Issue with reading smart meter P1 in Home assistant
Posted: Thursday 14 November 2019 17:28
by Richo999
Hello Everyone! hopefully anyone is able to help me with a issue I am having with reading out my smart meter.
I own a Landis E350 with a smart meter cable from
https://www.sossolutions.nl/slimme-meter-kabell its a verified cable for my smart meter. It is connected to my ESXI server in the basement (I extended the RJ-11). on the ESXI I have a Ubuntu64 with Home assistant for logging the data. I had some issues setting up home assistant, because of a known bug with Nginx in the configurator which I resolved by editing the config.yaml through SSH.
I used the following code:
sensor:
- platform: dsmr
port: /dev/ttyUSB0
dsmr_version: 4
group:
meter_readings:
entities:
- sensor.power_consumption_low
- sensor.power_consumption_normal
- sensor.power_production_low
- sensor.power_production_normal
- sensor.gas_consumption
As far as I can tell there is a connection, I verified this in SSH with the following command line:
cu -l /dev/ttyUSB0 -s 115200 --parity=none -E q
At first I got a Permission denied but with this following code I resolved the issue.
chmod 666 /dev/ttyUSB0
At this point I am able to establish a connection however not much more beside the following:
Connected.
it should output data but it times out after some time. Anyone got a idea how to resolve this issue?
Re: Issue with reading smart meter P1 in Home assistant
Posted: Thursday 14 November 2019 18:39
by FireWizard
It is good to know that this forum supports Domoticz and so it might be, that active users here, have less knowledge about Hass then active users in the Hass forum. However this topic is not only a Hass issue.
First.
Since, at least, 2017, the Landis & Gyr E350 supports DSMR 5. So maybe you have to change your config file to dsmr_version: 5.
Second.
This is a serial cable and you cannot extend this cable unlimited.
The RS-232 standard has been specified in 1960.The RS-232C dates from 1969. The maximum length has been specified as 15 meters (50 feet) for transmission speeds of up to 19.200 Bd. The standard has been developed for speeds up to 20kbps.
However it is often used for higher speeds, but this has effect on the maximum length.
In this case you should use the following maximum cable length:
Bit Rate Bus Length
115200 bit/s 2.5 m
57600 bit/s 5.0 m
38400 bit/s 7.5 m
19200 bit/s 15 m
9600 bit/s 30 m
So check the connection first, with a laptop and a terminal program, within 2.5m from your smart meter. If this works you can continue.
The serial connection might work on longer distances, but there is no guarantee.
Please post your results,
Posted: Thursday 14 November 2019 20:19
by Richo999
FireWizard wrote: Thursday 14 November 2019 18:39First.
Second.
Bit Rate Bus Length
115200 bit/s 2.5 m
57600 bit/s 5.0 m
38400 bit/s 7.5 m
19200 bit/s 15 m
9600 bit/s 30 m
The cable itself is 1.8m and the extension RJ-11 is 2,5m
connected directly to a laptop with the smart meter cable (without the extension), I get proper read out. can I presume the cable just doesn't like to get extended? It borrowed this laptop from a friend some time ago to do some other stuff. the only thing I changed to was plug in the smart meter cable and used:
Posted: Thursday 14 November 2019 22:29
by FireWizard
I understand that without the extension cable, you see the P1 smart meter protocol.
So let' s focus on the extension cable.
You cannot assume that the smart meter cable cannot be extended.
Check your extension cable, regarding the following:
1. Is the RJ-11/12 extension cable a straight cable and are all 6 wires connected?
2. The Landys & Gyr E350 requires a 1 kohm pull-up resistor, between Vcc and RxD.
Your P1 cable will have that, but if your extension cable is incomplete, you have a problem.
Measure the RJ-11/12 cable with a multimeter.
See:
https://www.google.com/search?q=P1+smar ... Kj2uUrM%3A
Posted: Friday 15 November 2019 18:55
by Richo999
FireWizard wrote: Thursday 14 November 2019 22:29
2. The Landyd & Gyr E350 requires a 1 kohm pull-up resistor, between Vcc and RxD.
See:
after reading this I figured that the 1kohm resistor might be a possible culprit so I went through my old cable "storage" (garbage) pile and discovered a 2m usb 2.0 extender, this solved my whole issue. thanks for the help!
Posted: Tuesday 26 January 2021 11:39
by PA5UL
Hi, similar challenge here. My E350 has an 8-pin P1 port. I need to connect it (either via USB or via the home network) to the NUC PC running Home Assistant, which is situated at a distance of some 5m in a straight line or about 10m if I run a cable in a way my wife will accept. What options do I have?
- 2021-01-26 11.29.36.jpg (84.1 KiB) Viewed 9045 times
Posted: Tuesday 26 January 2021 13:05
by erem
@PA5UL
one option is using a Wemos D1 in combination with ESPEasy to move the data to domoticz via wifi/ethernet
https://www.pe1rqm.nl/slimme-meter-uitl ... a-systeem/
it's dutch, but google translate is your friend if you do not speak dutch
Posted: Wednesday 30 July 2025 15:39
by PA5UL
By chance I happened on this old post. Mni tnx om Tjalling but in the mean time I've found another option that works very wel for me. I use a P1 dongle by Home Wizard (€25) which integrates really well into Home Assistant. I can monitor in real time for all 3 phases separately what I use or produce. This info helps met toggle smart switches for several 'dumb' users so I can optimise the amount of energy I use from my solar panels.
Posted: Monday 25 August 2025 16:56
by manjh
I've run into some questions with the P1 meter plugins.
Until now I have used a simple ESP unit with an RJ11 cable attached, connecting to "P1 smart meter with LAN interface" in Domoticz.
A little while ago I have bought the HomeWIzard P1 dongle, and attached it with a simple RJ11 splitter, connection to the HomwWIzard WiFi P1 meter plugin.
I now have both running and am comparing some of the values.
The L1 power usage (phase 1) power usage shows 215 Watt in the ESP unit, and 2160 in the HomeWIzard. So it's a factor 10 off. Looks like some other values are off as well.
Does this sound familiar?
I have not compared all values yet.
Posted: Wednesday 24 September 2025 10:47
by manjh
Anyone?
I use the values to determine if there is any power left to charge my car, for instance. So it is essential that I have the values correct.
The array that comes out of both units shows 6 entries: four meter readings, going in and out, in two time ranges, then two showing current.
The sixth value is a factor 10 higher in the HomeWizard unit compared to the "P1 meter with LAN interface" unit.
Purely based on my instinct, I think the lower value is correct (so the HomeWizard value is too high).
Does anyone have an opinion on this?
Once I am sure, it is not difficult to make the correction, of course.
Posted: Wednesday 24 September 2025 20:14
When you press on the green button on your real smart meter in your home, you can see the real values real time on the meters display. You can compare those with the values read by homewizard and Domoticz
Posted: Thursday 25 September 2025 10:35
by manjh
Thanks, that is an excellent suggestion, should have done that in the first place!
Comparing the values to what I can see in Domoticz, I found out that the actual usage from the HomwWizard dongle is indeed a factor 10 too high.
This is my setup:
Smartmeter-->ESPunit-P1-->P1 smart meter with LAN interface--> Domoticz device: value matches the reading on the meter
Smartmeter-->HomeWizard dongle-->HomeWIzard Wifi P1 meter-->Domoticz device: value is a factor 10 too high
I downloaded the HomeWizard Android app and checked: here the value is correct, matching the meter readout.
So I think the error is in the plugin... agree?
Posted: Thursday 25 September 2025 10:41
Agree, that seems to be an issue in the HomeWizard plugin
