FRITZ!Box 7530 Port Forwarding doesn't work wit PI
Posted: Friday 15 November 2019 15:16
by DomoticaRob
I do Have a Raspberry PI 3B with Domoticz V4.10717 on it
It worked fine on my KPN Experiabox V10, internaly and externaly with port 8080.
This week I changed from KPN to Solcon and now I have a FRITZ!Box 7530.
Internaly Domoticz works.
Externaly it doesn't work.
In the FRITZ!Box I have tried port forwarding TCP, UDP, HTTP, HTTPS, all kind of situations. Nothing works.
I have called the technical support of Solcon.
They see that my port is open. But, they also can't reach my Raspberry PI.
What must I do to let it work externaly?
Thanks in advance,
Rob
Re: FRITZ!Box 7530 Port Forwarding doesn't work wit PI
Posted: Friday 15 November 2019 16:06
by erem
Can you post the Fritz.os version, and the forwarding rule(s) you defined?
This is definitely a router issue, not a Domoticz issue.
Posted: Friday 15 November 2019 16:59
by DomoticaRob
Het betreft versie FRITZ!OS: 07.12
Toegang verlenen.png (59.35 KiB) Viewed 2208 times
Vrijgave aanmaken.png (16.21 KiB) Viewed 2208 times
Posted: Saturday 16 November 2019 10:43
by DomoticaRob
If I check my external port with a Port Forward Tester like:
(https://portchecker.co/check)
(https://www.portcheckers.com/)
(https://www.yougetsignal.com/tools/open-ports/)
then I only can open with:
port number 80.
For example, if I configure my FRITZ!Box for an ESP8266 sensor module as:
Port ESP8266 (intern): 80 - 80
Port extern: 80
The port tester says that the port is open.
If I configure my FRITZ!Box as:
Port PI (Domoticz) (intern): 8080 - 8080
Port extern: 80
The port tester says that the port is closed.
Posted: Saturday 16 November 2019 21:59
by andreo
These are my setting on a Fritzbox 7490
Posted: Saturday 16 November 2019 23:12
by DomoticaRob
I made a simple webserver on an ESP8266, two leds, two buttons in the webinterface.
I can give this ESP almost any internal port number in the sketch as well as almost any external port number in the FRITZ!Box, and it works.
But my PI is not reachable from outside.
I notice that the FRITZ!Box gives the PI also a so called IPv6-interface-ID.
Can that be the problem?
It drives me nuts!
