution.
Make a dummy (autolight)
Make a variable (variabele)
And the light will trigger once in 24 hour.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
