telegram http-response, gives error when using it
Posted: Thursday 07 November 2019 21:30
I want to make something with the message_id from telegram.
I get the value out of the answer. But when using it, the script gives me a error.
This one
I know why it gives it. Because it sees it as number value and not as plain text.
But don't know how to solve. Somebody has an idea?
The script which gives this error
This one
2019-11-07 21:22:38.066 Status: dzVents: Error (2.4.19): ...ticz/scripts/dzVents/generated_scripts/test telegram.lua:16: attempt to call local 'onstate' (a number value)But don't know how to solve. Somebody has an idea?
devices = {'Trigger device'},
httpResponses = { "Telegram_Callback"}
execute = function(dz, item)
local teleTok = '12345:0987654321'
local chatId = '123456789'
if item.isHTTPResponse then
if (item.ok) then
local onstate = item.json.result.message_id
print (onstate)
os.execute('curl -s -X POST "https://api.telegram.org/'..teleTok..'/deleteMessage?chat_id='..chatId..'&message_id='..onstate'"').afterSec(10)
print ('niet goed')
dz.openURL(
url = "https://api.telegram.org/bot12345:0987654321/sendMessage?chat_id=123456789&text=Isstil",
method = "GET",
callback = "Telegram_Callback",
