Page 1 of 10
Script to restart Domoticz if it crashes
Posted: Monday 28 July 2014 13:25
by fisics
Hey guys,
Thought I share a (very basic) script that I use to check if Domoticz has crashed (offline) and restart it, I have this setup on a cron job running every ten minutes.
My script basically launches a Telnet session to Domoticz on port 8080, if it fails to connect it removes the 2 temporary DB files -shm and -wal and relaunches the service.
This code could probably be written in one line by one of you geniuses, but as I'm not a coder - it works for me!
Hope that helps someone else who has frequent offline crashes...
#!/bin/bash
# This is a script to check if Domoticz is running or crashed, if crashed delete the 2 db files and relaunch - my script lives in a folder called domo-alive-test
echo open 127.0.0.1 8080
sleep 2
echo "exit"
) | telnet > /home/pi/domo-alive-test/info-output.txt
sleep 5
# Telnet connection check, lets open info-out and make sure it contains the failed telnet output otherwise stop.
grep -Po '\?Invalid command' /home/pi/domo-alive-test/info-output.txt > /home/pi/domo-alive-test/telnet-connection-test.txt
sed -i '1!d' /home/pi/domo-alive-test/telnet-connection-test.txt
info=$(cat /home/pi/domo-alive-test/telnet-connection-test.txt)
rm /home/pi/domo-alive-test/telnet-connection-test.txt
if [ "$info" = "?Invalid command" ]
then
	# Telnet connection refused
	rm /home/pi/domo-alive-test/info-output.txt
	rm /home/pi/domoticz/domoticz.db-wal
	rm /home/pi/domoticz/domoticz.db-shm
	sudo service domoticz.sh start
	exit
	exit
fi
Re: Script to restart Domoticz if it crashes
Posted: Monday 28 July 2014 13:32
by fisics
Just had another thought on this, you could probably do it much easier using:
sudo service domoticz.sh status
To check if it returns
"[FAIL] domoticz is not running ... failed!"
Posted: Monday 28 July 2014 13:34
by Derik
looks great..
And better than the watchdog....
For sharing :D :D
Posted: Monday 28 July 2014 13:35
by simonrg
A different approach is documented on the Wiki using the Watchdog service on the Raspberry pi - http://www.domoticz.com/wiki/Setting_up ... i_watchdog - this runs on the Raspberry Pi, so is self-contained and copes with the Raspberry Pi crashing itself rebooting the Raspberry Pi.
@Derik why Watchdog not good?
Posted: Monday 28 July 2014 19:02
by SweetPants
I'm using 'monit' on Raspberry and Ubuntu. You can also use it to monitor/restart other processes like nginx
/etc/monit/conf.d/domoticz.conf
check process domoticz with pidfile /var/run/domoticz.pid
start program "/etc/init.d/domoticz.sh start"
stop program "/etc/init.d/domoticz.sh stop"
/etc/monit/conf.d/nginx.conf
check process nginx with pidfile /var/run/nginx.pid
start program "/etc/init.d/nginx start"
stop program "/etc/init.d/nginx stop"
if failed host 127.0.0.1 port 80
protocol http then restart
if 5 restarts within 5 cycles then timeout
Regards, Harry
Posted: Wednesday 13 August 2014 23:51
by nigels0
simonrg wrote:A different approach is documented on the Wiki using the Watchdog service on the Raspberry pi - http://www.domoticz.com/wiki/Setting_up ... i_watchdog - this runs on the Raspberry Pi, so is self-contained and copes with the Raspberry Pi crashing itself rebooting the Raspberry Pi.
I looked for the domoticz.log file in /tmp, but it doesn't exist - so the watchdog doesn't start up.
Posted: Thursday 14 August 2014 8:23
by CopyCatz
As stated in the manual, specify the log location in the command line parameters:
-log file_path
Then point the watchdog to the log file.
Posted: Thursday 14 August 2014 22:40
by nigels0
I guess the danger of having the log being written to the SD or USB repeatedly is why the log is not switched on by default
Posted: Wednesday 14 January 2015 10:31
by sincze
nigels0 wrote:I guess the danger of having the log being written to the SD or USB repeatedly is why the log is not switched on by default
I'm writing the log to RAM or NAS. ;-)
It seems that NGINX is crashing a lot. (I configured monit to send me an e-mail so now I know exactly how many times and it is a lot).
10+ times per day it will be restarted by Monit. Is this a known issue? Should I tweak the nginx configuration.
Unfortunately I did not look at the nginx log file to see if it is maybe the known php issue.
https://discussion.dreamhost.com/thread-128870.html
Also Domoticz interface sometimes stalls... several seconds and then moves on again. (Nginx related??)
