Add support for CM113, Electrisave ampere meter
Posted: Friday 15 November 2019 11:01
by rtfmjoey
I've added the CM113 3-phase ampere meter to the dashboard, but it shows up as a switch with 'on' status and does not display the current.
Is the CM113 currently unsupported? And if so, can it be added?
Re: Add support for CM113, Electrisave ampere meter
Posted: Friday 15 November 2019 11:47
by b_weijenberg
The CM113 is supported by the RFXtrx433XL.
Posted: Friday 15 November 2019 12:37
by Lokonli
rtfmjoey wrote: Friday 15 November 2019 11:01 Hi,
Can you post the Domoticz device info? Then I'll have a look how to add it to Dashticz.
https://www.domoticz.com/wiki/Domoticz_ ... fic_device
Posted: Friday 15 November 2019 14:05
by rtfmjoey
I added the CM113 as a virtual device (Ampere (3-Fase)) in device creation) and am using it to monitor the current usage of an EV Charger.
Here's the raw json output:
   "ActTime" : 1573823069,
   "AstrTwilightEnd" : "18:47",
   "AstrTwilightStart" : "05:60",
   "CivTwilightEnd" : "17:26",
   "CivTwilightStart" : "07:20",
   "DayLength" : "08:52",
   "NautTwilightEnd" : "18:07",
   "NautTwilightStart" : "06:39",
   "ServerTime" : "2019-11-15 14:04:29",
   "SunAtSouth" : "12:23",
   "Sunrise" : "07:57",
   "Sunset" : "16:49",
   "app_version" : "4.10717",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "16.0 A",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 11,
         "HardwareName" : "dz-dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "ID" : "142D8",
         "LastUpdate" : "2019-11-15 14:04:28",
         "Name" : "Current EVSE",
         "Notifications" : "false",
         "PlanID" : "14",
         "PlanIDs" : [ 14 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "CM113, Electrisave",
         "Timers" : "false",
         "Type" : "Current",
         "TypeImg" : "current",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "displaytype" : 0,
         "idx" : "648"
   "status" : "OK",
   "title" : "Devices"
The field I'm interested in is the 'Data' field (obviously).
I've also noticed something strange with the AstrTwilightStart value, 05:60 is not valid. Already made a post in the main Domoticz bug thread
Posted: Friday 15 November 2019 15:19
by Lokonli
You can define a custom blocktype. In 'custom/custom.js' you can find the function getExtendedBlockTypes:
function getExtendedBlockTypes(blocktypes){
	//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
	return blocktypes;
Add your custom blocktype definition as follows:
        blocktypes.Type['Current'] = {icon: 'fas fa-plug', title: '<Name>', value: '<Data>'};
	return blocktypes;
I'm not able to test it at the moment, but this should work ...
Posted: Friday 15 November 2019 18:18
by rtfmjoey
Works like a charm, thanks!!
Posted: Friday 10 April 2020 18:03
by Lokonli
rtfmjoey wrote: Friday 15 November 2019 18:18 Works like a charm, thanks!!
Merged into latest beta as well.
