Database malformed?
Posted: Tuesday 12 November 2019 15:10
by JuanUil
Hi there,
since a few days I find the following in my log.
2019-11-12 15:00:00.947 Status: Starting automatic database backup procedure...
2019-11-12 15:00:01.363 Error: SQL Query("VACUUM") : database disk image is malformed
2019-11-12 15:00:04.693 Status: Ending automatic database backup procedure...
everything is working well so anybody any idea how to fix this?
Thnx in advance
Jan
Re: Database malformed?
Posted: Tuesday 12 November 2019 17:02
by JuanUil
allways when I post a problem the new posts are refreshed and my post is gone :oops: :oops: :oops:
Posted: Tuesday 12 November 2019 17:04
by jvdz
Are you using a RAMDrive for TMP and could it be this is not large enough anymore to hold a copy of your domoticz.db for the vacuum operation?
Check available space with: df -k
And the size of your domoticz.db with : ls -l /home/pi/domoticz
EDIT: actually I guess your DB is really having issue and needs to be checked. Will search for the post on that made earlier and post back.
EDIT2: check out this thread: https://www.domoticz.com/forum/viewtopi ... ed#p202504
Jos
Posted: Tuesday 12 November 2019 18:41
by JuanUil
Hi Jos,
Thnx for your reply.
no I have no ramdrive.
I will check the supposed procdure with sqlite, thnx!!
jan
Posted: Tuesday 12 November 2019 18:48
by JuanUil
Thnx Jos,
everything is normal again!!
Jan :D :D :D
