All my blockly scripts stopped working after an update
Posted: Friday 08 November 2019 20:11
by RduPre
All my blockly scripts stopped working after an update I did this week.
Lua scripts are working without any problem.
I tried to create a new Blockly script which does not work either.
Nothing in de logs :-(
Please help because I have a lot of Blockly scripts
Thanks,
Rien
Version: 4.11474
Build Hash: 12feb06f1
Compile Date: 2019-11-08 16:33:53
dzVents Version: 2.5.0
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Re: All my blockly scripts stopped working after an update
Posted: Friday 08 November 2019 21:02
by Geitje
Is eventsystem ticked (under settings-> other)?
I had something like that after a major update, in my case: some old blockies did not work, exact new copies did, still do not know what the problem was.
Posted: Friday 08 November 2019 22:45
by RduPre
Geitje wrote: Friday 08 November 2019 21:02 Is eventsystem ticked (under settings-> other)?
Yes it is, LUA scripts are running normally
Geitje wrote: Friday 08 November 2019 21:02 I had something like that after a major update, in my case: some old blockies did not work, exact new copies did, still do not know what the problem was.
If I create a new one, it still doesn't work :oops:
Posted: Friday 08 November 2019 22:59
by waaren
RduPre wrote: Friday 08 November 2019 22:45 If I create a new one, it still doesn't work :oops:
If you create a new one and save it you should see something in the log like 2019-11-08 22:58:09.619 Status: EventSystem: reset all events...
Do you see that ?
Posted: Friday 08 November 2019 23:00
by RduPre
waaren wrote: Friday 08 November 2019 22:59
Do yoyusee that ?
Yes !!
Posted: Friday 08 November 2019 23:14
by waaren
RduPre wrote: Friday 08 November 2019 23:00 Yes !!
OK,
you can check what is in the database. What do you see doing this ? (if you have not installed sqlite3 yet, install it first using
sudo apt install sqlite3
Then (on the CLI)
cd <domoticz  dir>
sudo cp domoticz.db safecopy.db
sudo sqlite3 safecopy.db
sqlite> .he on
sqlite> .ta
sqlite> select ID, Name, Type , Status from EventMaster where interpreter = 'Blockly';
sqlite> select * from eventRules where EMID in (select ID from EventMaster where interpreter = 'Blockly');
sqlite> .q
sudo rm safecopy.db
Posted: Saturday 09 November 2019 7:58
by RduPre
This is what I get.
Looks good to me, but I'm no expert ;)
sqlite> .ta
BackupLog             Meter                 SceneTimers
Cameras               Meter_Calendar        Scenes
CamerasActiveDevices  MobileDevices         SetpointTimers
CustomImages          MultiMeter            SharedDevices
DeviceStatus          MultiMeter_Calendar   Temperature
DeviceToPlansMap      MySensors             Temperature_Calendar
EnoceanSensors        MySensorsChilds       TimerPlans
EventMaster           MySensorsVars         Timers
EventRules            Notifications         ToonDevices
Fan                   Percentage            UV
Fan_Calendar          Percentage_Calendar   UV_Calendar
FibaroLink            Plans                 UserSessions
Floorplans            Preferences           UserVariables
GooglePubSubLink      PushLink              Users
Hardware              Rain                  WOLNodes
