Alert sensor  [Solved]
Hydci
Domoticz version: 4.10717
Alert sensor
Post by Hydci »
Hello I have this script that works great I just have a problem I would like him to update the device only when the state changes I tried several things but I can not do it
return
    on = { timer = { 'every minute' },
    httpResponses = { 'vigilance' }},
         logging =
            level = domoticz.LOG_DEBUG,
            marker = 'Vigilance'
    execute = function(dz, item, level)
        local SaisonURL = 'http://domogeek.entropialux.com/vigilance/59/color'
        if not(item.isHTTPResponse) then
            dz.openURL({ url = SaisonURL, callback = 'vigilance' })
        elseif item.ok then
            if item.data == 'vert' and dz.devices('Vigilance météo') ~= '1' then
            dz.devices('Vigilance météo').updateAlertSensor('1', 'Alerte vert')
        elseif item.data == 'jaune' and dz.devices('Vigilance météo') ~= '2' then
            dz.devices('Vigilance météo').updateAlertSensor('2','Alerte jaune')
        elseif item.data == 'orange' and dz.devices('Vigilance météo') ~= '3' then
            dz.devices('Vigilance météo').updateAlertSensor('3', 'Alerte orange')
        elseif item.data == 'rouge' and dz.devices('Vigilance météo') ~= '4' then
            dz.devices('Vigilance météo').updateAlertSensor('4', 'Alerte rouge')
Re: Alert sensor
Hydci wrote: Monday 11 November 2019 17:11 Hello I have this script that works great I just have a problem I would like him to update the device only when the state changes I tried several things but I can not do it
Can you try this ?
return
         logging =
    execute = function(dz, item)
            return
        local vigilance = dz.devices(131)  -- Change to the id of your Alert sensor
        local currentColor = vigilance.color
        local colorMapping =
                                gris = dz.ALERTLEVEL_GREY,
                                vert = dz.ALERTLEVEL_GREEN,
                                jaune = dz.ALERTLEVEL_YELLOW,
                                orange = dz.ALERTLEVEL_ORANGE,
                                rouge = dz.ALERTLEVEL_RED,
        if item.ok then
            if currentColor ~= colorMapping[item.data] then
                vigilance.updateAlertSensor(colorMapping[item.data], 'Alerte ' .. item.data)
                dz.log('No update needed. Sensor is already '.. item.data , dz.LOG_DEBUG)
            dz.log('problem retrieving data',dz.LOG_ERROR)
Re: Alert sensor
or if you want to use other data from this site in future..
return
         logging =
            local SaisonURL = 'http://domogeek.entropialux.com/vigilance/59/all'
            return
        local vigilance = dz.devices(131) -- change to id of your alert Sensor
        if item.ok then
            local newColor = item.json.vigilancecolor
            if colorMapping[newColor] ~=  currentColor  then
                vigilance.updateAlertSensor(colorMapping[newColor], 'Alerte ' .. newColor)
                dz.log('No update needed. Sensor is already '.. newColor , dz.LOG_DEBUG)
            dz.log('problem retrieving data ' .. item.data,dz.LOG_ERROR)
Hydci
Re: Alert sensor
Post by Hydci »
It works perfectly the device is no longer updated every minute but I have another script that sends a notification to the color change is that it? because it does not work
if value.data == "1" is good ?
   on = { devices = { "vigilance météo" }},
   execute = function(dz, item, devices, value )
        if value.data == "1" then
        os.execute("xxxxx'")
		elseif value.data == "2"  then
		os.execute("xxxx'")
		elseif value.data == "3" then
		os.execute("xxxx'")
		elseif value.data == "4"  then
        os.execute("xxxx'")
Edit:
My script work
   on = { devices = { "Vigilance météo" }},
        if item.state == "Alerte vert" then
        os.execute("curl -u Hydci:Daniel15042015 -s -o -v 'http://192.168.1.4:7080/send.html?smsto=xxxx&smsbody=Fin+de+lalerte+meteo+france&smstype=sms'")
		elseif item.state == "Alerte jaune"  then
		os.execute("curl -u Hydci:Daniel15042015 -s -o -v 'http://192.168.1.4:7080/send.html?smsto=xxxxx&smsbody=Bo%C3%AEte+au+lettre+courrier+dedans&smstype=sms'")
		elseif item.state == "Alerte orange" then
		elseif item.state == "Alerte rouge"  then
        os.execute("curl -u Hydci:Daniel15042015 -s -o -v 'http://192.168.1.4:7080/send.html?smsto=xxxx&smsbody=Bo%C3%AEte+au+lettre+courrier+dedans&smstype=sms'")
Re: Alert sensor  [Solved]
Hydci wrote: Monday 11 November 2019 17:58 It works perfectly the device is no longer updated every minute but I have another script that sends a notification to the color change is that it? because it does not work
No. It should be something like
   execute = function(dz, item )
        if item.color ==  dz.ALERTLEVEL_GREEN then
            os.execute("xxxxx")
        elseif item.color == dz.ALERTLEVEL_YELLOW then
            os.execute("xxxx")
        elseif item.color == dz.ALERTLEVEL_ORANGE then
            os.execute("xxxx")
        elseif item.color == dz.ALERTLEVEL_RED then
            os.execute("xxxx")
Is there a specific reason why you do not combine this with the previous script ?
something like
return
         logging =
            return
        if item.ok then
                if newColor ==  dz.ALERTLEVEL_GREEN then
                    os.execute("xxxxx")
                elseif newColor == dz.ALERTLEVEL_YELLOW then
                    os.execute("xxxx")
                elseif newColor == dz.ALERTLEVEL_ORANGE then
                    os.execute("xxx")
                elseif newColor == dz.ALERTLEVEL_RED then
                    os.execute("xx")
Hydci
Re: Alert sensor
Post by Hydci »
I did not think it was possible thanks for the solution
