Page 1 of 2
Zigate dimlevel group incorrect in beta
Posted: Friday 08 November 2019 21:57
by ronaldbro
I have a group of 5 tradfri lights connected to zigate and I noticed that the latest beta uses wrong dim levels for groups.
See my log below with update device messages and update group messages.
The current stable does not have this problem.
- Spoiler: show
2019-11-08 21:49:40.523 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:47
2019-11-08 21:49:41.111 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:30
2019-11-08 21:49:55.674 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 4) 1:30
2019-11-08 21:50:12.478 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:47
2019-11-08 21:50:32.172 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:38
2019-11-08 21:50:32.321 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:38
2019-11-08 21:50:32.660 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:33
2019-11-08 21:50:32.674 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 4) 1:33
2019-11-08 21:50:32.703 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:33
2019-11-08 21:50:32.731 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:33
2019-11-08 21:50:34.112 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:61
2019-11-08 21:50:37.125 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:62
2019-11-08 21:50:37.633 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:61
2019-11-08 21:50:37.647 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:61
2019-11-08 21:50:37.708 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 4) 1:61
2019-11-08 21:50:37.718 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:61
2019-11-08 21:50:42.129 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:100
2019-11-08 21:50:58.473 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:41
2019-11-08 21:50:58.789 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:20
2019-11-08 21:50:59.086 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:14
2019-11-08 21:50:59.173 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:58
2019-11-08 21:50:59.196 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 4) 1:58
2019-11-08 21:50:59.208 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:58
2019-11-08 21:50:59.220 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:58
2019-11-08 21:50:59.232 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:56
2019-11-08 21:51:02.185 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:100
2019-11-08 21:51:04.111 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:24
2019-11-08 21:51:04.145 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:24
2019-11-08 21:51:04.167 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 4) 1:24
2019-11-08 21:51:04.196 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:24
2019-11-08 21:51:04.266 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:24
2019-11-08 21:51:07.296 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:38
2019-11-08 21:52:42.576 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:38
2019-11-08 21:52:47.581 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:47
Re: Zigate dimlevel group incorrect in beta
Posted: Friday 08 November 2019 22:00
by pipiche
This log is not helpful, we need the log when creating/updating the group.
Could you do a Group Scan from the admin tab on the web admin gui and share the logs from the start of the plugin to the completion of the group scan.
Posted: Friday 08 November 2019 22:15
by ronaldbro
Sure, no problem. also increased the log level on the plugin settings
- Spoiler: show
- 2019-11-08 22:09:40.829 Status: (Zigate) Zigate plugin beta-4.6.016 started
2019-11-08 22:09:40.855 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-11-08 22:09:40.855 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-11-08 22:09:40.855 Status: (Zigate) DomoticzVersion: 4.11474
2019-11-08 22:09:40.855 Status: (Zigate) DomoticzHash: 12feb06f1
2019-11-08 22:09:40.856 Status: (Zigate) DomoticzBuildTime: 2019-11-08 16:33:53
2019-11-08 22:09:40.856 Status: (Zigate) load PluginConf
2019-11-08 22:09:40.859 Status: (Zigate) enableAPSFailureReporting set to 0
2019-11-08 22:09:40.859 Status: (Zigate) enableReadAttributes set to 1
2019-11-08 22:09:40.859 Status: (Zigate) enablegroupmanagement set to 1
2019-11-08 22:09:40.859 Status: (Zigate) allowOTA set to 1
2019-11-08 22:09:40.859 Status: (Zigate) batteryOTA set to 1
2019-11-08 22:09:40.859 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-11-08 22:09:40.859 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-11-08 22:09:40.859 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-20.json