HttpLink              Rain_Calendar         Wind
LightSubDevices       SceneDevices          Wind_Calendar
LightingLog           SceneLog              ZWaveNodes
ID|Name|Type|Status
1|Alarm Disarmed by Night|All|1
2|Alarm Arm Home|All|1
3|Alarm Arm Away|All|1
4|Kantoor Verlichting On|All|1
5|Kantoor Verlichting Off|All|1
7|Day On/off|All|1
8|Alarm Disarmed at Day|All|1
9|Huis Verlichting aan bij beweging voordeur|All|1
10|Huisverlichting uit bij geen beweging voordeur|All|1
12|Lichten aan bij Alarm|All|1
13|Woonkamer verlichting uit bij Zonsopkomst|All|1
14|Verlichting uit bij niet thuis|All|1
15|Tuin verlichting bij openen poort|All|1
19|Script #1|All|1
20|Script #2|All|1
21|Script #3|All|1
ID|EMID|Conditions|Actions|SequenceNo
7|9|(device[1352] == "On"  and  device[1264] == "Off")|commandArray[660]="On"|1
8|10|(device[1352] == "Off"  and  (device[1264] == "Off"  and  (timeofday  >  0  and  timeofday  <  420)))|commandArray[660]="Off"|1
11|12|device[1391] == "On"|commandArray[Group:8]="On"|1
19|14|(securitystatus  ==  2  and  timeofday  ==  1390)|commandArray[Group:8]="Off",commandArray[Group:10]="Off",commandArray[Group:9]="Off"|1
20|15|device[1425] == "On"|commandArray[532]="On FOR 10"|1
22|3|securitystatus  ==  2|commandArray[Group:8]="Off",commandArray[Group:9]="Off",commandArray[1474]="Off"|1
23|2|securitystatus  ==  1|commandArray[Group:8]="Off",commandArray[Group:9]="Off",commandArray[1474]="Off"|1
24|8|(securitystatus  ==  0  and  device[1264] == "On")|commandArray[522]="Off",commandArray[1391]="Off",commandArray[1474]="On"|1
25|1|(securitystatus  ==  0  and  device[1264] == "Off")|commandArray[1225]="On",commandArray[1236]="On",commandArray[906]="On",commandArray[907]="On",commandArray[906]="On",commandArray[1391]="Off",commandArray[1474]="On"|1
26|4|device[1224] == "On"|commandArray[1038]="On"|1
27|5|device[1224] == "Off"|commandArray[1038]="Off",commandArray[549]="Off"|1
29|19|device[1224] == "On"|commandArray[1038]="On"|1
30|13|timeofday  ==  @Sunrise|commandArray[Group:6]="Off",commandArray[660]="Off"|1
31|20|timeofday  ==  1194|commandArray[Group:6]="Off",commandArray[660]="Off"|1
32|21|device[1474] == "Off"|commandArray["WriteToLogText"]="Dit is een test"|1
sqlite>
Posted: Saturday 09 November 2019 10:49
by waaren
RduPre wrote: Saturday 09 November 2019 7:58 Looks good to me, but I'm no expert ;)
Yes. that looks OK.
Can you also do
cd <domoticz  dir>
sqlite> .he on
sqlite> select key, nValue from preferences where key in ('EnableEventScriptSystem','DisableDzVentsSystem');
sqlite> .q
sudo rm safecopy.db
Posted: Saturday 09 November 2019 10:51
by RduPre
Here you go
SQLite version 3.16.2 2017-01-06 16:32:41
Enter ".help" for usage hints.
sqlite> .he on
Key|nValue
EnableEventScriptSystem|1
DisableDzVentsSystem|0
Posted: Saturday 09 November 2019 10:58
by waaren
RduPre wrote: Saturday 09 November 2019 10:51 EnableEventScriptSystem|1
That is what it should be.
Can you stop domoticz and start it from the CLI with
cd <domoticz dir>
sudo ./domoticz -loglevel  normal,status,error,debug --debuglevel normal,eventsystem
Posted: Saturday 09 November 2019 11:06
by RduPre
Hmmm,
It seems to work when I start domoticz from the CLI, any clues why ?
