Is Z-Wave reliable anymore?
Posted: Sunday 10 November 2019 11:54
Since few days all z-wave devices on the same side of the house are marked dead and won't connect. This affects not only the battery operated like SpiritZ heating valves, as also wall plug adapters and wired FRGBW controllers. In my country LTE is in extension buildup in favor to 5G and the problematic devices are on the side of the house to the next cellphone tower (500m). So to understand let's have a look for the conflicting frequency.
LTE Band 20
LTE Band 20 is a part of the FDD (Frequency Division Duplex) LTE spectrum that has different uplink and downlink frequencies. The separate uplink and downlink bands allow for simultaneous transmission on two frequencies. The bands have a separation between them which is called the band gap.
Uplink Frequency: 832-862 MHz
Downlink Frequency: 791-821 MHz
Width of Band: 30 MHz
Duplex Spacing: -41 MHz
Band Gap: 71 MHz
Here LTE 20 uplink can operate at 862Mhz + 30Mhz hub and so inside the z-wave signals. While LTE devices can send with 2 watts, our z-wave devices do loose. My final question is: Is z-wave in near future a reliable technology or end now with new cellphone frequencies and are 2.4Ghz devices a better solution?
Solderbro
LTE Band 20
Band Gap: 71 MHz
Solderbro