2019-11-08 22:09:40.859 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-11-08 22:09:40.859 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-11-08 22:09:40.860 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-08 22:09:40.860 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-08 22:09:40.860 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-08 22:09:40.860 Status: (Zigate) Opening DomoticzDB in raw
2019-11-08 22:09:40.868 Status: (Zigate) Domoticz Website credentials /
2019-11-08 22:09:40.885 Status: (Zigate) Plugin Database: DeviceList-20.txt
2019-11-08 22:09:40.916 Status: (Zigate) DeviceConf loaded
2019-11-08 22:09:40.916 Status: (Zigate) load ListOfDevice
2019-11-08 22:09:41.372 (Zigate) runmode_with_gpiocommand
2019-11-08 22:09:41.372 (Zigate) + Checkint GPIO PINs
2019-11-08 22:09:41.582 (Zigate) + Checkint GPIO PINs
2019-11-08 22:09:41.645 (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2019-11-08 22:09:41.648 (Zigate) Permit Join set :
2019-11-08 22:09:41.648 (Zigate) ---> self.permitTojoin['Starttime']: 1573247381
2019-11-08 22:09:41.648 (Zigate) ---> self.permitTojoin['Duration'] : 254
2019-11-08 22:09:41.754 (Zigate) Start Network: Network joined / formed Status: 01
2019-11-08 22:09:41.290 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-20.txt : 46
2019-11-08 22:09:41.328 Status: (Zigate) Transport mode: PI
2019-11-08 22:09:41.368 Status: (Zigate) Python version: ['3.5.3 (default, Sep 27 2018, 17:25:39) ', '[GCC 6.3.0 20170516]'] dist: ('debian', '9.11', '') linux_distribution: ('debian', '9.11', '') system: Linux machine: armv7l platform: Linux-4.19.66-v7+-armv7l-with-debian-9.11 uname: uname_result(system='Linux', node='Domoticz', release='4.19.66-v7+', version='#1253 SMP Thu Aug 15 11:49:46 BST 2019', machine='armv7l', processor='') version: #1253 SMP Thu Aug 15 11:49:46 BST 2019 mac_ver: ('', ('', '', ''), '')
2019-11-08 22:09:41.645 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial0
2019-11-08 22:09:41.647 Status: (Zigate) setTimeServer - Setting UTC Time to : 626566181
2019-11-08 22:09:41.647 Status: (Zigate) Configure Permit To Join
2019-11-08 22:09:41.648 Status: (Zigate) Request Accepting new Hardware for 254 seconds
2019-11-08 22:09:41.648 Status: (Zigate) Trigger a Topology Scan
2019-11-08 22:09:41.649 Status: (Zigate) Trigger a Energy Level Scan
2019-11-08 22:09:41.754 Status: (Zigate) Zigate details IEEE: 00158d0001ed46fa, NetworkID: 0000, Channel: 0b, Status: 01: ZIGATE - [01] Incorrect Parameters
2019-11-08 22:09:41.755 Status: (Zigate) Non 'Factory new' Restart status: RUNNING
2019-11-08 22:09:41.758 Status: (Zigate) Major Version Num: 0003
2019-11-08 22:09:41.758 Status: (Zigate) Installer Version Number: 031a
2019-11-08 22:09:42.268 (Zigate) Permit Join status: 01
2019-11-08 22:09:42.268 (Zigate) ---> self.permitTojoin['Starttime']: 1573247381
2019-11-08 22:09:42.268 (Zigate) ---> self.permitTojoin['Duration'] : 254
2019-11-08 22:09:42.268 (Zigate) ---> Current time : 1573247382
2019-11-08 22:09:42.268 (Zigate) ---> self.Ping['Permit'] (prev) : None
2019-11-08 22:09:42.269 (Zigate) ---> self.Ping['Permit'] (new ) : On
2019-11-08 22:09:42.371 (Zigate) Initialize Zigate Data Structure 0000 00158d0001ed46fa
2019-11-08 22:09:42.268 Status: (Zigate) Accepting new Hardware: On
2019-11-08 22:09:42.372 Status: (Zigate) Zigate addresses ieee: 00158d0001ed46fa , short addr: 0000
2019-11-08 22:09:42.372 Status: (Zigate) Network state UP, PANID: 83fa extPANID: 0x6fb8a1e178f20065 Channel: 11
2019-11-08 22:09:42.511 Status: (Zigate) Number of devices recently active in Zigate = 24
2019-11-08 22:09:51.221 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.225 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.227 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.231 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.239 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.241 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.256 (Zigate) ota_decode_new_image - Signed Firmware ...
2019-11-08 22:09:51.499 (Zigate) Group Management - Init phase
2019-11-08 22:09:51.499 (Zigate) --->GroupList.pck doesn't exist
2019-11-08 22:09:51.499 (Zigate) ------------>Json Config file exists
2019-11-08 22:09:51.499 (Zigate) ------------>Last Update of JSON Config File: 1572180377.8507566
2019-11-08 22:09:51.500 (Zigate) --> Grp: 0001 --> [['000b57fffe907671', '01'], ['000b57fffec51189', '01']]
2019-11-08 22:09:51.500 (Zigate) ----> ['000b57fffe907671', '01']
2019-11-08 22:09:51.500 (Zigate) ----> ['000b57fffec51189', '01']