Posted: Saturday 09 November 2019 11:09
by waaren
RduPre wrote: Saturday 09 November 2019 11:06 Hmmm,
Not directly but maybe if you show the relevant parts of /etc/init.d/domoticz.sh (if you use that to start)
Posted: Saturday 09 November 2019 11:34
by RduPre
I don't know what's relevant, so here is the whole file
#! /bin/sh
### BEGIN INIT INFO
# Provides:          domoticz
# Required-Start:    $network $remote_fs $syslog
# Required-Stop:     $network $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Home Automation System
# Description:       This daemon will start the Domoticz Home Automation System
### END INIT INFO
# Do NOT "set -e"
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Domoticz Home Automation System"
NAME=domoticz
USERNAME=pi
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
DAEMON=/home/pi/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8081"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 0"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
pidof_domoticz() {
    # if there is actually a domoticz process whose pid is in PIDFILE,
    # print it and return 0.
    if [ -e "$PIDFILE" ]; then
        if pidof domoticz | tr ' ' '\n' | grep -w $(cat $PIDFILE); then
            return 0
        fi
    fi
    return 1
# Function that starts the daemon/service
do_start()
        # Return
        #   0 if daemon has been started
        #   1 if daemon was already running
        #   2 if daemon could not be started
        start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
                || return 1
        start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
                $DAEMON_ARGS \
                || return 2
# Function that stops the daemon/service
do_stop()
        # Return
        #   0 if daemon has been stopped
        #   1 if daemon was already stopped
        #   2 if daemon could not be stopped
        #   other if a failure occurred
        start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME
        RETVAL="$?"
        [ "$RETVAL" = 2 ] && return 2
        # Wait for children to finish too if this is a daemon that forks
        # and if the daemon is only ever run from this initscript.
        # If the above conditions are not satisfied then add some other code
        # that waits for the process to drop all resources that could be
        # needed by services started subsequently.  A last resort is to
        # sleep for some time.
        start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON
        [ "$?" = 2 ] && return 2
        # Many daemons don't delete their pidfiles when they exit.
        rm -f $PIDFILE
        return "$RETVAL"
case "$1" in
  start)
        [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
        do_start
        case "$?" in
                0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
                2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
        esac
  stop)
        [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
        do_stop
        case "$?" in
        esac
  status)
      status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
reload)
        log_daemon_msg "Reloading $DESC" "$NAME"
        PID=$(pidof_domoticz) || true
        if [ "${PID}" ]; then
                kill -HUP $PID
                log_end_msg 0
                log_end_msg 1
        fi
  restart)
        log_daemon_msg "Restarting $DESC" "$NAME"
        do_stop
        case "$?" in
          0|1)
                do_start
                case "$?" in
                        0) log_end_msg 0 ;;
                        1) log_end_msg 1 ;; # Old process is still running
                        *) log_end_msg 1 ;; # Failed to start
                esac
                # Failed to stop
                log_end_msg 1
        esac
        echo "Usage: $SCRIPTNAME {start|stop|status|restart|reload}" >&2
        exit 3
esac
Posted: Saturday 09 November 2019 11:55
by waaren
RduPre wrote: Saturday 09 November 2019 11:34 I don't know what's relevant, so here is the whole file
I don't know either what is relevant but the differences between starting from the CLI and starting with /etc/init.d/domoticz.sh
user: domoticz.sh uses PI; CLI uses sudo
www: domoticz.sh uses port 8081; CLI uses 8080 (default)
slwww: domoticz.sh uses port 0 (disabled) ; CLI uses 443(default)
log : domoticz.sh use internal logging only ; CLI use logging to terminal
loglevel: domoticz.sh use none; CLI use normal,eventSystem
Maybe you can see what happens in more detail if you change
in /etc/init.d/domotizc.sh
to
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error,debug"
DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,eventsystem"
and then
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz start
sudo tail -100f /var/log/domoticz.log
Posted: Saturday 09 November 2019 13:57
by RduPre
I don't see anything in the logs that might be suspicious
I have set the default ports in the domoticz.sh (8080 and 443) but this is not the solution
Any other hints or tips ?
Posted: Saturday 09 November 2019 14:39
by waaren
RduPre wrote: Saturday 09 November 2019 13:57 I don't see anything in the logs that might be suspicious
You could try with username=root and update to latest beta.
