Zigate: wrong widget for Gledopto GL-C-009
Posted: Friday 15 November 2019 22:22
by ronaldbro
@pipiche,
Today I added a Gledopto GL-C-009 but it creates a wrong widget in Domoticz.
De widget which is created is a Color Switch - WW, but this device doesn't support white temperature. It's only a dimmer.
Re: Zigate: wrong widget for Gledopto GL-C-009
Posted: Saturday 16 November 2019 10:35
by pipiche
Could you kindly attach Data/DeviceList-xx.txt (after having stoppedthe plugin, in order to get Database flushed)
and let me know what is the IEEE of this device
Posted: Saturday 16 November 2019 11:26
by ronaldbro
Sure, here it is.
The IEEE is 00124b001d43d2b3
DeviceList-20.txt
(70.98 KiB) Downloaded 68 times
Thanks for your help.
Posted: Saturday 16 November 2019 11:41
by pipiche
If you are on the 'beta' branch, please do a git pull (to retreive the last changes). Then restart the plugin, remove the existing wrong Gledopto GL-C-009 widget/device and then redo the pairing. It should create only a Level Control /Dim widget
Let me know if it works.
Posted: Saturday 16 November 2019 18:02
by ronaldbro
Perfect like always :)
Thanks Pipiche
[SOLVED] Re: Zigate: wrong widget for Gledopto GL-C-009
Posted: Sunday 17 November 2019 14:58
by pipiche
Posted: Tuesday 19 January 2021 13:04
by djreesing
I just paired a Gledopto GL-C-009 with Zigate. However, I noticed the widget was again the wrong RGWWW dimmer instead of just a normal dimmer switch. When I looked at the configuration files on github I noticed in the GL-C-009.json file the type was changed back to ColorControlRGBWW in the last stable update. When I use the old json with type LvlControl it works perfectly fine.
Why was this changed back to something that doesn't work? Are there maybe multiple versions of this GL-C-009? The one that I have is just a simple dimmer.
Posted: Tuesday 19 January 2021 13:59
by pipiche
There is a reason, it has been reported by @ronaldbro tha GL-C-009 should be a RGBW. So it might happen that we have on the market 2 differents devices identified with teh same Model Name.
Could you kindly drop here an export.json file from the Plugin Device List RAW (json) ?
Thanks in advance
Posted: Tuesday 19 January 2021 14:12
by djreesing
Thanks for the quick reply, please find attached the requested export.
Posted: Tuesday 19 January 2021 19:17
by pipiche
Seem to be a mistake on my end between GL-C-007 and GL-C-009.
Please kindly update to plugin
4.11.015 if you are on stable branch
4.12.108 if you are on beta branch
Unfortunately to get back the right Widget ( LvlControl) you'll have to remove the created widget and redo the pairing
Posted: Tuesday 19 January 2021 19:34
by djreesing
Thanks, just checked and it's working fine now!