2019-11-08 22:09:51.500 (Zigate) --> Grp: cf64 --> [['000d6ffffe7ac128', '01'], ['14b457fffe4c3e08', '01'], ['000d6ffffe8e9fb7', '01'], ['14b457fffe4c273a', '01'], ['14b457fffe3dbe31', '01']]
2019-11-08 22:09:51.500 (Zigate) ----> ['000d6ffffe7ac128', '01']
2019-11-08 22:09:51.500 (Zigate) ----> ['14b457fffe4c3e08', '01']
2019-11-08 22:09:51.500 (Zigate) ----> ['000d6ffffe8e9fb7', '01']
2019-11-08 22:09:51.500 (Zigate) ----> ['14b457fffe4c273a', '01']
2019-11-08 22:09:51.500 (Zigate) ----> ['14b457fffe3dbe31', '01']
2019-11-08 22:09:51.168 Status: (Zigate) Zigate set to Certification : CE
2019-11-08 22:09:51.169 Status: (Zigate) Start Group Management
2019-11-08 22:09:51.169 Status: (Zigate) Start Web Server connection
2019-11-08 22:09:51.215 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-11-08 22:09:51.215 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2019-11-08 22:09:51.219 Status: (Zigate) Available Firmware Type: 4549 version: 22008631 - filename: 10005778-4.1-TRADFRI-onoff-shortcut-control-2.2.008.ota.ota size: 179582 Bytes
2019-11-08 22:09:51.222 Status: (Zigate) Available Firmware Type: 4354 version: 22005631 - filename: 10037603-3.1-TRADFRI-signal-repeater-2.2.005.ota.ota.signed size: 189822 Bytes
2019-11-08 22:09:51.223 Status: (Zigate) Available Firmware Type: 16900 version: 20022623 - filename: 10038562-TRADFRI-sy5882-bulb-ws-2.0.022.ota.ota.signed size: 209790 Bytes
2019-11-08 22:09:51.226 Status: (Zigate) Available Firmware Type: 4487 version: 22009631 - filename: 10037585-5.1-TRADFRI-connected-blind-2.2.009.ota.ota.signed size: 186942 Bytes
2019-11-08 22:09:51.228 Status: (Zigate) Available Firmware Type: 4552 version: 20022623 - filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed size: 186814 Bytes
2019-11-08 22:09:51.230 Status: (Zigate) Available Firmware Type: 4545 version: 12223573 - filename: 159699-2.1-TRADFRI-remote-control-1.2.223.ota.ota.signed size: 159806 Bytes
2019-11-08 22:09:51.232 Status: (Zigate) Available Firmware Type: 16901 version: 21022631 - filename: 10040611-3.2-TRADFRI-sy5882-unified-2.1.022.ota.ota.signed size: 208254 Bytes
2019-11-08 22:09:51.234 Status: (Zigate) Available Firmware Type: 8705 version: 12221572 - filename: 10035514-TRADFRI-bulb-ws-1.2.221.ota.ota size: 172734 Bytes
2019-11-08 22:09:51.236 Status: (Zigate) Available Firmware Type: 4548 version: 12214572 - filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota size: 157822 Bytes
2019-11-08 22:09:51.237 Status: (Zigate) Available Firmware Type: 16897 version: 12217572 - filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota size: 173246 Bytes
2019-11-08 22:09:51.240 Status: (Zigate) Available Firmware Type: 16643 version: 21022631 - filename: 10046695-1.1-TRADFRI-light-unified-w-2.1.022.ota.ota.signed size: 202878 Bytes
2019-11-08 22:09:51.242 Status: (Zigate) Available Firmware Type: 4545 version: 23014631 - filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed size: 182590 Bytes
2019-11-08 22:09:51.244 Status: (Zigate) Available Firmware Type: 4353 version: 20022623 - filename: 10005777-4.1-TRADFRI-control-outlet-2.0.022.ota.ota.signed size: 204222 Bytes
2019-11-08 22:09:51.246 Status: (Zigate) Available Firmware Type: 10241 version: 13009572 - filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota size: 178366 Bytes
2019-11-08 22:09:51.247 Status: (Zigate) Available Firmware Type: 16898 version: 12217572 - filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota size: 173246 Bytes
2019-11-08 22:09:51.249 Status: (Zigate) Available Firmware Type: 4546 version: 12248572 - filename: 159701-TRADFRI-wireless-dimmer-1.2.248.ota.ota size: 172926 Bytes
2019-11-08 22:09:51.251 Status: (Zigate) Available Firmware Type: 8449 version: 12214572 - filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota size: 168318 Bytes
2019-11-08 22:09:51.253 Status: (Zigate) Available Firmware Type: 8707 version: 12221572 - filename: 10035534-TRADFRI-bulb-ws-gu10-1.2.221.ota.ota size: 172734 Bytes
2019-11-08 22:09:51.255 Status: (Zigate) Available Firmware Type: 8706 version: 12217572 - filename: 159695-TRADFRI-bulb-ws-1000lm-1.2.217.ota.ota size: 173246 Bytes
2019-11-08 22:09:51.257 Status: (Zigate) Available Firmware Type: 16899 version: 20022623 - filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.022.ota.ota.signed size: 208830 Bytes
2019-11-08 22:09:51.259 Status: (Zigate) Available Firmware Type: 16641 version: 12245572 - filename: 159495-TRADFRI-transformer-1.2.245.ota.ota size: 181118 Bytes
2019-11-08 22:09:51.627 Status: (Zigate) TxPower Attenuation : 0 dBm
2019-11-08 22:09:52.140 (Zigate) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-11-08 22:09:52.242 (Zigate) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-11-08 22:09:54.379 (Zigate) UpdateDevice - (Keuken: Vaatwasser lekkage) 0:Off