Sándor
Posted: Wednesday 14 January 2015 17:32
by ThinkPad
Moved topic to 'Scripts' section.
Posted: Thursday 11 June 2015 11:48
by frave
Hi, I was looking into a more simpler approach just like fisics opted a few posts back. The reason why is because I found out Domoticz ocassionally crashes. It does not happen a lot but it is frustrating when finding out the moment you would like to flip a switch. I have found a way to interpret the output of "sudo domoticz.sh service status" and it works flawlessly. So to help others with the same problem I thought I will make my first post here.
I just made a file called "domoticz_state_checker.sh" and inserted the following code:
#!/bin/bash
while true
do
DomoticzState=`sudo service domoticz.sh status`
if [[ $DomoticzState == "domoticz is running." ]]
        then
                echo 'Domoticz is running. Nothing to do.'
elif [[ $DomoticzState == "domoticz is not running ... failed!" ]]
        then
                echo 'Domoticz is not running. Restarting Domoticz...'
                sudo service domoticz.sh restart
                echo 'Domoticz restarted.'
fi
sleep 15
done
I just start the script with "nohup ./domoticz_state_checker.sh &" and it runs in the background. As you can see in the code it checks the state of Domoticz every 15 seconds and when it finds out Domoticz stopped working it performs a simple restart.
Posted: Thursday 11 June 2015 18:22
by Derik
@ Fisics....
How do you do this?
and where do you place the files??
Posted: Thursday 11 June 2015 19:05
by roblom
There is also an example of a script in the monit wiki.
Posted: Monday 22 June 2015 10:01
by Ingmar
frave wrote:Hi, I was looking into a more simpler approach just like fisics opted a few posts back. The reason why is because I found out Domoticz ocassionally crashes. It does not happen a lot but it is frustrating when finding out the moment you would like to flip a switch. I have found a way to interpret the output of "sudo domoticz.sh service status" and it works flawlessly. So to help others with the same problem I thought I will make my first post here.
#!/bin/bash
while true
do
        then
        then
fi
sleep 15
done
Thanks, works perfectly!
I added the "nohup /home/pi/domoticz/scripts/domoticz_state_checker.sh &" command in the rc.local file (in /etc) so that it automatically starts when the Pi starts up.
Posted: Monday 22 June 2015 15:16
by frave
Thanks for your success story :) and of course your addition of the automatic startup. I think I have solved that differently. But your solution is plain and simple.
Posted: Friday 30 October 2015 17:35
by frave
I am writing this just to inform anyone that wants to use this script and is not running on a Raspberry Pi. I recently migrated Domoticz to new hardware with a standard Debian 8 (jessie) installation so I stopped using my Raspberry Pi for Domoticz. I then came to know the script I wrote above does not work anymore. I therefore edited it as followes.
#!/bin/bash
while true
do
DomoticzState=`sudo service domoticz status`
if [[ $DomoticzState == *"active (running)"* ]]
        then
elif [[ $DomoticzState == *"inactive (dead)"* ]]
        then
                sudo service domoticz restart
         fi
sleep 15
done
### Done
Then start the script the same way, with the command "nohup ./domoticz_state_checker.sh &", to run in the background.
Posted: Sunday 01 November 2015 22:52
by HvdW
A perfect script.
Thanks a lot!
This unexpected stall of Domoticz on the Rasperry affects everyone (I think)
The code resolves the problem in a very simple manner.
  #!/bin/bash
            then
            then
    fi
sudo chmod +x domoticz_state_checker.sh
crontab -e
*/5 * * * * /home/pi/scripts/domoticz_state_checker.sh
However I removed the loop and made a cronjob which makes the script run every 5 minutes
Posted: Sunday 15 November 2015 8:23
by Derik
@ HDVW
Very simple script...
I give your srcipt a try, because it is very very simple..
Please Can you make a option when your script is restart Domotic that the board is sending a email?
I think that is a great option
Posted: Sunday 15 November 2015 11:08
by Derik
strange...
Try the script on my RPi, works great..
Try it on my CB: not...
I have:
I have:
sudo chmod +x restart_domoticz.sh
I have:
*/3 * * * * sudo /home/linaro/scripts/restart_domoticz.sh
The same as on my RPi..
I changed the pad..
Some one please, where do i go wrong?
EDIT:
Found a solution..
Changed restart in start
Posted: Monday 19 December 2016 17:22
by tjabas
Im really new to this Linux and rasberry, but how do i install this script?
I have lot of problems with Domoticz freezing, so i guess this script would do the trick.
