Switch turned off by Event can't be turned on by Scene
onzi
Domoticz version: V4.11349
Post by onzi »
I'm running Domoticz V4.11349 on a RaspberryPI.
All in all working good except I recently setup HA-Bridge for an Echo dot 3 using Alexa to call Domoticz Scenes.
This works good, except when an Event timer triggers a Switch off, then a Scene containing the same switch can't trigger it on.
E.g. I can ask Alexa to turn on the lights Scene in the livingroom, but during the night, the lights turn off by an Event. Next morning I would ask Alexa to turn the lights on and nothing happens.
In Domoticz log, I can see the Scene being called and the individual Switch being turned on, but the light doesn't actually turn on until I turn off and on the said switch. This goes for all switches that are part of scenes and are turned off by an event. When I "reset" the individual switch, e.g. I turn it off and on again, everything works as expected, including Scenes. This goes until the event timer triggers again.
Anyone else encountered something like this? I tried restarting the raspberry and re-creating the scenes. Nothing has improved.
Thanks.