2019-11-08 22:10:21.575 (Zigate) UpdateDevice - ( Woonkamer: THB) 0:21.2;59.3;1;1005.3;3
2019-11-08 22:10:21.607 (Zigate) UpdateDevice - (Woonkamer: Temp + RV) 0:21.2;59.3;1
2019-11-08 22:10:21.630 (Zigate) UpdateDevice - (Woonkamer: Temp) 21.2:21.2
2019-11-08 22:10:21.687 (Zigate) UpdateDevice - ( Woonkamer: THB) 0:21.2;58.9;1;1005.3;3
2019-11-08 22:10:21.704 (Zigate) UpdateDevice - (Woonkamer: Temp + RV) 0:21.2;58.9;1
2019-11-08 22:10:21.720 (Zigate) UpdateDevice - (Woonkamer: Luchtvochtigheid) 58.9:1
2019-11-08 22:10:21.743 (Zigate) UpdateDevice - ( Woonkamer: THB) 0:21.2;58.9;1;1005.4;3
2019-11-08 22:10:21.789 (Zigate) UpdateDevice - (Woonkamer: Barometer) 0:1005.4;3
2019-11-08 22:10:52.227 (Zigate) UpdateDevice - (Slaapkamer: THB) 0:17.6;57.7;1;1005.3;3
2019-11-08 22:10:52.270 (Zigate) UpdateDevice - (Slaapkamer: Temp + RV) 0:17.6;57.7;1
2019-11-08 22:10:52.333 (Zigate) UpdateDevice - (Slaapkamer: Temperatuur) 17.6:17.6
2019-11-08 22:10:52.438 (Zigate) UpdateDevice - (Slaapkamer: THB) 0:17.6;57.7;1;1005.0;3
2019-11-08 22:10:52.488 (Zigate) UpdateDevice - (Slaapkamer: Barometer) 0:1005.0;3
2019-11-08 22:10:52.544 (Zigate) UpdateDevice - (Slaapkamer: THB) 0:17.6;57.7;1;1005.3;3
2019-11-08 22:10:52.563 (Zigate) UpdateDevice - (Slaapkamer: Barometer) 0:1005.3;3
2019-11-08 22:11:06.296 (Zigate) UpdateDevice - ( Olivier: THB) 0:17.1;60.8;1;1004.7;3
2019-11-08 22:11:06.335 (Zigate) UpdateDevice - (Olivier: Temp + RV) 0:17.1;60.8;1
2019-11-08 22:11:06.380 (Zigate) UpdateDevice - (Olivier: Temperatuur) 17.1:17.1
2019-11-08 22:11:06.494 (Zigate) UpdateDevice - ( Olivier: THB) 0:17.1;60.5;1;1004.7;3
2019-11-08 22:11:06.511 (Zigate) UpdateDevice - (Olivier: Temp + RV) 0:17.1;60.5;1
2019-11-08 22:11:07.619 (Zigate) Group Management - Discovery mode - Searching for Group Membership (or continue)
2019-11-08 22:11:07.619 (Zigate) Group Management - Discovery mode - Devices to be queried: ['95cc', '819e', '9e2d', '9f16', '4ecf', '987d', '3f96']
2019-11-08 22:11:07.621 (Zigate) hearbeatGroupMgt - Finish Discovery Phase
2019-11-08 22:11:12.656 (Zigate) Group Management - Membership gathering
2019-11-08 22:11:22.629 (Zigate) Group: 0001 -
2019-11-08 22:11:22.629 (Zigate) - device: 95cc/01 000b57fffe907671
2019-11-08 22:11:22.629 (Zigate) - device: 819e/01 000b57fffec51189
2019-11-08 22:11:22.629 (Zigate) Group: cf64 -
2019-11-08 22:11:22.630 (Zigate) - device: 9e2d/01 000d6ffffe7ac128
2019-11-08 22:11:22.630 (Zigate) - device: 9f16/01 14b457fffe4c3e08
2019-11-08 22:11:22.630 (Zigate) - device: 4ecf/01 000d6ffffe8e9fb7
2019-11-08 22:11:22.630 (Zigate) - device: 987d/01 14b457fffe4c273a
2019-11-08 22:11:22.630 (Zigate) - device: 3f96/01 14b457fffe3dbe31
2019-11-08 22:11:22.630 (Zigate) Group Management - Discovery Completed
2019-11-08 22:11:28.586 (Zigate) UpdateDevice - (Slaapkamer: Beweging rechts) 1:On
2019-11-08 22:11:32.677 (Zigate) Group Management - End of Configuration processing
2019-11-08 22:11:32.678 (Zigate) - To be removed : []
2019-11-08 22:11:32.678 (Zigate) - To be added : []
2019-11-08 22:11:37.665 (Zigate) Group Management - Checking Group list
2019-11-08 22:11:37.666 (Zigate) bestGroupWidget - Group: 0001 processing 95cc
2019-11-08 22:11:37.666 (Zigate) --------------- - processing 95cc code: 2 widget: (244, 73, 7), color_widget: None _ikea_colormode: None
2019-11-08 22:11:37.666 (Zigate) bestGroupWidget - Group: 0001 processing 819e
2019-11-08 22:11:37.667 (Zigate) --------------- - processing 819e code: 2 widget: (244, 73, 7), color_widget: None _ikea_colormode: None
2019-11-08 22:11:37.667 (Zigate) _bestGroupWidget - 0001 Code: 2, Color_Widget: None, widget: (244, 73, 7)
2019-11-08 22:11:37.667 (Zigate) hearbeatGroupMgt - _updateDomoGroup done
2019-11-08 22:11:37.667 (Zigate) bestGroupWidget - Group: cf64 processing 9e2d
2019-11-08 22:11:37.668 (Zigate) --------------- - processing 9e2d code: 3 widget: (241, 8, 7), color_widget: None _ikea_colormode: ColorControlWW
2019-11-08 22:11:37.668 (Zigate) bestGroupWidget - Group: cf64 processing 9f16
2019-11-08 22:11:37.668 (Zigate) --------------- - processing 9f16 code: 3 widget: (241, 8, 7), color_widget: None _ikea_colormode: ColorControlWW
2019-11-08 22:11:37.668 (Zigate) bestGroupWidget - Group: cf64 processing 4ecf
2019-11-08 22:11:37.668 (Zigate) --------------- - processing 4ecf code: 3 widget: (241, 8, 7), color_widget: None _ikea_colormode: ColorControlWW
2019-11-08 22:11:37.668 (Zigate) bestGroupWidget - Group: cf64 processing 987d
2019-11-08 22:11:37.668 (Zigate) --------------- - processing 987d code: 3 widget: (241, 8, 7), color_widget: None _ikea_colormode: ColorControlWW
2019-11-08 22:11:37.669 (Zigate) bestGroupWidget - Group: cf64 processing 3f96
2019-11-08 22:11:37.669 (Zigate) --------------- - processing 3f96 code: 3 widget: (241, 8, 7), color_widget: None _ikea_colormode: ColorControlWW
2019-11-08 22:11:37.669 (Zigate) _bestGroupWidget - cf64 Code: 3, Color_Widget: None, widget: (241, 8, 7)
2019-11-08 22:11:37.669 (Zigate) hearbeatGroupMgt - _updateDomoGroup done
2019-11-08 22:11:37.670 Status: (Zigate) Group Management - startup done
2019-11-08 22:11:45.987 (Zigate) Group: 0001 - Achtertuin: Zithoek
2019-11-08 22:11:45.988 (Zigate) Group: 0001 - [('95cc', '01'), ('819e', '01')]
2019-11-08 22:11:45.988 (Zigate) - device: 95cc/01 000b57fffe907671
2019-11-08 22:11:45.988 (Zigate) - device: 819e/01 000b57fffec51189
2019-11-08 22:11:45.988 (Zigate) Group: cf64 - Woonkamer: Spot uitbouw
2019-11-08 22:11:45.988 (Zigate) Group: cf64 - [('9e2d', '01'), ('9f16', '01'), ('4ecf', '01'), ('987d', '01'), ('3f96', '01')]
2019-11-08 22:11:45.988 (Zigate) - device: 9e2d/01 000d6ffffe7ac128
2019-11-08 22:11:45.988 (Zigate) - device: 9f16/01 14b457fffe4c3e08
2019-11-08 22:11:45.989 (Zigate) - device: 4ecf/01 000d6ffffe8e9fb7
2019-11-08 22:11:45.989 (Zigate) - device: 987d/01 14b457fffe4c273a
2019-11-08 22:11:45.989 (Zigate) - device: 3f96/01 14b457fffe3dbe31
2019-11-08 22:11:54.396 (Zigate) UpdateDevice - (Woonkamer: Dressoir) 1:30
2019-11-08 22:11:58.998 (Zigate) UpdateDevice - (Slaapkamer: Beweging rechts) 0:Off
2019-11-08 22:12:19.476 (Zigate) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-11-08 22:12:19.686 (Zigate) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-11-08 22:12:19.787 (Zigate) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-11-08 22:12:29.480 (Zigate) Decode8000 - PacketType: 0100 Status: [15] - 15
2019-11-08 22:12:34.232 (Zigate) readCluster - 0300 - 3f96/01 unknown attribute: 4010 21 0002 ffff
2019-11-08 22:12:38.092 (Zigate) UpdateDevice - (Woonkamer: Dressoir) 1:4d
2019-11-08 22:12:39.014 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:47
2019-11-08 22:13:00.224 (Zigate) readCluster - 0300 - 4ecf/01 unknown attribute: 4010 21 0002 ffff
2019-11-08 22:13:10.574 (Zigate) readCluster - 0300 - 987d/01 unknown attribute: 4010 21 0002 ffff
2019-11-08 22:13:27.514 (Zigate) UpdateDevice - ( Olivier: THB) 0:17.1;60.5;1;1004.9;3
2019-11-08 22:13:27.595 (Zigate) UpdateDevice - (Olivier: Barometer) 0:1004.9;3
2019-11-08 22:13:35.280 (Zigate) readCluster - 0300 - 9e2d/01 unknown attribute: 4010 21 0002 ffff
2019-11-08 22:13:35.820 (Zigate) readCluster - 0300 - 9f16/01 unknown attribute: 4010 21 0002 ffff
2019-11-08 22:13:58.253 (Zigate) Permit Join status: 00
2019-11-08 22:13:58.253 (Zigate) ---> self.permitTojoin['Starttime']: 1573247381
2019-11-08 22:13:58.253 (Zigate) ---> self.permitTojoin['Duration'] : 0
2019-11-08 22:13:58.253 (Zigate) ---> Current time : 1573247638
2019-11-08 22:13:58.253 (Zigate) ---> self.Ping['Permit'] (prev) : On
2019-11-08 22:13:58.253 (Zigate) ---> self.Ping['Permit'] (new ) : Off
2019-11-08 22:14:11.342 (Zigate) readCluster - 0300 - 6439/0b unknown attribute: 0017 20 0001 fe
2019-11-08 22:14:11.343 (Zigate) readCluster - 0300 - 6439/0b unknown attribute: 001b 20 0001 0b
2019-11-08 22:14:11.344 (Zigate) readCluster - 0300 - 6439/0b unknown attribute: 0012 21 0002 4eec
2019-11-08 22:14:11.448 (Zigate) readCluster - 0300 - 6439/0b unknown attribute: 0031 21 0002 6075
2019-11-08 22:14:11.553 (Zigate) readCluster - 0300 - 6439/0b unknown attribute: 0030 21 0002 6161
Hope this helps
Posted: Friday 08 November 2019 22:18
by pipiche
So the widget is not correct ?
What I see it is a WWcolor widget where you can update the white colour .
What are the type of bulb in the group ?
Posted: Friday 08 November 2019 22:26
by ronaldbro
Yep, the group widget displays a wrong dim level.
These are Tradfri GU10 WW bulbs. (You changed the device config file for me last week because RGBWW widgets were created first)
But I also notice a wrong dim level reported back for a Philips hue RGBWW. I send setpoint 30, the bulb seems to be 30 and the widget shows 4. In the log I see:
2019-11-08 22:20:03.994 (Zigate) UpdateDevice - (Woonkamer: Dressoir) 1:4d
Stable branch displays the correct dim level for the hue too.
Posted: Friday 08 November 2019 22:35
by pipiche
Ok, sorry i didn’t catch the issue.
So the issue is the level displayed got the group doesn’t match the 5 bulbs levels.
Let say if you set the group level to 50.% does each bulb are set to 50% ?
Posted: Friday 08 November 2019 22:36
by ronaldbro
Correct.
You can see that in the first log.
(I can understand that it's not helpful in debugging but it shows the problem)
Posted: Friday 08 November 2019 22:38
by ronaldbro
In this piece of log all 5 bulbs have dimlevel 24, but the group returns 38
Posted: Friday 08 November 2019 22:39
by pipiche
Even if you leave 10’
Posted: Friday 08 November 2019 22:46
by ronaldbro
Yep, it stays wrong
Posted: Friday 08 November 2019 22:47
by pipiche
Ok, will have a look. Not at home for now
Posted: Friday 08 November 2019 22:52
by ronaldbro
I switched back to stable and its all correct again.
No problem, just ask if you want me to test something.
Posted: Saturday 09 November 2019 9:39
by pipiche
Could you please switch backup to beta, do a git pull to get the latest version
then restart the plugin
enable debugGroups from the Web Admin GUI
then the plugin will log how the group dim level is calaculated. Would appreciate to have the logs copy-paste here.
Posted: Saturday 09 November 2019 10:45
by ronaldbro
Sure, no problem.
- Spoiler: show
- 2019-11-09 10:44:16.576 (Zigate) Command: 01cf640101014c0010
2019-11-09 10:44:16.359 Status: setcolbrightnessvalue: ID: fe, bri: 30, color: '{m: 2, RGB: 000000, CWWW: 0000, CT: 128}'
2019-11-09 10:44:16.363 Status: setcolbrightnessvalue: ID: 1a6, bri: 30, color: '{m: 2, RGB: 000000, CWWW: 0000, CT: 128}'
2019-11-09 10:44:17.128 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:17.129 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:17.129 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:17.129 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:17.129 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 48
2019-11-09 10:44:17.130 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 48
2019-11-09 10:44:17.130 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 48
2019-11-09 10:44:17.130 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 48
2019-11-09 10:44:17.130 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 48
2019-11-09 10:44:17.130 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 48
2019-11-09 10:44:17.131 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 19
2019-11-09 10:44:22.157 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:22.158 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:22.158 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:22.158 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:22.158 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 48
2019-11-09 10:44:22.159 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 48
2019-11-09 10:44:22.159 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 48
2019-11-09 10:44:22.159 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 48
2019-11-09 10:44:22.159 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 48
2019-11-09 10:44:22.159 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 48
2019-11-09 10:44:22.159 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 19
2019-11-09 10:44:22.369 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 5) 1:30
2019-11-09 10:44:22.783 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 10:44:22.804 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 1) 1:30
2019-11-09 10:44:22.829 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 2) 1:30
2019-11-09 10:44:22.855 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 4) 1:30
2019-11-09 10:44:22.892 (Zigate) UpdateDevice - (Woonkamer: Spot uitbouw 3) 1:30
2019-11-09 10:44:23.009 (Dummy) Light/Switch (Scene Avond Alleen Aan)
2019-11-09 10:44:23.024 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 10:44:27.363 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:27.364 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:27.364 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:27.364 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:27.364 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 119
2019-11-09 10:44:27.365 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 119
2019-11-09 10:44:27.365 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 119
2019-11-09 10:44:27.365 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 119
2019-11-09 10:44:27.365 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 119
2019-11-09 10:44:27.365 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 119
2019-11-09 10:44:27.366 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 47
2019-11-09 10:44:27.366 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:47
2019-11-09 10:44:29.591 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 10:44:29.815 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 10:44:32.396 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:32.396 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:32.396 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:32.397 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:32.397 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 119
2019-11-09 10:44:32.397 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 119
2019-11-09 10:44:32.397 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 119
2019-11-09 10:44:32.398 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 119
2019-11-09 10:44:32.398 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 119
2019-11-09 10:44:32.398 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 119
2019-11-09 10:44:32.398 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 47
2019-11-09 10:44:32.645 (Zigate) readCluster - 0300 - 9f16/01 unknown attribute: 4010 21 0002 ffff
2019-11-09 10:44:37.371 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:37.371 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:37.371 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:37.371 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:37.372 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 119
2019-11-09 10:44:37.372 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 119
2019-11-09 10:44:37.372 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 119
2019-11-09 10:44:37.372 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 119
2019-11-09 10:44:37.372 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 119
2019-11-09 10:44:37.373 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 119
2019-11-09 10:44:37.373 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 47
2019-11-09 10:44:42.404 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:42.405 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:42.405 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:42.405 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:42.405 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 119
2019-11-09 10:44:42.405 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 119
2019-11-09 10:44:42.406 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 119
2019-11-09 10:44:42.406 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 119
2019-11-09 10:44:42.406 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 119
2019-11-09 10:44:42.406 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 119
2019-11-09 10:44:42.406 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 47
2019-11-09 10:44:42.653 (Zigate) readCluster - 0300 - 3f96/01 unknown attribute: 4010 21 0002 ffff
2019-11-09 10:44:47.361 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 0, level: 2
2019-11-09 10:44:47.361 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 819e/01 nValue: 0, level: 2
2019-11-09 10:44:47.361 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, level: 2
2019-11-09 10:44:47.362 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 0, sValue: 1
2019-11-09 10:44:47.362 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 119
2019-11-09 10:44:47.362 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 119
2019-11-09 10:44:47.362 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 4ecf/01 nValue: 1, level: 119
2019-11-09 10:44:47.363 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 119
2019-11-09 10:44:47.363 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 10:44:47.363 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 10:44:47.363 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 10:44:47.363 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:46
2019-11-09 10:44:49.609 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 10:44:49.834 (Dummy) Light/Switch (Scene - Check scenes)
Posted: Saturday 09 November 2019 10:48
by pipiche
Thanks and could you tell me what dim level you expect ?
Posted: Saturday 09 November 2019 11:13
by ronaldbro
I expect dim level 30. See also the command in the first lines of the log
Posted: Saturday 09 November 2019 16:20
by pipiche
@ronaldbro if you can update the beta branch and test it, let me know if it is better or worst
Posted: Saturday 09 November 2019 18:18
by ronaldbro
I just did, and it's not good yet.
I send dim lvl 30 and zigate reports back 46
- Spoiler: show
- 2019-11-09 18:15:19.684 (Zigate) UpdateGroup - (Woonkamer: Spot uitbouw) 1:46
2019-11-09 18:15:19.551 Status: setcolbrightnessvalue: ID: fe, bri: 30, color: '{m: 2, RGB: 000000, CWWW: 0000, CT: 128}'
2019-11-09 18:15:19.554 Status: setcolbrightnessvalue: ID: 1a6, bri: 30, color: '{m: 2, RGB: 000000, CWWW: 0000, CT: 128}'
2019-11-09 18:15:21.515 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:21.515 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:21.524 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:21.524 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:21.524 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:21.525 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:21.525 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:21.525 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:21.525 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:15:22.148 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 18:15:22.335 (Dummy) Light/Switch (Scene Avond Alleen Aan)
2019-11-09 18:15:22.364 (Dummy) Light/Switch (Scene - Check scenes)
2019-11-09 18:15:26.483 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:26.483 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:26.483 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:26.484 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:26.484 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:26.484 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:26.484 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:26.484 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:26.484 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:15:31.509 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:31.509 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:31.509 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:31.509 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:31.510 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:31.510 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:31.510 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:31.510 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:31.510 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:15:36.488 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:36.489 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:36.489 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:36.489 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:36.489 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:36.490 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:36.490 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:36.490 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:36.490 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:15:36.735 (Zigate) readCluster - 0300 - 3f96/01 unknown attribute: 4010 21 0002 ffff
2019-11-09 18:15:48.631 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:48.631 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:48.631 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:48.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:48.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:48.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:48.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:48.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:48.633 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:15:53.612 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:53.612 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:53.613 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:53.613 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:53.613 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:53.613 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:53.614 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:53.614 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:53.614 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:15:54.178 (Zigate) readCluster - 0300 - 9f16/01 unknown attribute: 4010 21 0002 ffff
2019-11-09 18:15:58.628 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:15:58.628 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:15:58.631 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:15:58.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:15:58.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:15:58.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:15:58.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:15:58.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
2019-11-09 18:15:58.632 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, sValue: 46
2019-11-09 18:16:03.640 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 95cc/01 nValue: 1, level: 2
2019-11-09 18:16:03.641 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, level: 2
2019-11-09 18:16:03.647 (Zigate) updateDomoGroupDevice - Processing: Group: 0001 ==> nValue: 1, sValue: 1
2019-11-09 18:16:03.648 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9e2d/01 nValue: 1, level: 118
2019-11-09 18:16:03.648 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 9f16/01 nValue: 1, level: 118
2019-11-09 18:16:03.648 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 987d/01 nValue: 1, level: 118
2019-11-09 18:16:03.648 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 3f96/01 nValue: 1, level: 118
2019-11-09 18:16:03.648 (Zigate) updateDomoGroupDevice - Processing: Group: cf64 ==> nValue: 1, level: 118
Posted: Sunday 10 November 2019 12:37
by pipiche
Can you try once more ?
Posted: Sunday 10 November 2019 14:10
by ronaldbro
Hi pipiche, I want to but I got a lot of trouble with switching to beta and back to stable. Yesterday most of my devices stoped working. For my xiaomi devices it was enough to press the little button once. For half my tradfri's I had to bind them again.
At this moment I have most of them working again but I still have some problems.
I can't rebind Tradfri E27 1000lm and get the following message in the log:
- Spoiler: show
- 2019-11-10 13:53:45.016 (Zigate) Decode004d - Looks like it is a new device sent by Zigate
2019-11-10 13:53:45.017 (Zigate) Decode004d - 7178 Info: {'Status': '0045', 'IEEE': '000b57fffec51189', 'ReadAttributes': {}, 'Last Cmds': [], 'Battery': {}, 'Maufacturer Name': '', 'Model': {}, 'Heartbeat': '0', 'Type': {}, 'PowerSource': '', 'Manufacturer': '', 'Health': '', 'DeviceType': '', 'Version': '3', 'ReceiveOnIdle': '', 'MacCapa': '8e', 'RIA': '0', 'ZCL Version': '', 'SQN': '', 'ZDeviceName': '', 'RSSI': {}, 'App Version': '', 'Stack Version': '', 'ZDeviceID': {}, 'NbEp': '', 'HW Version': '', 'Attributes List': {}, 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'Ep': {}, 'LogicalType': '', 'Stamp': {}, 'ProfileID': {}}
2019-11-10 13:53:45.015 Status: (Zigate) Device Annoucement ShortAddr: 7178, IEEE: 000b57fffec51189
2019-11-10 13:53:49.530 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 0, HB_: 1
2019-11-10 13:53:52.963 (Zigate) Decode004d - rebind clusters for 2832
2019-11-10 13:53:52.963 Status: (Zigate) Device Annoucement ShortAddr: 2832, IEEE: 00158d0002490400
2019-11-10 13:53:54.524 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 0, HB_: 2
2019-11-10 13:53:59.512 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 0, HB_: 3
2019-11-10 13:53:59.693 (Zigate) Decode8030 - Bind response SQN: 1d status [8c] - The device does not have table space to support the operation.
2019-11-10 13:53:59.898 (Zigate) Decode8030 - Bind response SQN: 1e status [8c] - The device does not have table space to support the operation.
2019-11-10 13:53:59.512 Status: (Zigate) [0] NEW OBJECT: 7178 TimeOut in 0045 restarting at 0x004d
2019-11-10 13:53:59.512 Status: (Zigate) [0] NEW OBJECT: 7178 Request Model Name
2019-11-10 13:54:00.154 (Zigate) Decode8030 - Bind response SQN: 1f status [8c] - The device does not have table space to support the operation.
2019-11-10 13:54:02.907 (zwave) Lux (Achtertuin: Lux (PIR))
2019-11-10 13:54:02.947 (zwave) Lux (Achtertuin: Lux (PIR))
2019-11-10 13:54:04.551 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 1, HB_: 1
2019-11-10 13:54:04.896 (zwave) Temp (Achtertuin: Temperature (PIR))
2019-11-10 13:54:04.937 (zwave) Temp (Achtertuin: Temperature (PIR))
2019-11-10 13:54:09.515 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 1, HB_: 2
2019-11-10 13:54:14.555 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 1, HB_: 3
2019-11-10 13:54:14.556 Status: (Zigate) [1] NEW OBJECT: 7178 TimeOut in 0045 restarting at 0x004d
2019-11-10 13:54:14.556 Status: (Zigate) [1] NEW OBJECT: 7178 Request Model Name
2019-11-10 13:54:22.508 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 2, HB_: 1
2019-11-10 13:54:27.548 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 2, HB_: 2
2019-11-10 13:54:34.150 Status: Incoming connection from: 192.168.1.29
2019-11-10 13:54:36.262 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 2, HB_: 3
2019-11-10 13:54:36.262 Status: (Zigate) [2] NEW OBJECT: 7178 TimeOut in 0045 restarting at 0x004d
2019-11-10 13:54:36.262 Status: (Zigate) [2] NEW OBJECT: 7178 Request Model Name
2019-11-10 13:54:41.264 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 3, HB_: 1
2019-11-10 13:54:46.299 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 3, HB_: 2
2019-11-10 13:54:51.308 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 3, HB_: 3
2019-11-10 13:54:51.308 Status: (Zigate) [3] NEW OBJECT: 7178 TimeOut in 0045 restarting at 0x004d
2019-11-10 13:54:51.343 Status: (Zigate) [3] NEW OBJECT: 7178 Request Model Name
2019-11-10 13:54:56.295 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 4, HB_: 1
2019-11-10 13:55:01.315 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 4, HB_: 2
2019-11-10 13:55:06.304 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 4, HB_: 3
2019-11-10 13:55:06.304 Status: (Zigate) [4] NEW OBJECT: 7178 TimeOut in 0045 restarting at 0x004d
2019-11-10 13:55:06.305 Status: (Zigate) [4] NEW OBJECT: 7178 Request Model Name
2019-11-10 13:55:11.272 (Zigate) processNotinDBDevices - NWKID: 7178, Status: 0045, RIA: 5, HB_: 1
2019-11-10 13:55:11.272 (Zigate) processNotinDB - not able to find response from 7178 stop process at 0045
2019-11-10 13:55:11.272 (Zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: {}
2019-11-10 13:55:11.273 (Zigate) processNotinDB - Collected Infos are : {'Status': 'UNKNOW', 'IEEE': '000b57fffec51189', 'ReadAttributes': {'Ep': {'01': {'0000': {}}, '06': {'0000': {}}, '09': {'0000': {}}, '03': {'0000': {}}, '02': {'0000': {}}}, 'TimeStamps': {'09-0000': 1573390506, '06-0000': 1573390506, '03-0000': 1573390506, '02-0000': 1573390506, '01-0000': 1573390506}}, 'Last Cmds': [], 'Battery': {}, 'Maufacturer Name': '', 'Model': {}, 'Heartbeat': '1', 'Type': {}, 'PowerSource': '', 'Manufacturer': '', 'Health': '', 'DeviceType': '', 'Version': '3', 'ReceiveOnIdle': '', 'MacCapa': '8e', 'RIA': '5', 'ZCL Version': '', 'SQN': '', 'ZDeviceName': '', 'RSSI': {}, 'App Version': '', 'Stack Version': '', 'ZDeviceID': {}, 'NbEp': '', 'HW Version': '', 'Attributes List': {}, 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'Ep': {}, 'LogicalType': '', 'Stamp': {'Time': '2019-11-10 13:55:06', 'MsgType': '8702'}, 'ProfileID': {}}
2019-11-10 13:55:11.344 (Zigate) OTA heartbeat - [869] Type: None out of 10 remaining Images, Device: None, out of ? remaining devices, upgradeInProgress: None
2019-11-10 13:55:11.272 Status: (Zigate) [5] NEW OBJECT: 7178 Not able to get all needed attributes on time
And I have a hue which doesn't work and after a power switch off/on I get the following in the log:
2019-11-10 14:06:42.372 Status: (Zigate) Device Annoucement ShortAddr: 6439, IEEE: 0017880104851759
2019-11-10 14:06:43.073 (Zigate) Decode8030 - Bind response SQN: 35 status [8c] - The device does not have table space to support the operation.
Can you please help?
I'm on the stable right now. (I noticed slow response in beta from devices, so didn't want to stay on beta)
